Interior LED install with pictures!!
Old 05-11-2009, 03:28 PM
  #121
dwb993's Avatar
Originally Posted by sprtstr012
http://cgi.ebay.com/ebaymotors/RED-1...mZ380114408027
will thoose fit??they look like a board with leds on them but not like u had which was just a single bulb
They should fit, but I upgraded my front domes from 12LED wedges to 20 LED panels from V-LEDs. Really made a difference.
Those 12LED panels should fit fine. You may want to take a styrofoam packing peanut or something similar to attach it to the light fixture and keep it in place. You do not want to leave the panel sitting directly on the diffuser. I was able to slide one side of my panels into an opening in the housing toward the front of the car. They have remained stable there for several weeks now.
Old 05-19-2009, 10:56 PM
  #122
5th Gear
scott08tls's Avatar
Thanks for this thread, helped a lot with ordering the right bulbs
Old 05-21-2009, 03:00 PM
  #123
5th Gear
moog99's Avatar
Great Thread! Thanks to all for the quality tutorials and info!
Old 05-23-2009, 09:43 PM
  #124
5th Gear
scott08tls's Avatar
is anybody having a problem with the center console and glove box bulbs falling out? I put in the 74-X bulbs and can't seem to get them tight enough. Any ideas?
Old 05-24-2009, 10:13 AM
  #125
dwb993's Avatar
You really have to jam them in. The console is a PITA, just because there is not much play in the wire length. Get the angle right and push them in until they click. You'll get it.
Old 05-24-2009, 09:04 PM
  #126
5th Gear
scott08tls's Avatar
Thanks dwb993, I will try that tomorrow! And I agree the console is a PITA!
Old 05-30-2009, 05:41 AM
  #127
Phmbm12
Phambam12's Avatar
I CANT find those blue LED lights
Old 04-20-2010, 10:06 PM
  #128
Cablevision Employee
robbie82's Avatar
There not really that blue, they look that why in that pic, there just REALLY bright white, with a slight slight hint of blue. Hardly any at all tho.
Old 05-04-2010, 09:36 PM
  #129
Rcolorado's Avatar
Hey Robbie that listing that you put is deleted and gone. Would you happen to have the exact type of bulbs that I need to get?
Old 06-04-2010, 07:39 PM
  #130
turbocivic94's Avatar
How do you remove the glass on front dome lights?
Old 07-21-2010, 05:24 PM
  #131
ionojimbo's Avatar
thanks for the pictures and descriptions, it made my job that much easier! the hardest part of this was taking the bulbs out of the front dome lights. took me about 15 min to take one of those bulbs out.
Advice: use some force and wiggle it a little and it should pop right out. the doors and rear dome lights took about 5 min total compared to the front domes.
Old 07-21-2010, 06:46 PM
  #132
dwb993's Avatar
Yeah, the best way I found was the "Tape Trick"---take a length of scotch tape and loop it around the bulb leaving a length you can hold. Press the tape onto the bulb for a good hold, then pull the bulb by pulling on the extra length of tape. Difficult to describe but it makes removing those front dome lights so much easier.
Old 07-26-2010, 08:18 PM
  #133
Mopos's Avatar
Nice work! Do the lights (LED) dim like the stock bulbs?
Old 07-28-2010, 10:11 AM
  #134
Schweinsteiger11's Avatar
can you get bulbslike these from an everyday store like autozone or walmart or something? id like to avoid having to have them shipped and such.
Old 07-28-2010, 10:34 AM
  #135
dwb993's Avatar
^ Its possible to find them local. You may also want to call a local Radio Shack or similar.
However, the online vendors (esp V-LEDs) ship very quickly---I have received orders from them in as little as 2 days from WA state to PA!!!
Mopos--they do dim like the OEMs, but it is not as smooth. Once the voltage goes below a certain point, the LEDs shut off. Its not too abrupt, but somewhat noticeable if you are looking for it.
Old 10-14-2010, 11:00 PM
  #136
2004 NBP TL 6MT
HondaFan81's Avatar
I have an 04 TL and installed some interior LEDs from www.superbrightleds.com Wanted to make my TL unique and a bit my own, not usually into aesthetic mods.
