Just got a new OEM headlight that I need to blackout
My drivers side headlight got destroyed so I ordered a used replacement. However, I can't seem to remember what paint I used to blackout the chrome. I know it was a flat black, and I thought it was Duplicolor brand. They only make GM/Chrysler Low Gloss paint, and I'm not sure if that will be flat enough.
Does anyone have any experience with the the low glow Duplicolor? I suppose I can buy a few different cans and test them on the broken light, but some of cans aren't cheap.
It might be worth opening both of them up and painting both...
Tycoon
Well you won't know unless you give it a try.. bake the sucker and see if it will come apart. Use your discretion at it, but take your time, don't rush it.
I don't think there's anything you can do without destroying the chrome. It is pretty sensitive to any chemical or friction.
Received 6,470 Likes
I think most of the ones at any auto parts store will be good.
if you just want flat black for a tiny chrome strip, then anything will work fine really. you're not going to notice much difference between any of the big brands(krylon, rustoleum,duplicolor, etc)
as for removing the current black, simple sandpaper will do.
Also, be careful how thick you layer on the paint. the clearance to the headlight cover is extremely tight, and will rub if theres even a little extra paint
Now I'm thinking I may just get a can of the Duplicolor low gloss high temp paint and spray the chrome on my broken headlight and see how it matches. I'm nearly certain I used Duplicolor high temp originally so I'm assuming that has to be the same paint I used before.
I really don't feel like opening up my good light, and as long as the blacks match close enough I'll be fine with it.
Unbelievably the Fedex man actually made a surprise delivery to my house. Normally, they along with UPS will not stop at my house because of my 110lb once went through a window after a delivery man.
Anyway here it is:
I gotta say it looks really good in person. The polycarbonate is in great shape for being from an 04/05. All the mounting tabs are good. Overall not bad for $220.
Now it's time to get my oven mitts and apron so I can get baking.
Anyway here it is:
AmplifiedDetails
09-24-2015 02:55 PM
4drviper
09-23-2015 09:00 PM
