iJDMtoy Led DRL Harness Install w/Pics
Old 03-16-2013, 02:28 PM
  #241
Registered Member
The Machine's Avatar
Hopefully all goes well. Let us know how you make out.
Old 03-16-2013, 02:31 PM
  #242
oops is that your face?
cazio's Avatar
def not the bulbs, he was way too rough with the drls and also wires them wrong
Old 03-16-2013, 02:48 PM
  #243
Desert Life Sucks!!
sauceja's Avatar
Yeah I had the same problem and I sent IJDMTOYS the link to this thread and also emailed them detailed pics of the problem I had and pics of the parts needed to fix it.
It was an easy fix for me because I had just ordered a fog light relay kit and didn't use the connectors for the bulbs since I have HID's but wanted to run them through a relay due to flickering issues.
Once I swapped the connector on the ijdmtoy harness to the correct connector for the 9005 bulbs they plugged right up.
If you have a problem with the bulbs swap them sides and they should work.
If not then you have a wiring issue. Run 2 wires off the battery straight to the bulb and check the bulbs that way.
If bulbs work check your wiring.
I jacked up a 6k bulb but I had already planned on ordering the same as machine, the 5k off ebay.
I will dig for the pics but I followed chips write-up here without a hitch except the bulb.
Old 03-16-2013, 02:56 PM
  #244
Desert Life Sucks!!
sauceja's Avatar
See how the bulb has 2 slots and the connector has 1 slot. The ijdm connector has 1 slot and bulb 2 slots.
The connector you need will have 2 slots. They can be found pretty easy but its still a pain in the ass. Or you can file of the tabs on the bulb connector to get it to work for now and have them ship you new bulbs or buy new bulbs.
I am not defending jdmtoy by any means and you should make them foot the bill. Just stating my experience.
Either way to get them to fit snug and click into place you will need the right connector on wire side as the new bulbs are going to have the 2 slots. You WILL have to find a connector for the 9005 bulb (or 9006 can't remember which. I believe its 9006 higher number for low beam)
But you get the point.
As far as your fogs. Thats another issue.
Old 03-22-2013, 09:23 AM
  #245
wcurrin's Avatar
well, the guys at ijdmtoy were excellent to work with, I am sending them back both set of bulbs (fogs and drls) and they are sending me back some slimmer bulbs. Now I will just redo the wiring and give it a go. I'll check back in a couple weeks with results/pics. Thanks for the help everyone.
Old 03-22-2013, 10:29 AM
  #246
Registered Member
Awesome, glad to here! Hopefully you figure out what the issue was.
Old 03-22-2013, 10:56 AM
  #247
cazio's Avatar
a couple weeks!!?? lol I did mine in 30 minutes and that includes a 10 minutes to chip to make sure I did it right before i tested and possible burned up the relay
Old 03-22-2013, 11:17 AM
  #248
2014 Jeep SRT
ebelp's Avatar
Received 1,615 Likes on 1,030 Posts
What's up, Ward...how's the Noke? You probably have the only modded TL there. Post some pics when you can!
Old 03-22-2013, 03:34 PM
  #249
wcurrin's Avatar
well, I just mailed them yesterday, I was giving the postal service time to do their thing.....once I get bulbs back in I'll get on it.
John, what up! Noke is good, just havent been there in a while, I live out by the bay, even fewer TLs this direction. Im catching a bit of the mod bug right now, I might hit you up for some opinions soon...
Old 03-26-2013, 02:33 PM
  #250
08TList's Avatar
anyone know how to get LED DRLs working in an 07-08 TL? I installed the 6 LED version from v-leds and they work only if i only have one in, i read it's a problem with the voltage in the UA7 DRLs but has anyone found a simple fix that maybe i can put together a radio shack?
Old 03-26-2013, 03:36 PM
  #251
wcurrin's Avatar
I got the relay kit from iJDMtoy, it was around $25. You might be able to piece the kit together if you are familiar with electronics and wiring, but I can't be of much help there...
08TList (03-26-2013)
Old 03-26-2013, 08:27 PM
  #252
08TList's Avatar
wirings not a problem, just wanted to see if i could get make a harness myself and what i would need instead of ordering one
Old 03-27-2013, 04:58 PM
  #253
zubi23's Avatar
wait so I can't just buy led 9005 bulbs and plug and play? From what I've read Ill get a DRL warning light?
THAT SUCKS!
Will this void my warranty?
Old 03-27-2013, 05:46 PM
  #254
Registered Member
THAT SUCKS!
