Gas leak
Old 02-16-2017, 07:32 PM
Aralyn21's Avatar
Gas leak
Going down the interstate & something busted my gas tank. It's a small hole.. what can I get to seal it good ? Or how much would I be looking at replacing it?
Old 02-17-2017, 06:50 AM
iWhine S/C 6MT TL
04WDPSeDaN's Avatar
Received 2,563 Likes on 1,317 Posts
Back in the day when I started in the automotive field, I worked in a shop that had a lot of classic's. All of which had steel gas tanks, which we fixed the rust and sealed them. Today, we no longer use metal gas tanks use now use high-density polyethylene gas tanks. Can you use some sort of WB-Weld or plastic weld? Maybe, but I highly doubt it. See back in the days we didn't have Ethanol mixed with gasoline, so not sure if that has any role in trying to fix the tank. The best solution, which also gives you peace of mind that you won't encounter a leak if one of those plastic weld kit breaks, is a new gas tank. Keep in mind, the fuel system on today's vehicles are pressurized so a weld might not hold up. Also driving will cause the tank to vibrate so that doesn't help much either.
You can buy a new OEM tank for $287.56, Not a bad price at all for a tank.
Link is here:
TANK, FUEL for 2004 Acura TL SEDAN|17044-SEP-A00 : Acura Parts | OEM Acura Parts | Factory Acura Parts
Just make sure you reset the inputs, YEAR and MODEL. I have it as 04 with a 6MT,
Old 02-17-2017, 08:01 AM
Turbonut's Avatar
Actually all 3G tanks are the same.
Depending on your area, used tanks can be had for $25 up.
Old 02-17-2017, 07:38 PM
GreenSpades's Avatar
Wel apparently "FLEX SEAL" can build an entire airboat so why dontcha try that.
