The Official "Does This Fit My Car?" Thread
#161
94 DC4 RS LSV/Turbo
Originally Posted by cbptltypes
Year: 2008
Trim : type-s AT
color : cbp
5 spokes 18' offset 35 volks GT-C.. Nexen tires, 225/45/18
Will those fit in my car?
Trim : type-s AT
color : cbp
BUT
reconsider your tire choice... 235/40-18 or 245/40-18 are ideal
#162
94 DC4 RS LSV/Turbo
Originally Posted by shayan
What registration? My cars registration?
Originally Posted by jguerra23
Nope they don't....Bumpers and doors do... But not the headlights.
#164
stillhere-
I got a rim fitment question for ya..
2005 TL 5AT
Stock braking system
Will......
19x8.5 +35 225/35/19
19x9.5 +30 275/30/19
fit? I don't mind rubbing right now, I'm not going to drop it to the point where it will rub because i'm pretty sure a series 275 tire with width 9.5 will rub; I just want to know if that'll clear the stock brakes, spokes seem to be pretty straight to the lip, with a tiny bit of a curve
2005 TL 5AT
Will......
#165
Honda Noob
stillhere...
Year: 2004
Trim: Base
Color: NBP/Camel
Item you would like fitment verified: i want to know if an 01 - 06 MDX black and burlwood sifter would get my car. Sorry if this is a noob question.
Year: 2004
Trim: Base
Color: NBP/Camel
#166
94 DC4 RS LSV/Turbo
Originally Posted by bforbrian
stillhere-
2005 TL 5AT
Will......
2005 TL 5AT
Will......
#167
94 DC4 RS LSV/Turbo
Originally Posted by nitropwd
stillhere...
Year: 2004
Trim: Base
Color: NBP/Camel
Year: 2004
Trim: Base
Color: NBP/Camel
#169
94 DC4 RS LSV/Turbo
the rear wont work because the ideal negative camber is -1.5 max... and with that tire it will never work... you can run the 225 in the rear, that way it will work
#170
94 DC4 RS LSV/Turbo
MODS STICKIED THE THREAD FOR ME.... LETS KEEP IT ON TOPIC
Follow this guideline
Year: (04, 05, 06, 07 or 08)
Trim: (Base or Type S)
Color: ---
Color: ---
#171
Ok I have a rim fitment question also. I have been researching it and I think it is close/tight fit.
The fronts are
19x8.5 +38
and the backs are
19x9.5 +42
I believe the fronts will be ok but I am unsure of the rears.
These are volk sf-winning wheels. Anyways if they do fit I will be purchasing them I believe.
D
The fronts are
19x8.5 +38
and the backs are
19x9.5 +42
D
#172
05 tl auto blk
my local bodyshop install the side mirrors w/ blinkers blinkers works but my (1)heated mirrors, (2) memory seats, (3) reverse tilt mirrors does not work wat can i do.... ???
install type s tail lights fits nicely but i it seems as though its not bright (is there LEDs behind the tailights or is it conventional bulbs could i get LEDS for it ???
#173
Herro
Year: 2004
Trim: Base Auto
Color: NBP
Item you would like fitment verified: MB Wheels Weapon - 18x9 45 offset with my current Neuspeed Accord Sport Drop (1.75")
http://www.discounttiredirect.com/di...4.3&vid=008463
Trim: Base Auto
Color: NBP
#174
94 DC4 RS LSV/Turbo
The fronts are
19x8.5 +38
and the backs are
19x9.5 +42
D
The fronts are
19x8.5 +38
and the backs are
19x9.5 +42
D
Front Tire
235/35-19
245/35-19
255/35-19
Rear Tire
245/35-19
255/35-19
265/35-19
Good luck...
#175
94 DC4 RS LSV/Turbo
Originally Posted by dchea03@hotmail.com
05 tl auto blk
#176
94 DC4 RS LSV/Turbo
Originally Posted by NBPacuraTL
Year: 2004
Trim: Base Auto
Color: NBP
Trim: Base Auto
Color: NBP
FITMENT: YES... since you do not have brembos they will fit perfect
Tires to be considered
235/40-18 (factory spec fits, but it will not provide lip protection)
245/40-18 (My current setup on an 18x9 wheel)
255/40-18 (what I consider to be a good fit)
#180
04 tl auto
Just purchased TSW 20x8.5 +40 offset chrome rims and already mounted them. See here:
http://www.wheelsnext.com/wheels-rim...ro-Chrome.html
Now car feels like it's draging a**. Is there some kind of adjustment needs to me made? Everything fits perfect. Looks great.
Please help as I have to drive it 150mi. on Saturday. Wanna get this taken care of.
#181
94 DC4 RS LSV/Turbo
what tires did you throw on?
also keep in mind that 20" wheels get up there in weight... I wouldn't be surprised if those wheels weighed in at 40lbs a pop... I'd say they weight in at 35lbs each... lastly keep in mind that you may also just be feeling that lag for now because you have not come accustomed to it... rolling big has its down sides
#182
#183
UOTE=stillhere153]the rear wont work because the ideal negative camber is -1.5 max... and with that tire it will never work... you can run the 225 in the rear, that way it will work[/QUOTE]
You're positive? So if I run 225 series tire on a 9.5 width with a 30 offset will it rub?
