KP Technologies Window roll up module install 3G Garage #I-097
Old 11-13-2012, 03:33 PM
  #521
mc_holla's Avatar
Module has been working for some time now but today it for some reason wasnt. The windows are not rolling up after the delayed double press (but I am able to use the kep to put them up). Anyone have any issues with the module just failing and/or know the warranty details for the unit?
Old 11-13-2012, 03:35 PM
  #522
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
it honestly should not ever fail. it's a dumb animal unit.
i would go back in and recheck your wiring. a t-tap might have come loose from slamming the door, etc.
Old 11-13-2012, 04:07 PM
  #523
mc_holla's Avatar
Ok. Will have to go in one day soon and check. If thats the case I think soldering would be a better option this 2nd time.
Old 11-13-2012, 07:37 PM
  #524
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Guys, I got mine and really like it. Swoosh and I installed it about a month ago. It went very quick (on the install) and it's worth the $59.
Just know that now, they make them to order. They don't have them in stock. So they don't ship the next day.
sauceja (11-27-2012)
Old 11-13-2012, 08:31 PM
  #525
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
best
mod
ever...
especially for a guy like me that drives with the windows down ALL THE TIME!
Old 11-27-2012, 12:47 PM
  #526
07TLBONB's Avatar
Will work with Viper 5704....however...
I installed this module and I love it! I also purchased a Viper 5704 2 way security and remote start system on Amazon for 190 (lists on Viper website for 600). After installing the alarm I learned you can actually program the alarm to send 2 lock pulses with only hitting the lock button on the LCD remote once. Which will in turn roll the windows up like before. However if you want to lock the doors and leave the windows down...then you will have to physcially push twice like before.
The windows WILL NOT ROLL DOWN anymore with the addition of the alarm without the addition of a 530t window module which can do 2 windows 2 directions or 4 windows 1 direction, which works for this case bc we just want all 4 of them to go down.
Sunroof will also not open anymore without the addition of a 529t which works for one motor one or two ways...
I bought the alarm, remote start, and all modules (also need a transponder bypass) for 300 on amazon and it would have been over 800 on the Viper website....
Hope this helps anyone with questions about aftermarket alarms
Old 11-27-2012, 01:33 PM
  #527
^^^wow, excellent information, thanks for sharing all that!
Old 12-12-2012, 08:25 AM
  #528
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
Old 02-18-2013, 09:45 PM
  #529
7th Gear
whitesosa's Avatar
might have to try this out
Old 04-02-2013, 10:57 PM
  #530
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
read a couple pages in this thread but has ANYONE tapped into the ACC wire instead of IGN that way it actually works as how it should? With only tapping into IGN, if the key is in ACC, the module will think the car is off.
Old 04-03-2013, 07:30 AM
  #531
I guess I will sound ignorant, but what purpose would that serve? To be able to roll up while the car is still on?
Old 04-03-2013, 10:13 AM
  #532
swoosh's Avatar
^^^ Jeremy, as far as I remember couple folks did not connect the yellow wire (I think which tells the car is on or locked...something around those lines)....the purpose that solves is, if you are crusising down the highway and you get a phone call, you can hit the lock button (in the door panel) twice WHILE driving and all the windows will roll up....
sorry for the very vague description but it has been more than 4 years I did this mod...
Old 04-03-2013, 02:02 PM
  #533
OMG-6SPD
Bada$$VTEC's Avatar
If you dont mind sharing your knowledge swoosh,
but i didnt connect my yellow wire either cuz i found
the DIY to be confusing (basically had to piece info/common sense
to connect it the way its connected now). So if you can tell
me where you connected your yellow wire id be grateful.
edit: nvm,ima go try whats on the first page.
i actually didnt see this DIY.
Old 04-03-2013, 02:14 PM
  #534
swoosh's Avatar
its all good...The first post is very very descriptive and well written
since the yellow wire is connected to a switched 12volts(when you turn on the ignition this wire gets 12volts that will keep the module from working when the ignition is on and/or car running, one could simply leave the wire unconnected and use the module even when the car is running
Bada$$VTEC (04-03-2013)
Old 04-03-2013, 06:07 PM
  #535
OMG-6SPD
Bada$$VTEC's Avatar
Thanks Anil,i had my buddy TLDude876 try locking his car
with the ignition on/car running & he said it didnt roll the windows
up (i helped him install his roll up module for him but forgot to test mine
before i connected the yellow wire today). So idk what the deal is,
I did connect my yellow wire up and it still works the same way it did before.
I also trimmed the height of the door lock while i was at it
Unlocked
Locked
swoosh (04-03-2013)
Old 04-03-2013, 07:48 PM
  #536
swoosh's Avatar
I love the door lock thingie trimmed....I ended up doing this on my car around when I did the mod as well
About the yellow wire...I haven't left it disconnected....I just read on on the forums that someone had left it disconnected and it worked for him....
