DIY installation of Daytime Running Lights**with detailed pictures** 3G Garage #G-067
Old 05-11-2009, 12:53 AM
  #201
DMZ
Head a da Family
DMZ's Avatar
I had mine installed by someone well experienced in auto electric using the write-up at the beginning of this thread. I went his way because of the difficulty in getting to the harness blocked by the clutch reservoir. I just substituted a better fuse holder than the piece of crap that comes with it to avoid future problems. 4 months so far and it works great!
As I also have the single piece chrome strips across the centers of the 2 lower grilles, I wonder how many TL drivers coming the other way think they're seeing an '07/8.
Old 05-11-2009, 07:13 AM
  #202
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Hmmm...mine is on it's way...I hope I have the same luck installing it!
I also ordered some Honda dielectric grease to keep all connections corrosion free and free flowing.
Old 05-11-2009, 09:23 PM
  #203
I have a question...just to check for understanding. Is it 1 only done on 1 side?!
Also, anyone open the module to cut the wire to NOT have the delay? I don't really want it staying on after I turn off the car. AND...can it be set up to NOT come on with parking ligths...I'd rather not have the DRL's cause I have installed bumper fogs that come on w/the parking lights and I don't want the DRL's to be on too.
Old 05-12-2009, 11:29 AM
  #204
bhelsdon's Avatar
It only gets hooked to the one side and yes you can have them go off when the parking lights come on. Instead of hooking the wire to the ballast connector run it to the hot side of the parking light. Make sure you choose the hot side of the parking light and not the turn signal. you can use a simple test light for this.
Old 05-13-2009, 02:29 PM
  #205
Thank you...I would imagine it would be the colored of the two wires on the parking light? I think they all have a black and colored one from factory and I assume the black is negative.
Thank you very much. That's what I will do because I don't need em unless I have everything OFF!
Old 05-14-2009, 09:28 PM
  #206
Note to all...
wiring to the parking light DOES NOT WORK to get the DRL's to turn off with the parking lights. In fact...it messes it up and makes it NOT turn off the DRL's with the low beams unless you turn on the stalk fogs.
Wire it to the ballast low beam wire, like the OP advised. That makes it work properly.
That said...I put some nokya yellows for DRL's and it looks effin mean!
Old 06-04-2009, 08:52 AM
  #207
Anyone have a CONFIRMED way of taking away the delay to come on and off from the DRL module since they now moved the wire into the unit?
PLEASE!??
Old 05-01-2010, 10:10 PM
  #208
louisville88's Avatar
Excellent! I cant seem to find the item online. Can some one post a link?
Old 08-17-2010, 06:41 AM
  #209
neiderlander's Avatar
Does this work on a 2004 RSX-S or are there any differences in the installation?
Old 08-25-2010, 11:53 PM
  #210
that ONE RED tl
DimwitRj's Avatar
PLEASE!??
You can pop the unit open, the box is just pressure fitted together with no glue or anything. Atleast mine is.
Had mine for awhile now and the only problem I've found with it was that on a recent trip to Vegas in 110+ degree weather, long hours on the highway.. the unit was probably overheating causing the DRLs to dim and finally turn off. Turning my headlights on then off would turn the DRLs back on for a while again.
Old 08-26-2010, 06:49 AM
  #211
YES, I've experienced that as well, plus, when a battery I had leaked acid onto the unit/wiring, it corroded the fuse holder. Fixed that and it's been better, although when it's SUPER hot under the hood it does turn them off eventually.
About the delay, it's funny, when you come back to thread months later...you sometimes think "was that really a concern for me?!"...lol....I have had them stay on for 20 seconds after every time and never killed my battery so I'm good.
Old 12-10-2010, 11:47 PM
  #212
B A N N E D
odehboy's Avatar
Bump?
Old 12-13-2010, 01:20 PM
  #213
butnin's Avatar
why go through the hassel, just buy a canadian TL model, it comes with DRL
Old 12-13-2010, 05:39 PM
  #214
^^^I think that would be more money, ehhh?
Old 12-13-2010, 06:41 PM
  #215
MasterShake's Avatar
I couldn't find the DesignTech DRL module Model # 20013 the OP used and so I had to look for a different one.
I'm using a Grote 44040:
http://www.grote.com/product.php?product_number=44040
The install was pretty much the same as the OP except with different wire colors.
I paid about $30 for one shipped and from what I can tell, it doesn't use low power for the DRL.
Old 12-17-2010, 11:28 AM
  #216
DMZ
Head a da Family
DMZ's Avatar
Exclamation Bad news
This DRL module has been discontinued!
The link to where you could have bought it in my signature no longer works and the company that made them for Designtech,, Hopkins Manufacturing in Kansas City says marketing decided to pull the plug for no explained reason.
So, if you have a 2004,5, or 6 TL and want to convert your fogs to DRL's, you're going to have to look elsewhere, but I'd look for one that lights the fogs up at 75% intensity, or thereabouts.
Old 12-19-2010, 05:48 PM
  #217
UA7 6MT
TmaX's Avatar
Wondering for those of us Canadian's who have the DRL's have been able to find a way to increase the output of the bulbs as if I'm not mistaken they only output at 30-50 % of their regular capacity. Make them more visible when being used when the HID's are not being used in the daytime.
Old 03-11-2011, 10:56 AM
  #218
money5577's Avatar
Module no longer working
I know no one has posted for some time, but my module has stopped working after about 8 months of use. I had an auto shop do the installation does anyone have any troubleshooting tips before I take it back to the shop?
