Custom headlights by JnC, part III.
Former Sponsor
After running the second thread for more than a year and half and having it go past 33 pages its only fair if I update it a tad and start all over again.
For those of you who know me and know my work you already know what me and my work is about. For the rest of the crowd here is a brief break down.
Previous threads
Custom headlights by JnC.
https://acurazine.com/forums/3g-tl-2004-2008-93/custom-headlights-jnc-641022/
Custom Headlights by JnC, continued.
https://acurazine.com/forums/3g-tl-2004-2008-93/custom-headlights-jnc-continued-718576/
Got JnC's custom headlights? Post pictures here
https://acurazine.com/forums/3g-tl-photograph-gallery-96/got-jncs-custom-headlights-post-pictures-here-724822/
Turn around time
Headlights that are sent in for work have highest of priority. I will work with the customer's schedule to make sure down time is as little as possible. Depending on the what the project requires I take 1~2 days to finalize everything and ship the lights back to the customer.
JnC's Trade-In/Core Exchange program
This is a very simple and efficient way of getting your headlights worked on without putting your car out of commission. I have with me a few sets of 3G TL headlights that I can modify and send of to the customer and they can install them and send their headlights back to me. This way your car wouldn’t be off the road for more than the installation time
Customer will be responsible for shipping cost which I'd endure to send the headlights to them.
Unlike the past where I use to have a list for my trade in option, I will no longer have that, I have ample number of all year TL headlights available to keep the trade in program available to anyone interested at any given time, so if you are ready then I am ready to commence work on your project.
Headlights are all OEM, no depo or aftermarket sets will be offered or taken back as trade in. I will send you modified OEM headlights and will expect the same in return.
Core exchange program is a way for member to avoid putting their car out of commission while they have this mod done by no means its a way for someone to ditch their damaged headlights for a set of good ones. Headlights that will be shipped to you would be in good, if not great, condition and that is what I expect in return. Most people realize this and so is why I havent had any issues in the past with people sending me damaged headlights. If your headlights have above than normal wear then get in touch with me and we'll discuss if I can offer you the trade in or not. Also, I have been asked in the past if I can exchange older model headlights for new ones, the program is for exchange with same year TL headlights i.e. 04-05 for 04-05, 06 for 06, base 07-08 for base 07-08 and same goes for Type S headlights .
Trade in available for all years and types of 3G TL.
Trade in process
1) After discussing the details with the you and finalizing the final project I'll ask for a $350 deposit for the headlights through paypal, $350 is a reasonable price for a used set of OEM headlights. This deposit is fully refundable and will be refunded once I get your OEM headlights back from you and once everything checks out good.
2) After deposit is received I'll commence work on the project and once headlights are ready to be shipped I'll ask for payment for labor etc.
3) Second payment will consist labot, parts (if needed), trade in charge and shipping.
4) Upon receiving second payment I'll ship the lights out.
5) Once you receive the new headlights you will install them and ship your old ones back.
6) As stated in first step, your $350 deposit will be fully refunded once I get your old OEM headlights back.
Modifications available for the 3G TL headlights
I am open to ideas so if you think you have an idea that you want executed for your set, let me know and if its feasible then I am willing to work on it.
here are some common mods or the 3G headlights.
Clear lens swaps
ZKW swap
ZKW swap include swapping the Fresnel TL projector lens with one from an 04 BMW 330 XI projector made by ZKW, hence the name ZKW swap. Lens swap yields a sharp and crisp cut off along with better light dispersion towards the corners.
ZKW replica lenses.
Due to the high price of ZKW clears recently the replica ZKW lenses were introduced to the market.
ZKW-R lenses are $40 and I have them in stock.
Bulb upgrade
The fact is that the stock D2S HID bulb just sucks, they are made by Osram and they loose their intensity after 100 hours worth of use i.e. they color shift. Right of the box they produce 3200 lumens each and after color shifting the output goes down to as much as 2800 lumens. One of the best HID bulb present on the market is the Phillips D2S model 85122+ not to be confused with 85122. These bulbs are rated at 3400 lumens and are known not to color shift so they retain their output level. Just to take care of any ambiguity, these are not your smurf colored blue bulbs, osrams are 4300k and phillips are 4200k. I personally would NEVER recommend using a higher kelvin bulb since they are VERY poor in adverse condition driving.
Phillips 85122+ bulbs are $85 shipped through my vendor.
CCFL and LED halos
Currently there are two variations of halos available for the 3G TL.
CCFL halos -- Offered by umnitza
Pros: Made to fit the 3G TL, slim, aesthetically pleasing to most.
Cons: Poor dependability, easily break and need ballasts to run.
LED Halos
Pros: Very dependable, dont need ballasts to run
Cons: Thicker in size, block 5~10% light output usually not noticeable to most.
LED strips
Another popular mod.
Side emitting LED strips can be installed inside the headlights upon request.