No unfortunately you can't just buy the bulbs and plug them into the factory wiring. The LED bulbs require less voltage to operate. So if you just plug them into the factory wiring only a few LED's on the tree will light up, if any at all. You need the relay harness for these to work properly.
And no I don't think this will void your warranty. Since it's plug and play anyway, if something were to happen, which I highly doubt it would, you could just take the kit off and put your halogen bulbs back in and then get the car fixed. But you should be perfectly fine using the kit without any issues.
Old 04-06-2013, 07:58 AM
  #255
wcurrin's Avatar
Ok, went to wire the drls last night and no luck. The bulb fit this time, but I followed the instructions And still got no lights. I know it not the bulbs because these are different bulbs. I will post some pics of my wiring but I am baffled and feel like a complete idiot.
Old 04-06-2013, 01:32 PM
  #256
rotciveel's Avatar
I've read a bunch of stuff here but I can't find a solution to my problem. I run a 2010 TSX and I got the LED DRL kit from iJDMtoy, hooked it all up and neither of the lights work. I just get the DRL error message..
Shouldn't it be a simple plug and play?
mt101 (10-25-2013)
Old 04-12-2013, 02:10 PM
  #257
zubi23's Avatar
[QUOTE=The Machine;13689906][COLOR=Black]I recently bought the ijdmtoy LED DRL kit seen here: http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r3.htm
It was a pretty straight forward install even though it didn't come with any instructions, so I figured I would do a little write up for anyone looking to buy the kit and install it.
I used this video as a reference even though it's the V-Leds kit, but the ijdmtoy kit is very similar.
Here is a picture of the ijdmtoy kit laid out:
anyone know how I can access the youtube video!
It says private video... I just got the drl kit yesterday!!
Old 04-12-2013, 07:27 PM
  #258
Registered Member
It is simple plug and play, but you have a TSX. The kit is meant for the TL. Maybe that is what is causing your issue?
That's odd the video is like that now. But I only posted the video as an extra helping tool. My step by step write up is the exact same as what the video showed. IMO, I think I actually went into a little more detail than the video did. Just follow the steps I wrote and you should be just fine.
Old 04-12-2013, 07:36 PM
  #259
TegoTL's Avatar
This means with this harness, I can put an HID kit instead of LED correct? Fuck the LED's...lol@
Old 04-12-2013, 07:42 PM
  #260
TegoTL's Avatar
Judging from the picture, the kit looks exactly like the ones you would find on ebay for a lot cheaper. I don't know maybe its me, not trying to bash.
http://www.ebay.ca/itm/9005-HB3-LED-...2b912c&vxp=mtr
http://www.ebay.ca/itm/1x-Xenon-HID-...e27f86&vxp=mtr
Also wanted to point out, I was going through this thread, found the pic below and if you look closely at the relay it even says "HID" just like the one in the ebay link above.
Old 04-12-2013, 09:59 PM
  #261
Registered Member
You may be able to hook up HID's to this relay harness and run them as DRL's. However, the housing they are going in is not very big, nor really made to handle an HID bulb, so I don't know how well it will take the heat that an HID gives off. You could potentially melt something.
Old 04-14-2013, 07:24 PM
  #262
zubi23's Avatar
Old 04-14-2013, 07:28 PM
  #263
zubi23's Avatar
okay the stupid ass picture url is not working, but I got it to work and it looks awesome!!!
the only concern I have is that I don't know if I tightened the bulb in all the way. When I had to remove the bulb it took a lot of force to take it out, and when I put in the new bulb with LEDs it went in and I turned it, and i thought it was okay, but then when I checked again it seemed a little loose. the left one I think is in all the way, and the right seems like its in...anyway to find out if the bulb is in properly? what happens if its not i think it may have went into the wrong slot or something and its impossible to see since the battery is in the way on the right side and the engine is in the way on the left...
Old 04-14-2013, 07:37 PM
  #264
zubi23's Avatar
Old 04-15-2013, 06:23 AM
  #265
Registered Member
If you want to post pics, you need to have a site like photobucket host your photos. Then you copy the IMG file and paste it here.
Secondly, yes the stock halogen bulbs are in there pretty tight and it's usually kinda tough to get the LED bulbs in correctly the first try. The connection should still be tight though when they are put in correctly and turned all the way. You can usually tell if they are not in properly because the bulb will be cocked in one direction or the other or facing donward too much, instead of directly facing you. Should be very easy to tell when you look directly at the bulb through the housing. Of course one way to make sure you have the bulb in correctly if you are not sure, is to remove the headlight and put the bulb in, but ain't nobody got time for that, lol.
Old 04-15-2013, 08:45 AM
  #266
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
supposedly HID's burn cooler than Halogen...
