Exhaust bolts
Old 04-26-2015, 11:43 AM
Jeff
Oh Sickest TL's Avatar
Exhaust bolts
I need the exhaust bolts that go from the xlr8 j pipe to the cat back and also need the bolts that go from the bottom of pre cats to the 2 ends of the j pipe..
are those bolts #16?? in the link
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
but what about the 3 other bolts and nut that go from the xlr8 j pipe to the catback.. would that be #3 and #22
thanks boys
going to be installing the xlr8 system here soon but it only came with 2bolts and 2 nuts, the other one fell out of the package
Old 04-26-2015, 01:48 PM
Jeff
anyone know lol?
Old 04-26-2015, 02:02 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
forget buying those nuts and bolts from the dealer, they charged me over 20$ for the same bolts i saw at the auto parts store for much cheaper
You are correct with the part numbers, though.
#16 you won't need unless you snap the stud off your precat. It's like the studs on your hub, no need to replace unless broken when removing the lug, in your case, nut.
Oh Sickest TL (04-26-2015)
Old 04-26-2015, 02:05 PM
Jeff
thanks! I just figured they are prob rusted and seized badly so wanted to make life easier on the mechanic lol
Old 04-26-2015, 02:15 PM
Expect them to be seized and rusted
If your car was like mine, your mechanic will have to use a "damaged/rounded bolt remover" socket for the precat to jpipe nuts. That will destroy them, but at least you'll be able to get them off and replace with new nuts. The studs are fine on the pre-cat.
As for the jpipe to catback bolts, mine weren't even bolts anymore.
Just pure chunk of rust.
Oxy acetylene torch + hammer with chisel broke them off.
Old 04-26-2015, 02:18 PM
Jeff
lol yea god damn canada.. so in those links provided what will I need.... 9 of the #22's 3 of #3 ?
Old 04-26-2015, 02:26 PM
Correct.
Old 04-26-2015, 02:29 PM
Jeff
you da man GP.
EDIT: this is for the xlr8 system so i won't have the 3rd cat, does that matter in terms of the bolts? 10 bucks for a bolt tho? LOL wtf
Old 04-26-2015, 02:42 PM
I installed my RV6 V3 (no 3rd cat) using the exact same hardware.
Old 04-26-2015, 02:43 PM
Jeff
thnks man.. i need to get the grill mesh for my front bumper so ill just put this order in using delray I guess
tsx_boy
12-13-2019 08:33 PM
neuronbob
23
07-16-2019 10:48 AM
Charles Bennett
01-28-2018 08:53 PM
joflewbyu2
10-08-2015 11:16 AM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Exhaust bolts
