G-029: DIY Independent Fog Lights WITH Stock Switch
Old 05-08-2010, 10:08 AM
  #81
dadon's Avatar
going to check that green wire, and fuses
if not ill connect everything the way it was :-(
Old 05-08-2010, 10:32 AM
  #82
dadon's Avatar
I checked the main fuse box didnt see any blown fuses, on the green wire I am not getting a 12v read. Getting no more then 2.9v
I did everything the way you said except on part 2 after you connect the blue/white wire to plug it back in, I waited to i had everything connected
dont know if by doing that i blew something, if so I def, want to know where to look at
man i knew it was to good to be true, everything was fine didnt break nothing found the firewll hole quick daaaaaaaaaaaaaaaaaaamn:wh yme:
Old 05-08-2010, 10:59 AM
  #83
Joe Foe from Buffalo's Avatar
If this helps...I fix stuff for a living. When I found I did some thing wrong and can't figure it out and not much help from others...I found if i walk away from the problem for a bit and come back to starting from step one on how to do it like I never did it in the first time helps. Also from what you saying it sounds like you have a short of some sort ...so you really need to verify you did every thing proper. My guess is you taped in the wrong wire. Stressing about only makes it worse so try not to stress and think you can figure it out.....it's not brain surgery is what I tell my self and I'm smart enough to figure my problem out.
Old 05-08-2010, 11:10 AM
  #84
dadon's Avatar
thanks, as you see in the pics though its exactly how the instructions said, i didnt make no other connection, do you think a scan can tell me if i blew a relay or something?
Old 05-08-2010, 11:18 AM
  #85
Just unistall every thing and put it back the way it was and see if every thing works the way it use to and start over if you need to.
Old 05-08-2010, 11:53 AM
  #86
dadon's Avatar
just cut the wires i had, vsa lights dont come on when i turn the fog ligts on, im at work and didnt bring all my tools, so im going to wait until 5 when i get home.
i wonder if the wiring is different on my car...it should be the same.
Old 05-08-2010, 12:13 PM
  #87
OCD
Roger555's Avatar
wiring should be the same I have an 2006 also. Check and see if there are any other Green wires in that harness because there should be 12V running through that wire with the keys turned in the ignition.
Old 05-08-2010, 02:16 PM
  #88
dadon's Avatar
there is no other green wire, funny thing is the fog light should be on?
its not.
when i get home i will plug everything back
hopefully the combo switch is not bad, i doubt it cause parking lights and all work just fine and its not that expensive
i sat down read your post 10 times over and over, even have it printed out pictures and all, i still cant figure where i went wrong.
Old 05-08-2010, 04:44 PM
  #89
dadon's Avatar
ok I got home and the problem is the green wire
its not giving me 12v so the fog lights will now power up with 2.8v
is there another ACC cable i can run it to, if I put it straight to 12v line
Ill be able to power on the fog lights while the car is off
and my wife drives the car sometimes and I know she will leave it on and come back to a dead bat. or even me half sleep going to work.
i might try the acc wire on the ignition switch and run a second wire through the fw out to the engine bay.
Old 05-08-2010, 06:16 PM
  #90
dadon's Avatar
DONE
THANKS TO ALL THAT HELP.
I USED THIS GREEN ONE THAT HAD 12V
PROPS TO bhelsdon, I LOOKED AT HIS THREAD.
THATS IT OFF TO WASH MY BABY
The following 2 users liked this post by dadon:
350 (07-20-2013), Undying Dreams (03-20-2013)
Old 05-13-2010, 07:30 PM
  #91
RIP RBP
upnout's Avatar
Thanx Roger555, I got mine half way hooked up. Just hooked up the first wire from the control switch to the relay fuse box. They light up on que. Tomorrow I'll finish it! Yeah dadon, I had a time finding the green wire (power)
Old 05-14-2010, 05:38 PM
  #92
6-SPEED LOVER
ABP_04TL's Avatar
Roger... Thnx a lot for the DIY just did mine earlier today... Everythin came out perfect. Thnx bro
Old 05-14-2010, 10:06 PM
  #93
CARBON FIBER WDP TL
poormans_tl69's Avatar
wow you are my money saver today... was going to buy the drl module but it seem lke its cheaper to..
