Hazard signal switch lights up?
Old 10-24-2011, 09:49 PM
jungy4's Avatar
Does your hazard signal switch (red triangle) light up with parking or headlights on?
I took out the center vent piece the other day and accidently dropped it. I don't know if I damaged it or not. The switch itself works though.
Old 10-24-2011, 10:08 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
It turns on with both; so should every interior bulb.
Old 10-24-2011, 10:40 PM
PR_Guy's Avatar
Does the windshield wiper thing light up!??
Old 10-24-2011, 10:41 PM
PR_Guy's Avatar
oops... nvm.. its the steering wheel lol
Old 10-24-2011, 10:56 PM
jungy4's Avatar
Thank you for that picture. Everything but that hazard switch lights up. It's funny how similar thing happened to my old car. The bulb got damaged because I dropped it.
Old 10-25-2011, 09:19 AM
lazytik's Avatar
Mine lights up sometimes, and sometimes it doesn't.
Old 10-25-2011, 10:38 AM
jungy4's Avatar
Does "Passenger Airbag" letters light up too?
Old 10-25-2011, 10:46 AM
dwb993's Avatar
^Yes
Old 10-25-2011, 12:11 PM
06WDPAspec's Avatar
My Hazard Switch doesn't light up either, but it probably should.
A few times I had to reach for the Hazard Button at night and I couldn't find it. I had to turn on the map lights to see the button.
I'm sure the button is supposed to be lit in case of emergency and ease of access.
Old 10-25-2011, 12:55 PM
'06 NBP TL
xxkevo's Avatar
Does anyone know how to remove the hazard switch to change the light bulb? i've tried searching awhile back and gave up... but since this thread is up.. I might as well ask
Old 10-25-2011, 01:31 PM
vietxquangstah's Avatar
It's really not that difficult to reach the button in complete darkness... It's located smack dab in the center of your two middle air vents.
I could hit the button with my eyes closed
Old 10-25-2011, 02:37 PM
Fearless DIY Guy
DeathMetal's Avatar
We're you wearing a baseball mitt? How the hell couldn't you find that?
Mine is off and will stay off - it's an aesthetic anomaly relative to the rest of the interior
Old 10-25-2011, 03:04 PM
porkyxp's Avatar
hey death metal, i've actually seen ur threads on swapping interior lights and what you did with the interior lighting is absolutely AMAZING. my lights similarly are having the same problem ... specifically the hazard light, heated seats light, climate control lights and steering wheel lights. the issue I'm having though is that its indeterminate ... sometimes they're on, sometimes they're off; I'm wondering are the bulbs damaged , or could it possibly just be the fuse?
Old 10-25-2011, 04:02 PM
Fearless DIY Guy
DeathMetal's Avatar
Not the fuse, at least I don't suspect as the interior lights are pretty much all or none. It could be a faulty switch or relay as the circuit of which you speak is for the lighting circuit energized when the exterior lights are on. The light switch on your steering stalk would be my first suspect and move from there. Also, check to ensure the fuses are properly seated.
Old 10-25-2011, 04:08 PM
Engineer
lights's Avatar
mine stays off too just like Dan. Actually mine didn't even come with one when I opened up from factory. it was just a socket there without a bulb.
But i do have the person sitting logo on~ lol
Old 10-25-2011, 04:19 PM
Fearless DIY Guy
DeathMetal's Avatar
Goddamit, I need a better camera.
What's your setup there, lights?
Old 10-25-2011, 04:24 PM
Engineer
lights's Avatar
what do you mean Dan? my camera? D90.
Old 10-25-2011, 04:43 PM
jungy4's Avatar
So maybe people with 04 and 05's, theirs light up and maybe 06's doesn't because the passenger airbag indicator was new for 06.
Old 10-25-2011, 04:50 PM
Fearless DIY Guy
DeathMetal's Avatar
Yeah, that's an awesome shot, man!!!
Old 10-25-2011, 04:53 PM
Actually, the 04 was the only year that didn't come with them.
Old 11-01-2011, 09:04 PM
jungy4's Avatar
Well now on mine, the letters and the triangle both light up. I had to just push in the module and it's always lit now.
Old 03-07-2012, 11:17 PM
3GTLCHICK's Avatar
Maybe I missed it, what's the easiest way to change the hazard bulb without breaking anything? TIA.
Old 03-07-2012, 11:31 PM
No other way of doing it other than removing center vents.
All I did (as per deathmetals diy) was pull up really hard on the vent assembly.
Old 03-08-2012, 03:04 AM
legendbliss's Avatar
Can you explain how to do it? I've tried a few times only to scratch the surrounding plastic.
Old 03-08-2012, 12:37 PM
3GTLCHICK's Avatar
Sounds like I'm going to break something. Do the metal bezels come off?
Old 03-08-2012, 03:36 PM
3GTLCHICK's Avatar
Okay we figured out the deal. The vent bezel pulls straight back out and you disconnect two harness plugs.
The switch has two tabs that press in and it slides out.
Old 03-08-2012, 04:59 PM
TLX-S
wilztlxs's Avatar
Any tips for removing the vent?
Old 03-08-2012, 05:43 PM
Going to the gym helps :gheylaugh:
There's no "oh you press this clip in so that it comes out" or "move this out of the way to remove it easier".
You just take it out. Hence why easy is dependant on your strength.
Old 03-08-2012, 06:06 PM
3GTLCHICK's Avatar
Slide it left to right to break it loose. Find somebody with nails and start on the left side. Insert left hand with nails on the top between dash and bezel, the right hand nails dig underneath, near the hazard switch. Pull the left out till it pops out just a bit, then do the same on other side. Pull straight back or you might break tabs on top.
Old 03-17-2012, 01:39 PM
TLX-S
wilztlxs's Avatar
i just got the center vent out to change out the bulb for the hazard button.
you really do have to use a lot of force/strength to get it out, it almost feels/looks like its going to break but the clips eventually give and it comes loose.
Old 03-17-2012, 01:54 PM
Yeah, I think I actually broke a clip or two that fell down the vent lol
Old 03-17-2012, 03:21 PM
TLX-S
wilztlxs's Avatar
yea, i lost one of the clips inside the dash, i took off the driver side panel to the center console to try to find it, but had no luck and gave up.
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
JnC
09-11-2015 06:06 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: Hazard signal switch lights up?