Old 03-12-2011, 11:59 AM
  #219
slcxow's Avatar
Awesome, one of many DIY coming this spring! Thanks!
Old 03-12-2011, 12:45 PM
  #220
Check the fuse from the battery to module. then check the signal wires...if they were ttapped then check the taps.
If module gets super hot I've noticed it shuts off.
Old 03-12-2011, 02:50 PM
  #221
King of NYC
rockyfeller's Avatar
I was a big fan of this mod as seen on previous pages but the module has NOT stood the test of time. I have gone through 4-5 faulty modules. They tend to go bad by 8-12 months.
I went with the new method of rewiring the fogs as DRLs directly as shown in the new thread by Roger. I recommend it to everyone as an alternative because your fog light switch can actively turn it on and off independent of the headlights. Looks like a tricky mod but it really isn't. I have yellow 3000K HIDs hooked up to it (which you can't do without additional rejigging with the DesignTech) and so far it has proven to be much more problem free. It really seems as if the car is stock and came that way.
Old 03-12-2011, 07:59 PM
  #222
raf1919's Avatar
dumb question.. what does it do? is this this to disable DRL
Old 03-13-2011, 01:00 AM
  #223
It is to GIVE the older Acuras DRL's, which they didn't have.
I might be nuts, but going on almost 2 years with no issues with my module. They stopped selling them so I'm guessing it was a widespread problem.
Old 03-13-2011, 07:08 AM
  #224
vicgreen19142's Avatar
Hey rockstar143 post a link to the DIY on how to get it done without the module.. I actually bought one about 2 years ago, I did installed it but it went bad only after 2 months. I would have try to return it or exchange it before it was discontinued but I was a little busy with school and work...
Old 04-27-2011, 09:04 AM
  #225
money5577's Avatar
It's official, my designtech went bad. Has anyone replaced their broken designtech module with the Hamsar? If so what model do I need and is it a direct replacement?
Old 04-27-2011, 09:21 AM
  #226
Sollly's Avatar
I installed a Grote 44040 and it works great. Buy on amazon.
Old 04-27-2011, 01:53 PM
  #227
UA6 SSM TL
24no7's Avatar
^ Did you do the installation? if so, how difficult was it?? is this the module you got? btw do the foglights go off when the HID's are on??
Old 04-27-2011, 01:56 PM
  #228
UA6 SSM TL
24no7's Avatar
I like roger's way but i want the foglights to go off whenever the HID's come on.
Old 04-27-2011, 02:45 PM
  #229
Sollly's Avatar
Install was easy. Follow Faq and adjust wiring accordingly.
Old 04-27-2011, 02:46 PM
  #230
Just getting back to this thread, nice to see there is another option if/when it goes bad. Sorry, i don't know any way to wire without module that I can point you to.
Old 04-27-2011, 02:51 PM
  #231
Bone stock tl-s
jptl04's Avatar
Sollly, lets try that again
Old 04-27-2011, 07:31 PM
  #232
6SPEED FEVER
EATSLEEPRACE's Avatar
If anyone wants a cheaper version on how to get day time running lights ....check my thread I believe it's et521 only like 12bucks.......
Old 04-27-2011, 07:47 PM
  #233
UA6 SSM TL
24no7's Avatar
is there any link?? im too lazy to look lol
Old 04-27-2011, 10:39 PM
  #234
DMZ
Head a da Family
DMZ's Avatar
Does it light the fogs at 75% brightness like the one from Autobarn did?
Old 04-27-2011, 11:02 PM
  #235
Sollly's Avatar
Yes. unless you want them on, then just turn the fog switch on.
Old 04-27-2011, 11:03 PM
  #236
Sollly's Avatar
I think they are 100%. Didn't really check before and after.
Old 04-28-2011, 09:52 AM
  #237
My assumption would be that it's 75% since that's part of what the module does. Connect HID's to it, that'll tell you pretty quickly!
Old 04-30-2011, 12:02 PM
  #238
DMZ
Head a da Family
DMZ's Avatar
You're assuming that it's 75%? Ya know what happens when you break the word ass.u.me into 3 separate words?
Full brightness of the fog lights can be blinding to some oncoming drivers in the daytime. The 25% dimming effect is recommended because that's what makes their brightness level similar to most factory installed DRL's.
Why not call that company up and ask?
Old 08-24-2011, 01:49 PM
  #239
COLINGER's Avatar
Any Canuck have luck finding a place in Ontario, Canada that sells these relays??
I'm not a DRL fan but the law won't allow me to drive my imported TL without DRL's.
I found some Audi style drl's that they say fit the Acura tl but wouldn't I still need a relay for that? Sorry for being so rookie!
Old 08-31-2011, 06:11 PM
  #240
COLINGER's Avatar
Grote DRL Module 44040
Its official. The 44040 activates the low beams at 100%. It deactivates the headlights when the ignition is switched off (obviously). The module will NOT be activated when the park lamps are manually activated. The module will not de-activate the vehicle's headlight if the headlight switch is left in the 'on' position.
(I got that info from the instructions that came with it).
Seems like a simple system that will get my American TL to pass the Canadian Inspection - otherwise I'll probably take it off. There is no delay so it will cause some battery drain on start up and running at 100% low beam is not the industry norm.
Quick Reply: DIY installation of Daytime Running Lights**with detailed pictures** 3G Garage #G-067