All bulbs below fit well, the glove box & center console bulbs are snug. Careful with LEDs, push them in fully with normal force and the plastic lens cap fits over like stock.
Vanity lens removed easiest for me with butter knife, as described previously. Push inward and upwards toward headliner, lens comes downward.
6 LED bulbs for map/rear dome lights are plenty bright in cool white for function and nice look. I would say any brighter would annoy while driving. If you want more subtle, yet functional go 4 LED.
4 LED bulbs for vanity in cool white I thought was bright enough for that function, yet not annoying.
3 LED blue bulbs for glove box and center console are subtle, yet compliments stock blue interior lighting.
6 LED blue bulbs for front doors are plenty bright, light up the ground nice when opening doors. Very distinct.
Overall, very happy. Will order cool white bulbs for trunk, reverse and license plate lighting in near future. Those were more expensive and wanted to test out cheaper interior bulbs first.
Went with (order QTY indicated):
- Vanity Lights: WLEDx4 90 deg cool white (QTY: 2)
- Front Map Lights: WLEDx6 cool white (QTY: 2)
- Rear Dome: WLEDx6 cool white (QTY: 2)
- Front Doors: T13x6 wedge base blue (QTY: 2)
- Glove Box: 74-xHP3 wedge base blue (QTY: 1)
- Center Console: 74-xHP3 wedge base blue (QTY: 1)
Old 10-27-2010, 09:41 PM
  #137
I Like turtles
GeeteeDan's Avatar
Thanks for the list. Ordered mine a few minutes ago and will be the first change ive done to my 04 TL.
Daniel
Old 10-28-2010, 12:33 AM
  #138
06TLCROMIE's Avatar
Looks good! little things like that make a huge difference!
Old 10-28-2010, 09:09 PM
  #139
vuuha05's Avatar
Hey robbie82..thanks for the awesome DIY. I just finished installing the new WLED-XHP5 leds. they look so crisp
Old 10-29-2010, 11:19 AM
  #140
ridindirty69's Avatar
Just got my TL definitely doing this mod! Can't wait til I get them in the mail!
Old 10-30-2010, 01:16 PM
  #141
hooch8's Avatar
these lights are the best.....ive had them for a long time and they havent gave me a problem at all
Old 11-01-2010, 06:09 PM
  #142
I Like turtles
GeeteeDan's Avatar
Installed the lights today except the vanity lights, feels like I'm going to break them so I'm going to tackle them tomorrow. Ordered all mine in cool blue and think it turned out awesome. Pictures don't do it justice.
Old 11-02-2010, 10:06 PM
  #143
T2005L's Avatar
I have to be honest. I don't love the blue interior lights. Seems too juvenile for a car like the TL. Plus it hinders how much you can actually see at night, no? To each his own though
I am about to order my LEDs from superbrightleds.com - anyone have a coupon code? I was looking around the v-leds.com website but its way too confusing for me, I like the set-up of superbright a lot better. Here's what I'm getting:
(4) WLEDx6 front and rear domes
(4)921x9 doors and Lic plate
(2) WLEDx4 vanity
all in Cool White
I'll see if I can post pics when I get em in
Old 11-12-2010, 11:25 AM
  #144
T2005L's Avatar
Completed my mod Here are just a few pics, they didn't come out that great.. my only camera is a blackberry.. I also took a pic to really show what the vanity lights look like once you get them off. I didn't see any that gave a good idea of what you were actually working with and I just thought it was a lens cover like the rest of the lights:Name:  IMG00029-20101110-1935.jpg
Size:  56.2 KBName:  IMG00030-20101110-1935.jpg
This is the pass side vanity with old bulb still in. Gives a good idea of taking the cover off. I found best tool was a butter knife and for the vanity's you want to go in for the tabs from the center of the car (DR side go from right, PS go from left)
Old 11-15-2010, 11:45 PM
  #145
danielbui's Avatar
looks way nice i gotta do it
Old 11-15-2010, 11:53 PM
  #146
MechEng
03tLsNBP's Avatar
meh on the blue interior lights. cant see shit when youre actually looking for something in the dark or trying to read a map or something while driving. totally useless.