Carbon Fiber Inlays.
Carbon fiber inlays can also be installed depending on customer's requirements.
You can either have CF as it is.
or you can have them installed with the type S clear diffusers.
*I do not have type S diffusers, they will be installed if you provide them or if you have type S or CDM headlights.
Aftermarket Clear Diffusers
Since type S semi clear diffusers are hard to get you can always opt for USR complete clear diffusers. These can be modified to fit any year 3G TL.
Liability: DOT laws vary from state to state, kindly check with your states laws before opting for my services as I will not personally be held liable if you are in violation of any DOT codes.
Limited Warranty: Work is guaranteed against leaking/fogging for one year. I stand behind my work and my past customers can attest to that fact. My work has been time tested and proven .
A few pictures.
Link to my gallery with more pictures : https://acurazine.com/forums/members/jnc-26894-albums-custom-headlights-jnc-586/
This is how the stock headlights look like
Cleared (04-06 headlights)
Cleared (02-03 TL headlights)
Blacked out Version 1 (V1) : Turn signal reflector is completely blacked out
Blacked out Version 2 (V2) : Turn signal reflector is partially blacked out, some of the reflective surface is left chrome.
Blacked out Version 2 (V2) with pained fog light bulb cover
Blacked out Version 2 (V2) with painted fog light bulb cover and Type S clear diffuser (amber pieces in the OEM type S clear diffusers are painted black as well).
Blacked out Version 2 (V2) 07-08 Base Model TL
Color matched Version 2 (V2), Satin Silver Metallic
Color Matched Version 2 (V2), Anthracite
Blacked out V2 with CCFLs
Blacked out V2 with OEM amber diffuser and chrome strip across the diffuser painted black as well.
Blacked out V2 (07-08 base TL) with Carbon fiber inlays
Blacked out V2 (07-08 Base TL) with CCFLs
Blacked out V2 with OEM amber diffuser, silver OEM bezel painted Anthracite, Flat (matte) Black finish
Prices
Cleared headlights-- $100
Blacked out/cleared-- $150
Color Match/Cleared-- $140 + cost of color match. I do not use paint from paintscratch.com any more as the quality of the final product is not the same as from a body shop. Body shop paint services cost almost the same as paintscratch.com.
ZKW-R lenses : $40
LED halos : PM me to be directed to my vendor
CCFL halos : PM me to be directed to my vendor
Phillips Bulbs : PM me to be directed to my Vendor
Halo install -- $20
LED strips install - $20
Clear lens swap - Free of charge when having headlights modified
Carbon fiber accents -- $20 (Includes cost of custom cut pieces with CF overlays installed)
Trade in charge - $25
Each set will come with a set of custom made washers to go around the ballast and create a perfect seal; these washers will replace the flimsy factory foam washers.
Headlight resurfacing surfaces
I can resurface headlights if yours have been pitted or damaged from accident/oxidation. Each resurfacing job will be assessed before I commit to the notion that I can restore the lens, so check with me first.
I modify all sorts of headlights regardless of the make/model, kindly get in touch with me if you have any questions about a project you are interested in getting done.
My contact info
I can be contacted either by PM here on AcuraZine or by email, text and phone.
Email : rook786(at)aol(dot)com
Txt: (Five Zero Eight) Three Six Zero - Eight Three Two Zero
Previous threads
Turn around time
Trade in process
Clear lens swaps
ZKW swap
ZKW replica lenses.
Bulb upgrade
CCFL and LED halos
LED Halos
LED strips
A few pictures.
Prices
ZKW-R lenses : $40
Halo install -- $20
My contact info
Former Sponsor
A few more pictures
Type S headlights with CCFL halos, blacked out V2, retained amber diffuser bits.
04-06 Headlights, Blacked out V2, USR all clear diffusers, painted fog light bulb cover, matte black.
Type S headlights, Blacked out V2, painted amber diffusers bits.
04-06 headlights, blacked out V1, matte black, painted fog light bulb cover plus painted chrome strip.
04-06 Headlights, blacked out V2, painted fog light bulb covers, glossy black, new style CF inserts.
07-08 base headlights, blacked out V2, type S diffusers with CF overlays.
Dmoney23 (04-05-2012)
BANNED
but...you can have the LED's and halo's installed, then wire them up to 2 separate rocker switches n install those switches near your steering column. that way you have the option to turn on the LED's, or halo's, or both...whenever you want.
Chapter Leader (San Antonio)
JNC does good work. So if anyone is worried about his integrity, don't. He has done a lot of headlights and have done this for years. I got my V2 Headlights from him with ZKW and I love them on my NBP. I'm about to bring them back to him so he can install some LED's too
WishaninjaWood (10-13-2014)
Former Sponsor
I do clear headlights, charge for just cleared is $100 if you send your lights in for the work.
