2004-06 manual vs 2007-08 manual TL
Old 03-02-2020, 04:29 AM
kleeklee
Xue Zheng's Avatar
What’s the difference between sport model manual vs type s manual , is it just the bell housing(clutch housing) does the internal the same ? anyone did the swap?
Old 03-02-2020, 07:49 AM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
The transmissions are identical; the bellhousings (and I believe flywheels and starters) are different. Why would you want to do a swap?
Old 03-02-2020, 09:04 AM
kleeklee
Xue Zheng's Avatar
I picked up a sport tran for around 500 bucks, so it worth a try , other than spending 1500+ on a used tran
Old 03-02-2020, 09:09 AM
Latent car nut
horseshoez's Avatar
I'm not sure what you're saying, all of the 6-Speed manual transmissions for the entire line of 3G TLs are identical.
Old 03-02-2020, 09:12 AM
kleeklee
Xue Zheng's Avatar
04-06 are sport model manual and only 07-08 type s has option for manual. yes, i searched up part numbers , i believe 3rd 5th gear has different part number
Old 03-02-2020, 09:27 AM
Latent car nut
horseshoez's Avatar
It is the same transmission.
Old 03-02-2020, 09:51 AM
teh CL's Avatar
The trans aren't identical internally. The 07/08 Type S 6MT shares some similarities with the older trans but it was beefed up for the most part for the 3.5 upgrade.
Old 03-02-2020, 10:47 AM
Latent car nut
horseshoez's Avatar
Are you sure, or were the differences simply to help correct for the 3rd gear issues?
Old 03-02-2020, 11:51 AM
Slot Machine Lubricator
1black_seven's Avatar
The gear ratios and final drive are the exact same.
horseshoez (03-02-2020)
Old 03-02-2020, 12:03 PM
oraclem20's Avatar
There were changes in multiple parts of the transmission. There were changes in the bellhousing, fluid passages, and more minute changes.
The 07-08 trans IS DIFFERENT both in bellhousing and reliability and clutch fitment from the 04-06 manual.
However, if you swap the 07 MT in, what you'll "gain" is a cheaper clutch (can't explain this one), more reliability, possibly a fix for the 3rd gear issue, and a bellhousing that is more updated and compatible with newer blocks IIRC.
That being said, swap for the engine, not the transmission.
Old 03-02-2020, 01:00 PM
Latent car nut
horseshoez's Avatar
If you look at my earlier posts I already called out the bellhousing, flywheel (the clutch is the same), and starter.
As for the fluid passages, do you have any documentation which supports different fluid passages (something I totally get for an automatic transmission, but not for a manual)?
Old 03-02-2020, 01:20 PM
teh CL's Avatar
Not sure really why the changes were made but just quickly going through the parts breakdown shows more than a few part numbers that are different..
Old 03-03-2020, 04:53 PM
WDPanda's Avatar
Manual transmissions have fluid passages? I thought that was an automatic thing.
Old 03-03-2020, 07:26 PM
Latent car nut
horseshoez's Avatar
You are correct, virtually all manual transmissions have no such a thing fluid passages.
Old 03-04-2020, 12:09 AM
kleeklee
Xue Zheng's Avatar
So are they swap able? type s tran are bad, and plan to swap in a 04-06 manual in (internal)
Old 03-04-2020, 08:12 AM
Latent car nut
horseshoez's Avatar
As has been stated several times, the transmissions are 100% interchangeable; the bellhousings, flywheel, and starter are not.
Old 03-14-2020, 11:51 PM
kleeklee
Xue Zheng's Avatar
i took apart the 2 transmission and the input shaft will not come out , the inputshaft hit the bell housing
Old 03-15-2020, 12:04 AM
kleeklee
Xue Zheng's Avatar
it will hitting the snout
lylen
04-07-2010 06:46 PM
Jericho
07-13-2007 03:52 PM
JJ4Short
Cameras & Photography
14
07-09-2007 09:22 AM
honda_inspire99
02-22-2006 06:12 PM
bored7one4
09-15-2005 12:39 PM
Quick Reply: 2004-06 manual vs 2007-08 manual TL
