Maintenance Service ...Input help
Hello acurazine..... I just got a 07 type s with a lil under 77k
and im wondering what full service should do to the car...
timing belt adjuster
timing belt tensioner
timing belt
timing belt idler
water pump
serpentine belt
air filter
cabin filter
Transmission
3rd and 4th gear
91213-rkg-003 x 3
28600-rke-004 x2
28610-rke-004 x1
is there anything im missing.....Or do you guy's recommend anything else that should be done....
timing belt
timing belt idler
water pump
serpentine belt
air filter
cabin filter
Transmission
3rd and 4th gear
91213-rkg-003 x 3
28600-rke-004 x2
28610-rke-004 x1
the timing belt is due at 105k miles, you're only at 77k...you should wait.
you should absolutely change out ALL fluids.
this includes;
-transmission
-brake
-engine oil
--coolant
-power steering fluid
def. change out the pressure switches.
That's basically it for a car with 77k miles...as there's not much to do.
this includes;
-transmission
-brake
-engine oil
--coolant
Type Sik (11-19-2014)
this includes;
-transmission
-brake
-engine oil
--coolant
this includes;
-transmission
-brake
-engine oil
--coolant
thanks for the input
08_UA7_Gr33k
02-11-2016 02:17 PM