#184
94 DC4 RS LSV/Turbo
Originally Posted by MinDawg
I have Falken Azernis 245/35ZR20 95W tires on. It's 50psi max and I have 45psi front, 42psi back. oh and LH rear is on 17" stock as other tire needs to be fixed.
wow dude ur tires are completely off
and wait I had no idea you had to fill the tires up that high... 35psi all around? what ever happend to that?
you are supposed to be running 245/30-20...
Speedometer: 56.7 mph 94.6 km/h (WHEN IT SHOULD BE READING 60MPH)
Speedometer Difference: 5.646% too slow
Diameter Difference: 5.35% <- BAD
#185
94 DC4 RS LSV/Turbo
You're positive? So if I run 225 series tire on a 9.5 width with a 30 offset will it rub?[/QUOTE]
if you roll the fenders and negative camber it will not rub... but your lip will be a couple mm off the ground... so the hardest bump would bend/crack or both that wheel
#186
fitment question
Here we go 2006 tl auto A Spec Tein S Tech coils, want to mount the following
18x8.5 35mm off set with 245 40 18 tires, 19x9.5 40 mm offset with 255 35 19 tires
#189
lil' kid in ya....
Stillhere153,
Like a NOOB that I'm, I ask you this question on another post and didn't realize you have an official post setup.
Year: 2007
Trim: Type S
Color: WDP
Item you would like fitment verified: Need your expertise on TSW Mondello 18x8 wheels... can they fit with the BBK? If so, what offset do you recommend?? Do you recommend stepping up to 19s and will 19s make a signifcant difference in ride comfort/performance?
Sorry for the multiple questions within a question..hehe.
Thanks a lot!!
Year: 2007
Trim: Type S
Color: WDP
Thanks a lot!!
#190
94 DC4 RS LSV/Turbo
Pm me when you do it... Def wanna see this
#191
94 DC4 RS LSV/Turbo
This is a stupid question lol but I just need to know
Year: 2005 TL 5AT
Trim: N/A
Color: NBP
20x8.5
20x10
+25 offsets lol
Need tire recommendations if they fit
Year: 2005 TL 5AT
Trim: N/A
Color: NBP
20x8.5
20x10
+25 offsets lol
Unless you are stock height and never put anything in the trunk, never go into turns, and want to look like an isuzu rodeo go for it, but in all reality it does not fit... Even if you wrap 225/30-20 NO GO
Ps. Writing "lol" atleast tells me ur half serious
#192
94 DC4 RS LSV/Turbo
Originally Posted by JVs_TypeS
Stillhere153,
Year: 2007
Trim: Type S
Color: WDP
Year: 2007
Trim: Type S
Color: WDP
For spacers I called Fred @ wheeladapter.com
Thanks a lot!!
Thanks a lot!!
#193
Looks like they missed a couple of the plugs or left something unplugged, where are you located? there are usually aziners ready and willing to help out on wiring problems
the type s tails are pretty bright, you should have someone hit the brake and stand back about 20 feet, they are infact really bright, the only led which you can swap out is the turn signal... hope this helps
#195
Registered Nutsack
I have a 2004 NBP Auto/Navi/ A-spec
Fitment I would like verified:
What size are the OEM 03-05 Accord foglights? I want to do the grill mod but I dont want to spend the $350 for the OEM Accord fogs. I also don't want to put the cheap Ebay junk lights down there either so I figure I would buy the fog kit off Ebay, keep the shrouds and wiring, and swap the cheap lenses for some nicer(at least glass covered) ones instead.
#196
94 DC4 RS LSV/Turbo
Originally Posted by BkRedTL
ok im bac..lol
is there a d i y for the 07 fogs on the 04-06 tl'z?
yes and no... yes there is a diy on lower grill foglights on the 04-06, but it isn't using the 07 foglights... it is using the accord sedan foglights... for this one... search is your friend...
keep it on topic guys
#197
94 DC4 RS LSV/Turbo
sorry but I've never done this mod on any members car... you'd have to ask one of the many guys who has and see what they come up with
#198
What is all this MPH stuff? sorry...noob
#199
I changed it all to 35psi. 245/35ZR20 is not rubbing. any other reason to use 30 over 35? I already have 4 tires
Just thought I would help ya out, Seems like this thread is very informational, helping alot of people, and keepin you busy!!
But MinDawg, MPH stands for Miles Per Hour, speed in which your car travels, running a 35 series as Stillhere stated will show your speedometer to be off.
For example when you are actually traveling at 60 Miles Per Hour, and you have 245/35/20 your speedometer will show a speed of 56.7 Miles Per Hour. But if you have 245/30/20 then your speedometer will show 58.9 Miles Per Hour.
You also need to know that the added weight, places strain on braking as well, your braking distance required is increased as well.
Also it is recommended that your overall Tire diameter not be more than 3% than OEM (originally Equipped by manufacturer). Running 245/35/20 is placing your overall diameter at 5.35% more than OEM, but if you have 245/30/20 the overall diameter will only be 1.79%.
#200
Everything else did help a lot. How big of a deal is this? should I sell my 35s and get 30s? I did get better rotors from exelerated - slotted/drilled with all new ceramic pads.
Thanks for all answers.