Old 11-16-2010, 11:39 AM
  #147
T2005L's Avatar
agreed. Mine are not the blue though they are "cool white" that gives off a bluish tint .. looks very good but pics dont do justice
Old 03-29-2011, 04:03 PM
  #148
shey's Avatar
This is awesome; thanks for everyone who gave input. This is actually my first post - just got the 2011 TSX wagon this week. Does anyone know what additional bulbs are required for the wagon?
Old 03-30-2011, 01:50 PM
  #149
I'd rather be golfing
adsoldschool's Avatar
so I'm on the superbrightled web site...seeing that a lot of these posts go back a few years, has anyone tried the "high power" versions I see on their offering?
Old 04-02-2011, 09:54 PM
  #150
av2600's Avatar
im interested if anyone has tried the highpower led's also... looking to replace dome / trunk /door /glovebox /map lights in my 08 type-s....
Old 08-23-2011, 08:26 AM
  #151
robbie82's Avatar
I hear they go out a lot.
Old 08-24-2011, 10:53 PM
  #152
8th Gear
customade's Avatar
Can anyone post a specific link to where I can buy these leds, for my TL 05?
Old 08-24-2011, 11:05 PM
  #153
8th Gear
customade's Avatar
I've found the link but dont know which ones to buy? I wanna replace all my stock lights with leds, help please? Part names?
Old 08-27-2011, 10:35 AM
  #154
robbie82's Avatar
I just did this install on my friends TL and used these bulbs:
http://cgi.ebay.com/ebaymotors/White...item20b8a7a1f5
Old 08-27-2011, 12:47 PM
  #155
dwb993's Avatar
Got vleds.com. At the bottom of the home page is a bulb selector, which will list the bulb types for every location on the car. Then, browse the site for the bulbs in type & color you need. Like them on facebook and you will get coupon codes.
Old 08-28-2011, 01:04 AM
  #156
Former Sponsor
Kinetic's Avatar
nice
Old 05-10-2012, 02:46 PM
  #157
BrownBuck
BrownBuck's Avatar
I found this on youtube. Looks WAY too easy lol..not sure if it's cuz he has all the stuff out of the car. Obviously you don't have to take the whole damn thing out but at least gives you an idea of how to open the light fixtures maybe.
HAHAH just realized nobody has been in this thread for months oops? o well
has anyone used JLC lights?!?
Last edited by BrownBuck; 05-10-2012 at 02:49 PM. Reason: revival of a dead thread? lol
Old 07-18-2012, 07:58 AM
  #158
ResistaNce's Avatar
Want to get all cool white for every interior light.
Somebody tell me part #'s for vleds or superbright leds?
many links expired on here :/ havent messed with a mod like this seems simple but just want to make sure im ordering the right and good quality bulbs. thanks
Old 07-18-2012, 10:41 PM
  #159
Chad05TL's Avatar
I installed dimmer lights up front rather than brighter. The factory bulbs are too bright, they hurt my eyes and I dont want to be on display when I turn on the light at night. In a lot of other cars I had, the dome light was over my head.. Not in front of my face. haha I mean, I would rather have the light shining forward onto the dash or in the footwell.. not in my face. Bad location in my opinion.
Old 10-08-2012, 09:21 AM
  #160
PhilB81's Avatar
Guys, I need your help here...
I'm trying to get a set of dome lights for my TL, what I want is a normal amount of light, I don't need flood lights inside the car.
I found these http://www.v-leds.com/Interior-LED/D...-p6691894.html in another thread, but they are sold out. Also I can't seem to find dome lights at vleds...
I also looked at http://www.superbrightleds.com/cat/l...-1071--448498/
But I'm not too sure where to pick. My main requirement is I want them to be WHITE. I don't want a blue hue to it, if anything I'd tolerate a yellow tint, but what I would really like is something white like Mr. GuitarPlayer16 has in his thread.
https://acurazine.com/forums/3g-tl-photograph-gallery-96/some-led-love-lots-pictures-810519/
Many thanks in advance!
Quick Reply: Interior LED install with pictures!!