I have to take my door panel out for something and will try to disconnect the yellow wire and see how it works for me and will let you know bro...
Old 04-03-2013, 07:53 PM
  #537
Bump
Old 04-04-2013, 01:05 AM
  #538
OMG-6SPD
Bada$$VTEC's Avatar
I still have to do the rears,didnt have enough time before work.
I figured id do that mod since i have the shock sensor
and drivers door keyhole delete mod
I dont think disconnecting it is gonna do anything,
but you can try it out and see. Be sure to post up & tell.
Old 04-04-2013, 08:53 AM
  #539
Gotcha, thanks for the x plane, Anil. that makes sense...never thought of doing that...oh well.
Old 04-04-2013, 11:05 AM
  #540
swoosh's Avatar
you dont have to remove the door panel to do the trimmed lock mod
you can unscrew the lock pin, trim it, screw it back on
it does make a lot of sense for us folks who drive with our windows down and might get a call on the HFL....but then again I dont have HFL anymore LOL
Old 04-04-2013, 11:07 AM
  #541
I do, but I turn it off and just use the phone so I can keep the windows open. In hindsight, I shouldn't have even replaced it.
My KP tech thing has bugged out on me before so I'm too to mess with it now.
Old 04-17-2013, 02:31 PM
  #542
6th Gear
loverholic's Avatar
just finished installing my module and love it already.... it started raining right when i was done putting the door panel back so my module became useful immediately.....
#FAST4DR's wiring instructions and pics made this easier than washing my car.... 15mins and door panels were already being screwed back on
thumbs up #FAST4DR & also #kpierson for a great piece of equipment...
Old 04-27-2013, 12:40 AM
  #543
kpierson's Avatar
The yellow wire is a redundant safety inhibit - it is designed to keep the module from outputting a signal to raise the windows while the car is on. However, the OEM Honda BCM won't allow the windows to raise when the ignition is on anyway so in reality the yellow wire is not actually needed for functionality. If you do not hook up the yellow wire you still can NOT raise the windows while the ignition is on - again the OEM BCM will not allow this to happen. Years ago there was some discussion about removing the yellow wire all together but due to safety and liability concerns it was left in.
Old 05-31-2013, 08:45 AM
  #544
TL = True Love
mcmguti's Avatar
Just installed mine today, took me about 1 hour 45 minutes. Had to take the dam door apart twice cause Im a dumbass and got the wire clips too large so I had to splice them up a little with a razor blade the second time around. smh. But once it is installed it works great! Thanks again for the guide.
Old 09-08-2013, 10:22 AM
  #545
www.colradodetail.com
Hondaforlife954's Avatar
i was going to add a LED to the door handle and i just installed this yesterday. would it be safe to tap the red(+12v) and black(ground) wire and put my 12v led on it?
Old 09-26-2013, 12:11 AM
  #546
Damin1123's Avatar
Bumping this thread. Installed mine today and wow it was pretty easy and damn do I love it
Old 11-15-2013, 09:23 PM
  #547
6th Gear
smitht0789's Avatar
Nice!! Thx!!
Old 10-27-2015, 04:54 PM
  #548
jz113's Avatar
can i pay somebody to this? in the LA area
Old 05-26-2016, 04:14 PM
  #549
peter6's Avatar
Thank you so much for this guide. I love this mod !
Couple photos from my installation on Acura TL 2008 :
Old 09-22-2016, 08:58 AM
  #550
charliex2x2's Avatar
2006 Acura TL window/down module
Has anyone ever used the factory auto window/sunroof open/down module off of another TL (same model) to reverse the application for window up /sunroof close as the addition instead of the aftermarket module??
Old 09-22-2016, 09:12 AM
  #551
Received 8,575 Likes on 6,626 Posts
Sounds like a whole lotta work ... And not necessarily cheaper either. What's the benefit here
Old 09-22-2016, 12:12 PM
  #552
peter6's Avatar
Using OEM module to reverse might work if it's separate unit (no idea, but I highly doubt it). Also you would need correct wire (from close door signal) to hold voltage. (to work exactly like open door signal)
Using this module is much easier.
Now when I think about my installation, someday I might try doing my own module with arduino and couple relays. This way I will have 100% control over delays. But what I'm really thinking about is opening all windows with triple click instead of hold. Maybe I will try doing it in future, just need correct wire.
I'm using this option all the time to cool down my car after sitting in sun on parking lot, but holding it sometimes doesn't open my windows all the way (battery is getting low I huess).
02-25-2020 09:57 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
HeloDown
09-08-2015 06:51 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: KP Technologies Window roll up module install 3G Garage #I-097
