How do you change back lights.
Check in section G : https://acurazine.com/forums/third-g...ewbies-553554/
I believe you have to change out the LED board if you want them all to work. To get to it you have to take the rear bumper off to get to the 2 bolts holding in the tail lights. Or just disconect it enough to where you can access the bolts. Then the tail light is held in place by 3-4 smaller bolts, once off the LED board is held by 4 small screws, and a connector. It's a little bit of work but relatively easy.
nanos
11-12-2015 08:41 PM