Old 05-15-2010, 01:37 PM
  #94
In step 2 do we use the light blue/white wire or the dark blue/white wire in 2005's? I guessed it should be light blue/white....but may be wrong cause I have it on light blue/white and my fogs do not work.
Old 05-15-2010, 03:12 PM
  #95
Also in step 2 it says "Cut the blue/white wire and connect the switch side of the wire to your thinner gauge extension wire" But in the pictures it looks like it is connected to the wire harness going away from the connection/switch. So do we connect to the wire going in to the connection or the one going away?
Old 05-15-2010, 04:31 PM
  #96
OCD
Roger555's Avatar
Mine was Dark blue
You connect to the blue/white wire going away from the connector which goes to the switch
Old 05-15-2010, 06:46 PM
  #97
LOL No wonder mine doesn't work. Thank you, I'll fix my guess on the light blue/white wire to the bark blue/white wire tomorrow.
Old 05-15-2010, 07:33 PM
  #98
OCD
Roger555's Avatar
good luck let me know if you have any more issues
Old 05-16-2010, 12:38 AM
  #99
4th Gear
Valentinik46's Avatar
Great DIY!!
Old 05-16-2010, 02:11 PM
  #100
King of NYC
rockyfeller's Avatar
GREAT DIY!!! Bout time someone posted this up. I get questions about this all the time and I just direct people to bheldson's thread. It has to be better to have independent control though....and no messin with relays....I have to do this now.
I have the DRL module since 2006 but I can't tell you how many times I have wired and rewired this damn thing and it is out again. It is always a problem with a connection or the module itself. I am on my 5th module. Thank God the company is good about it and always gives me a new one under warranty.
Now I am thinkin about puttin in HIDs (and you can't do that with a DRL module) I'm lookin into doing things this way once and for all. It seems easy to screw up things with the wiring but I am going to go slow, plan ahead and use a voltmeter. Thanks!!!
Old 05-16-2010, 09:32 PM
  #101
I fixed my mistake and works perfect. Thank you Roger555. May want to add it's the dark blue/white wire. I must be a little color blind cause the pictures to me look like it may be the light blue/white.
I did some thing a little different others may want to do. Instead of hacking in to the wire harness in step six for the accessory power green wire that powers the windshield wipers, instead I ran the blue/red wire in step five that I attached the thicker gauge wire to the relay wire threw the fire wall and used this in line fuse holder that has a nice LED to show if the fuse is blown (that I have a 7.5 amp fuse in and works)
http://www.radioshack.com/product/in...ductId=3150583
and soldered a fuse tap to it like this one
http://www.connectorsupply.com/catal...use-p-617.html
then plugged the tap in to the inside/under dash fuse box at location #22 that is open/not used and get power only when car is running.
Old 05-20-2010, 09:32 AM
  #102
Alexsm's Avatar
Welcome everyone
Roger great post ,i want to ask u a question:
I want to have my foglights turned on all the time like canadian DRL even when foglight switch is off ,controlled only by ignition key is the any way to do it ? like connect some wires in the switch?
don't want to install DRL modul just some quick connction
Thanx so much
Old 05-20-2010, 04:36 PM
  #103
OCD
Roger555's Avatar
Originally Posted by Alexsm
Welcome everyone
Thanx so much
you can just ground the wire going to the switch and it will work like you describe but I don't understand why its an issue to leave the switch on?
Old 05-23-2010, 01:11 AM
  #104
King of NYC
Thanks to Roger I finished this mod today. There is no reason to chicken out here guys. If you are careful enough you are not going to screw up the wiring on the car. This can be considered a simple 2 wire hookup. It's not overly complicated, it just seems that way. Just follow the directions as stated. For those of you considering this as an option to use these as DRLs, here are some pros and cons to doing the DesignTech module compared to the Independent OEM switch control:
Designtech Module pros:
4/10 in terms of difficulty of install.
Works in DRL mode 80% power instead of 100%.
Has a delayed shutoff circuit.
Retains OEM functionality once the headlights are turned on with 100% power.
Dashboard fog pilot light functional.
Easy to reverse the mod to OEM.