Old 04-15-2013, 09:27 AM
  #267
zubi23's Avatar
okay ill upload a pic of how the bulb looks and maybe you guys can tell me if its not in properly.
Lets say it rains alot, will water get down in there and ruin my headlights or electrical connections?!
I even tried using one of those mirror tools but impossible to tell... I think i'll take out my battery and that way I would be able to see if its in there...
Old 04-15-2013, 10:38 AM
  #268
Registered Member
No, even if the bulb was not seated properly water shouldn't be getting into anywhere to ruin anything, unless you plan on driving into a lake, lol.
The bulbs are tucked pretty well under there so if you can't get the bulb in properly by just using your hand and bending down and looking through the front of the lens, then you may need to take the battery out. That was the toughest side to get in properly for me as well since there isn't a lot of room for the hand and arm to move around.
Old 04-17-2013, 07:28 PM
  #269
Acura4life
brandon7583's Avatar
Just wanted to say thanks Machine, this made the install a breeze!
The Machine (04-18-2013)
Old 04-18-2013, 06:18 AM
  #270
Registered Member
You're welcome Brandon. Glad things went flawlessly for you.
4CFDEG6 (04-25-2013)
Old 04-24-2013, 07:53 PM
  #271
lnfernopyro's Avatar
What is that light for without mod? I have an 04 TL but don't know how to turn them on.
Old 04-25-2013, 12:38 AM
  #272
5th Gear
4CFDEG6's Avatar
Thanks Machine! Going to ijdmtoys tomorrow to pick up a kit for my TL.
Old 04-26-2013, 08:44 PM
  #273
Mugen.Justice's Avatar
I am sold on this mod (going to be my first for the TL-S!)
Now the only question is...Xenon White or Ultra Blue? Lol.
Old 04-26-2013, 09:58 PM
  #274
vietxquangstah's Avatar
Neither. Grab the ijdmtoy harness only and go to VLEDs and buy the 10 XB 9005 LED rated @ 850 lumens. You can choose 5k or 6k.
here's a thread to the 6 XB led versions rated @ 725 lumens.
https://acurazine.com/forums/3g-tl-2004-2008-93/vleds-6-led-725-lumen-drl-9005-bulb-884617/
Old 04-27-2013, 11:28 AM
  #275
Desert Life Sucks!!
sauceja's Avatar
The thing you have to remember is with the iJDMtoy kit versus the ebay kit when it comes to the DRL's though is that the jdm kit comes with the resistor boxes inline.
That is what eliminates the drl indicator on the dash. The ebay "relay kit" does not have those resistor boxes.
Also if you have a bulb or both bulbs not working. Try switching them to the other side. Sometimes with LED's they only work on one side. Or flip them around like with the interior lights.
Old 04-27-2013, 11:29 AM
  #276
Desert Life Sucks!!
sauceja's Avatar
http://www.ebay.ca/itm/9005-HB3-LED-...d=473109915187
This looks like it may work but I have no experience. For the DRL
http://www.ebay.ca/itm/1x-Xenon-HID-...d=473111308227
This would be what you would purchase for the HID fog light kit.
Old 07-09-2013, 10:28 AM
  #277
JJH
JJH's Avatar
Having some trouble getting mine working. tested both bulbs and they are both good. My harness is different than the OPs as it already has everything inline and the harness is one piece (got mine from iJDMToy too).
Hooked everything up just as I did with my HID fog lights harness and it's not working.
Old 07-09-2013, 11:09 AM
  #278
JJH
JJH's Avatar
I just made a short video showing how I have everything hooked up. My kit (The R3 option from iJDMToy) is a little different than the ones that I have seen in this thread in that I already had the resistors inline rather than having to attach them to the harness. Hoping someone can look over this for me and see if anything sticks out that I could be doing wrong. I have no clue at this point.
Old 07-09-2013, 11:52 AM
  #279
JJH
JJH's Avatar
Spoke with iJDM about the issue and they said that because my resistors are not getting hot to the touch at all that it's likely an issue with the harness that they sent me. I have everything wired up correctly. He told me that they recently changed the design of everything for our harnesses because customers were modifying the old designs and voiding the warranty so they wanted to mitigate the possibility of that happening. I have to return my old unit and and they are going to send me a new one. Of course I have to buy a new unit and wait for it to be shipped from Cali to Ohio which sucks but nothing I can do.
Old 07-09-2013, 04:37 PM
  #280
mvp2765's Avatar
Just installed this last week. Every thing works perfect with no codes. My harness does look a bit different than the original tho
JJH (07-10-2013)
Quick Reply: iJDMtoy Led DRL Harness Install w/Pics
