Does 05 TL come standard with wheel lock?
Old 06-16-2008, 07:59 AM
vicdeng's Avatar
I just purchased a 05 TL from a dealer in the past month, but it comes with wheel lock installed on it, but i can't find the key in the glove compartment. I am just curious does the Acura comes standard with key locks. So they forced you to go back to the dealer for every service visit? thanks.
Old 06-16-2008, 08:19 AM
Previous Owner
Thorin78's Avatar
No, the car does not come standard with wheel locks. It's an accessory. However, if you bought the car from an Acura dealer, they should have the key to go along with it. I think the locks were like $40 w/ the key.
Old 06-16-2008, 08:29 AM
Stealthy A-CL Member
IntegraVT's Avatar
@vicdeng, also check the trunk. Dealers will often zip-tie the key to the wrench or just place it in the spare tire caddy.
vicdeng's Avatar
does every key is dfferent? base on my knowledge. i have a subaru in the past, and every key luck and key in a package has a series number, which relates to a number. so i guess each key is different. am i right?
Old 06-16-2008, 08:36 AM
it's a car-drive it
nj2pa2nc's Avatar
they are not a standard item-did you look in the trunk. If you can not find it go back to the dealer and ask for a replacement. They have their own keys they use. When I bought a 05 civic-it had wheel locks on it. When I could not find the key, the dealer replaced the locks with new ones so I then had a key.
Old 06-16-2008, 08:55 AM
vicdeng's Avatar
nj2pa2nc, i understand, thank you, but u said when u can't find the key, the dealer replaced the lock with new ones, but how can they take the wheel lock out, do they have a specific tool for it? thanks
Old 06-16-2008, 09:05 AM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
There are 5 or 6 different keys. The Dealer probably has a "Master set".
Your lock set should have a key with it (the set comes with a key).
If your key is not in the glove box, tool kit or any of the cubby storage areas, the dealer should provide a new key or a new lock set.
rockyboy
12-06-2022 02:29 PM
02-25-2020 09:57 AM
braveheart
09-07-2015 08:12 AM
Quick Reply: Does 05 TL come standard with wheel lock?