DesignTech Module cons:
Works automatically, no independent control.
Costs more.
Module is not all that reliable.
Cannot use it with an aftermarket HID kit without additional wiring.
Independent OEM switch control pros:
Complete independent control. On or off at any phase as long as the ignition is on.
Use of the OEM switch, clean OEM appearance.
Cheaper.
No additional relay needed.
Turns on and off with ignition.
Can use in conjunction with an aftermarket HID kit.
Independent OEM switch control cons:
6/10 in terms of difficulty of install.
Installation is more complicated, wiring access is tricky.
Works only with 100% power.
Dashboard fog pilot light non-functional.
Difficult to reverse the mod to OEM.
No delayed shut-off.
Stop thinking about it. Go out and do it!
Old 05-23-2010, 11:56 AM
  #105
craigtl35's Avatar
so who has done this with an 05 tl? any difference in wires, colors etc.?
Old 05-23-2010, 03:22 PM
  #106
What parts of this subject did you read and not read? I for one clearly said I did it on my 2005.
Old 05-23-2010, 04:50 PM
  #107
05 NBP
images's Avatar
completed it last week, 05 tl, no problems
Old 05-23-2010, 10:02 PM
  #108
Former Sponsor
AckTL05's Avatar
Just blacked out some headlights and put LED strips in, then did some custom fog lights with the type s bezel and did this fog switch trick. I think this was the best DIY I have done yet. Took about 30-45 minutes. The hardest part was working in the engine bay tapping into the relay.
casty (06-01-2012)
Old 05-25-2010, 06:42 AM
  #109
Veni, vidi, vici
Bayam0n's Avatar
I couldn't find a 10a inline fuse. at home depot or at autozone. can you show a pic of this so I know what it looks like. thanx.
Old 05-25-2010, 08:31 AM
  #110
Did you check the link I posted for one?
Old 05-25-2010, 09:27 AM
  #111
Veni, vidi, vici
Bayam0n's Avatar
I can't find a 10a inline fuse. is 15a good?
N/M
Old 05-25-2010, 11:27 AM
  #112
Former Sponsor
AckTL05's Avatar
http://www.newegg.com/Product/Produc...ble-_-82155349
Then just buy a 10 fuse.
Old 05-25-2010, 08:24 PM
  #113
Veni, vidi, vici
Bayam0n's Avatar
I found the 10a inline fuse holder and everything. But when I tried to wire it to the green wire, it doesn't work and there are two green wires and none of them worked.
Old 05-25-2010, 10:48 PM
  #114
RIP RBP
upnout's Avatar
Originally Posted by dadon
DONE
Use this green wire with 12V with ignition ON. should only be one green, white, yellow, and blue wire. look closely, find the wire pictured.
Old 05-26-2010, 12:18 AM
  #115
ScoobyZINE
AMUA6's Avatar
Ah now I see where I screwed up and ended up blowing my light combo switch in the car. Haha, I did the same as Joe Foe and taped the light blue wire instead of the dark blue, needless to say. I won't be attempting this again for awhile lol Acura raped mi wallet on this one.
Old 05-31-2010, 09:40 AM
  #116
6th Gear
fun4us's Avatar
great diy! thanks
Old 06-14-2010, 04:16 PM
  #117
ScoobyZINE
AMUA6's Avatar
Well I believe when I get off of work this evening, I will be attempting this mod once again. BUT, with the battery disconnected!
Old 06-15-2010, 12:34 AM
  #118
ScoobyZINE
AMUA6's Avatar
Well I have everything hooked up exactly like it should be and nothing.. Now what?
Old 06-15-2010, 12:49 AM
  #119
Former Sponsor
AckTL05's Avatar
I did this and it works perfect. Did you plug everything back in? Description was a little confusing but pictures explained A LOT.
Old 06-15-2010, 12:51 AM
  #120
ScoobyZINE
AMUA6's Avatar
I did. I have secured all the wire connections yet because I'm waiting to make sure they'll work. I even tried using the "light blue/white wire" off of the switch instead of the dark blue. I used a 16 gauge wire off of the switch to the relay.
Quick Reply: G-029: DIY Independent Fog Lights WITH Stock Switch