While getting them cleared if you want CF and ZKW installed and provide me with the lenses and CF then total cost of labor would be $115 as CF install requires painting the amber bits in the type S diffusers and then carefully installing the CF on top of that.
BANNED
Blacked out V2 -- $150
Halo install -- $20
LED strip install -- $20
CF work -- $15
ZKW swap -- Free
Headlight total -- $205
*CF is if you supply him with the material, same with the zkw lense swap. you supply those parts, those are the prices.*
correct me if i'm wrong, JnC.
straight from JnC
Halo install -- $20
CF work -- $15
ZKW swap -- Free
Halo install -- $20
CF work -- $15
ZKW swap -- Free
Rev High; Drive Happy
I did a retrofit in my car with projector-fogs... but thinking of replacing those with TSX [with yellow lens]. Been busy so didn't want to do it and have JNC do it instead.
Anyway, curious about this too!
Former Sponsor
Really? I thought I had sent you a PM.
I am working on waterjet cut brackets right now to be used with the base 04-06 TL to be used to help retrofit TSX/S2k/e46 projectors into the fog light opening. As soon as they are ready to go I'll update the thread .
Waterjet-cut-brackets? Dang! That's serious business! And here I was thinking of retrofitting it myself and using bent metal tabs like I've seen on HID Planet.
I guess I'll just wait and have headlights sent to you instead =o
Still wondering though...
Can we put in a 2.5" Yellow Lens from the Lexus ES300 on the TSX? I assume it wouldn't be the greatest... Or would it be better to tint the lens on the TSX with yellow-glass-stainer-thingamabobber?
I'm surprised TRS hasn't made a S2K-R yet when I think about! They supposedly reversed engineered the FXs...
Land of 10,000 lakes
http://www.hidplanet.com/forums/showthread.php?29883-S2K-R-In-the-Making-(Preview-Only)
Matt is actually getting them made right now. They've just been delayed on release dates yet. Not sure if you venture over to HIDplanet at all, but check this out.
On another note, aren't the FX-R Bi-Xenons?
If so, how would you/we hook up the hi-beam-solenoid of the FX-R to that of the TLs stock? I haven't had much reading or look at the projectors or wiring...
Don't want to clutter the thread anymore actually so someone who knows PM please =D [maybe I'll opt for a tri-bixenons!]
Former Sponsor
FX-R would be a tight fit. But S2K-Rs might work, I am slated to get one of the first sets of S2K-Rs when they come in . Once the water-jet brackets are ready I'll offer that as a thorough service to the 3G crowd at a reasonable price since there wont be much work involved mounting the S2K-Rs with the brackets onto the 3G headlights.
I'm thinking of holding off my retrofit plans for this S2K-R. I'd love to have another pair of S2K-R [or TSX for that matter] as my lower fogs. heheheh. No more playing around with the little thangs [ES300 projectors]
Former Sponsor
One of the members sent his headlights in to have the front lenses refinished as they had bad oxidation/fading marks left from use plus previous resurfacing from other companies. Lenses were resurfaced completely to bring them back to new condition.
07-08 Base headlights
Completely refinished front lenses.
Blacked out V2
CF inserts
ZKW-R swap
Orion V2 LED halos
Blacked out V2
CF inserts
ZKW-R swap
Orion V2 LED halos
JnC has provided excellent customer service, the best I've seen in my lifetime. I took my car apart before I went on one week vacation and sent my lights out to him. He gave me day-to-day emails of the progress of my lights. He had the halo's next-day expressed to him so he can catch the deadline. He also called me long distance just to give me my tracking number of the express package back to Toronto, Canada. Excellent quality, and highly recommended service
Former Sponsor
Mike421's headlights
Details
Another 3G first, umnitza just introduced their multicolor LED halos for the 3G and sent me a set to be installed in Mike's headlights. My camera didnt really pick up all the colors but there are around 12 different colors to choose from.
Colormatched AM V2
CF inserts
ZKW-R swap
LED strips
Umnitza Orion V2 multi-color LED Halos
Small video of the halos going through different colors, you can select a color and lock it.
http://www.youtube.com/watch?v=7kq9o_syLOg
Colormatched AM V2
CF inserts
ZKW-R swap
LED strips
Former Sponsor
From my understanding the halo kit is $299, I am not sure about the dependability of the multicolor ones since these just came out but the old Orion LED V2 halos are pretty dependable.
The oznium side emitting LED strips are dependable but not the other ones.
Former Sponsor
04-05 TL headlights for sale
Got a set of 04-05 TL headlights for sale $400 shipped. Inner tab on the passenger side headlight has been mended.
Details
04-05 TL headlights
Blacked out Matte black V1
Headlights will look identical to the following
Potential buyer has to let me know the following
Paint the fog light bulb cover or leave it chrome?
Paint the chrome strip across the turn signal or leave it chrome?
For an additional $50 I can install a set of ZKW-R lenses and also carbon fiber inlays.
Details
04-05 TL headlights
