Found a new feature in the TL
Old 10-12-2015, 07:15 PM
Life Connoisseur
MonkeyTrucker's Avatar
So, learned something recently that appears to be a hidden feature not explained within the owner's manual (2006).
I un-clipped my sun visor and it began to slide off, like it was coming off the arm / rod it's inserted over. Thought, "great, another item to buy." Then I realized it kinda hit a stop after it was extended a bit, then I tried it on the passenger sun visor.
Had no idea the sun visors extended to cover more sun, could've used this feature many days in the past ...
I had to pull on the passenger sun visor a bit to un-stick itself from apparently this feature never being used for nearly 10 years.
Honestly, how many of you guys knew this feature existed, it certainly wasn't an apparent feature for the owners.
Search for "sun" or "visors" in your owner's manual...zilch info about this feature.
File Type: pdf
The following 2 users liked this post by MonkeyTrucker:
EvilVirus (10-13-2015), HOWELLiNC (10-13-2015)
Old 10-12-2015, 08:12 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Yep, we actually used to have a thread with all the cool features of the TL. This was one of them-glad you found it.
Old 10-12-2015, 09:18 PM
flyromeo3's Avatar
Had no clue.
Thanks for sharing.
Old 10-12-2015, 09:20 PM
Christine Selzer's Avatar
How do I make a new post?
Old 10-12-2015, 09:24 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Yep not really new but thanks for the reminder.
Old 10-12-2015, 09:27 PM
IBankMouse's Avatar
Originally Posted by flyromeo3
Had no clue.
Thanks for sharing.
X2.
I can't even begin to think how many times the sun just sneaks to the left of the visor when I have it on the driver's side window.
Old 10-12-2015, 10:12 PM
dezymond's Avatar
One of the first features I accidentally found out when I test drove the car. Meant to pull it, but somehow ended up pulling it out to extend too.
And I can't even begin to tell you how many times I tried putting it back while it was extended and hit myself in the head....
Old 10-13-2015, 12:01 AM
rexflexall's Avatar
Ha! Thanks!
Old 10-13-2015, 07:36 AM
ggesq's Avatar
Received 2,181 Likes on 1,210 Posts
It's in the 3G "Garage"
https://acurazine.com/forums/third-g...-001-a-540216/
The following 3 users liked this post by ggesq:
Azonics (10-15-2015), EvilVirus (10-13-2015), Indy04TL (10-13-2015)
Old 10-13-2015, 07:45 AM
Received 16,260 Likes on 11,971 Posts
All Honda's have this feature.
okay, most of them.
it started in the accords
Old 10-13-2015, 09:35 AM
Jboat's Avatar
On a similar note, I accidentally discovered the storage compartment on the driver's side door extends outward for larger items. At first I thought I broke it, then I thought that's a neat little feature...
Old 10-13-2015, 11:13 AM
EvilVirus's Avatar
^So does the passenger side
Old 10-13-2015, 11:21 AM
this applies to sun visor too.
Old 10-13-2015, 11:41 AM
KevinK15's Avatar
I just found out the side mirrors tilt down in reverse when you leave the switch on left or right. I usually adjust my mirrors and then place the switch to the centre position afterwards.
Old 10-13-2015, 07:53 PM
Jason
HOWELLiNC's Avatar
I do the same thing. Mine's an 04 and Ive noticed that if I accidentally push the 1 memory setting more than once my driver side mirror does some kind of weird reverb thing where its assumably trying to get to the set position over and over again. Although this feature sound great, and I love finding new things about my TL, think I'll just leave them where they are lol
Old 10-13-2015, 08:37 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
TL also has a feature that driver door auto close.
Old 10-13-2015, 09:19 PM
Life Connoisseur
Is that feature called your mom?
I swear, some of you guys...
Old 10-13-2015, 09:21 PM
ff4930's Avatar
huh? I thought truonghthe was just poking fun at the TL's heavy door that it always try to slam shut no matter how wide you open the door.
Anyways, great find OP. Never thought that extends.
Old 10-13-2015, 10:17 PM
truonghthe's Avatar
yes, that what I mean, I am not sure why he said "your mom"
Old 10-13-2015, 11:34 PM
Life Connoisseur
A little context could've went a long way. I've never felt as if my driver's door was going to close automatically.
I had an Accord that developed a broken door catch and it would close at will.
Is yours broken?
Apologies
Old 10-14-2015, 01:49 AM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
My wife complains all the time about the automatic closing door. I like to time it so I never have to push it shut. It's because the door is heavy and the notches in the door link aren't that pronounced so it tends to shut if the door isn't held just right when opening it
justnspace had a thread if I remember on how to eliminate its tendency to shut easily. This isn't a feature but just a bad design.
That thread linked above is super helpful to anyone that is new to the car! I remember looking at it way back and loved finding those features
The following 2 users liked this post by sockr1:
EvilVirus (10-14-2015), justnspace (10-14-2015)
Old 10-14-2015, 07:06 AM
Monkeytrucker, by design the doors have an easy close feature.
there are two resting points for the door, a narrow opening and a wide opening.
if the door does not rest at either of these two points, the door will close.
this is due to the "door checker"
BY design:
IMG_1313-2.jpg?t=1280172858
we've found that you can replace the TL's door checker with an Accord's.
IMG_1316-1.jpg?t=1280173005
Accord VS TL
IMG_1319-1.jpg?t=1280173118
Accord Checker installed:
IMG_1321-1.jpg?t=1280173201
I havent done it myself, but others say that it resolves the issue of it closing on you, as it doesnt rely on those 2 resting points I talked about earlier.
Old 10-14-2015, 07:20 AM
Received 8,582 Likes on 6,629 Posts
Girlfriend hates the automatic door closing feature..
So i fired our chauffeur...
Old 10-14-2015, 12:30 PM
Life Connoisseur
Yeah, I said I replaced one of those on an Accord. I've never felt that the TL door was going to close on me though, if it were to do that on me, I'd replace the same part I replaced in the Accord, the "catch" similar to the image you posted.
Old 10-14-2015, 12:34 PM
^so, what most are referring to, is that they dont "catch" the door on the resting points and the door closes on their legs.
so, if this doesnt apply to you or you've learned to overcome the TL's self closing door feature, please disregard
Old 10-14-2015, 03:05 PM
2006 NBP TL MT6/ 02TL-S
AlanW's Avatar
The ever self-closing trunk lid that tries to take your head off at the slightest breeze.
Old 10-14-2015, 03:19 PM
sockr1's Avatar
try adding a bunch of sound deadener to it...it almost chopped off my head once when i parked on an incline! but that would have been worth it for my improved bass haha
Old 10-17-2015, 10:58 AM
LoneRonin's Avatar
mine is kind of loose, if someone slams the door a little too hard it pops open. Its very annoying...any ideas on how I can tighten the latch or something?
Old 10-17-2015, 11:36 AM
Jeff
Oh Sickest TL's Avatar
rexflexall
10-20-2015 09:36 AM
adreano17
10-13-2015 01:11 PM
Joe Avesyan
10-12-2015 07:56 PM
Microfiche
10-07-2015 09:14 PM
Bassam78
10-06-2015 01:53 PM
Quick Reply: Found a new feature in the TL
