How to install splash guards?
Old 10-28-2008, 08:37 PM
TL=True Love
wall e's Avatar
I got some OEM painted splash guards and i was wondering whats the easiest way to install them? Does it require any drilling? is it permanent or can i remove them if i don't like how they look? hopefully its still gives my car a sporty look.
Also, I like in Illinois and i was wondering if its illegal to not a have a front license plate cuz i do like that idea of painting that ACURA logo in the front bumper
Old 10-29-2008, 07:04 AM
vinnier6's Avatar
did you get directions or not...its pretty easy, i did mine in less then an hour...the rears would be easier taking off the wheels, but i did it without...there is no drilling or cutting...screws that already exist are taking out and the splash guard is put into place and screws put back in...the back ones comes with a metal bracket that goes in place and then some extra screws come with to put into the bracket...its really quite easy...let me know if you run into some trouble...i believe there is a link somehwere here that gives oem options installs and directions....check the 3 g garage...
Old 10-29-2008, 07:12 AM
mrlobaloba's Avatar
This page has helped me a bunch of times
https://acurazine.com/forums/showpos...96&postcount=1
Old 10-29-2008, 07:49 AM
ROFLCOPTER!
xen-cuts's Avatar
How much do painted splashguards cost from the dealer???
Old 10-29-2008, 08:02 AM
vinnier6's Avatar
i dont know how much they cost at the dealer, but you can get them from an acura dealer on ebay for about 100 bucks....thats painted oem....
Old 10-29-2008, 09:29 AM
mrlobaloba's Avatar
Also just a note but Splash guards do not work with A-spec side skirts
Old 10-29-2008, 09:55 AM
TL=True Love
wall e's Avatar
thx
Old 10-29-2008, 11:59 AM
ChicagoBurbs's Avatar
I did mine in under an hour too...I did not remove any wheels, but had to use an offset screwdriver to mount the screws on the rears. They go on real easy and fit great using all existing holes. They'll come off real easy too, but you may get some rubbing under them that will require a buff-out if you do remove them after time. So if you don't like them I don't think you should leave them on over the winter...get em off quick.
Old 10-29-2008, 12:14 PM
Jesstzn's Avatar
I solved the rubbing problem on mine .. I only run them for winter and what I did front & back was hold them up against the car and used a dry erase marker to outline the mud flap + 1/8 " .. then I applied a strip of black electrical tape up to that line then installed them.
In the spring when I remove the mud flaps all the scuffing that does happen is on the tape. Just a bit of heat from a hair dryer and the tape comes off with little to no residue left.
If you have a dark colored car and run them year round I'd advise doing that too .. with just 1/16 to 1/8" exposed you don't notice it.
D.
BTW here is a link to the DIY install
https://hondacuraworld.hostasaurus.c...lashguards.pdf
Old 10-29-2008, 12:19 PM
CTS-V Import Slayer
MichaelBenz's Avatar
#1 - Are you "like" in Illinois....or are you actually in Illinois? j/k
#2 - If your state runs front plates...yes its illegal
#3 - You can buy a CF or other type decal on ebay that will fill in that ACURA on the front bumper...no need to paint. They are die cut exactly.
Old 10-29-2008, 01:22 PM
ROFLCOPTER!
xen-cuts's Avatar
You could use rho plate mounting and keep both the front plate and color the acura logo.
Old 10-29-2008, 08:39 PM
ROFLCOPTER!
xen-cuts's Avatar
For painted splash guards to go on a 2005 without trim, should I purchase the painted 2007-2008 guards? http://www.hondacuraworld.com/Mercha...egory_Code=ATL
Old 10-31-2008, 04:48 PM
ikm19's Avatar
Does TL or type s spash guards have any difference ?
Old 10-31-2008, 05:21 PM
vinnier6's Avatar
yes, there is a difference...make sure you get the ones specific for the type s....i got mine on ebay...100 bucks
Old 10-31-2008, 06:18 PM
TL=True Love
wall e's Avatar
i love ebay! the acura dealer was trying to charge me 200$ for splash guards which includes installation, but thx to eBay i paid half and ill install it myself. ill be sure to post pix
Old 11-01-2008, 08:00 AM
Randy B's Avatar
I have the instructions for a 2008
However, I cannot seem to figure out how to upload them for you.
Randy B
Old 11-22-2008, 05:12 PM
iloveTL's Avatar
does the painted splash guards fit in 04 TLs?
Old 11-23-2008, 12:49 AM
usc
usc's Avatar
I don't see why not. Just make sure you don't get the TL-S splash guards.
Old 11-23-2008, 03:32 PM
iloveTL's Avatar
tim from hondaacuraworld told me that painted splash guards dont fit in 04 TLs
Old 12-02-2008, 06:57 PM
FiveShifts's Avatar
got my painted splash guards online from curryacura.com only took about 3 days & $105 incl shipping. it's pretty obvious how they fit once you hold them up to the lower fender well.
might as well take the rear wheels off- good time to check brake pads and look around for signs of trouble with suspension pieces. also gives you a chance to dab some lithium grease or other lube on the rotor hubs and mounting thread. if you live in areas that salt roads in the winter it helps prevent rims from "welding" themselves to the rotor.
Old 05-16-2016, 08:11 AM
Michael Hinchey's Avatar
I bought some OEM splash guards that are black but not to my car color which is nighthawk bp. Has anyone painted these? How did they look regularly just black and how much of a difference are they when u paint them to the color.? Thx
Old 05-26-2016, 06:30 AM
Bump
Old 05-26-2016, 06:33 AM
Received 8,568 Likes on 6,621 Posts
Why don't you just install them to see "how they would look"?
Old 05-26-2016, 04:04 PM
GOOSEej's Avatar
Ive installed both TL and TLS splash guards.. They dont require and drilling from what i remember. You can take them off if you dont like them. Thats if you have all the hardware that they need to be installed.
To make the installation easier to the rear you will have to remove the wheels. The front you can just turn the the wheels fully left and right
Old 05-27-2016, 09:08 PM
Unfortunately I don't have all the hardware. I didn't think it would be this difficult to get the brackets for the rear and the other hardware.
Old 05-27-2016, 09:10 PM
Do u think that didn't cross my mind? I was hoping for some insight before I go painting them and then liking the original color.
Old 06-05-2016, 09:34 AM
I am having a difficult time finding hardware only for the splash guards I bought on £ bay. Can anyone direct me or is the junk yards the only place?
Old 06-05-2016, 01:18 PM
GOOSEej's Avatar
SPLASH GUARDS (1) for 2008 Acura TL
but not the actual brackets
Old 06-05-2016, 03:27 PM
Well it's a good start. Thank you. I was looking to get those brackets. Otherwise getting these cheap on ebay.
le^2
02-18-2021 10:44 PM
09-17-2015 09:01 PM
TxRzrBk
09-17-2015 01:07 PM
d.lim
09-15-2015 08:54 PM
EE4Life
09-11-2015 10:13 PM
Quick Reply: How to install splash guards?
