Cracked Transmission Casing
Old 08-30-2015, 05:25 PM
quake97's Avatar
So, I was changing my transmission fluid and managed to break off half of the screw area for the drain plug. It was tight from the dealer using an air socket, I assume. Am I screwed and need a new transmission or is it possible to just replace that side of the housing?
Joe
Old 08-30-2015, 06:34 PM
01acls's Avatar
Wow that really sucks. You've got like the worse luck ever.
Pretty sure you need to replace the trans case/housing. Which translates to a rebuilt and new housing.
You can go with a use trans but with your luck maybe not.
Maybe you can find a fabracator that is willing to try and tig weld the chunk back on the trans for you if thats even possible but worth a try I guess. If it's possible then you can change the ATF by siphoning/vacuuming it through the dip stick.
Old 08-30-2015, 07:57 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
You can try using a combo of getting it welded and epoxy to seal the inside and outside of the case. There's also this tape that might be able to help you:
FiberFix | Now you can fix anything!
TypeS860
09-03-2021 06:42 PM
joflewbyu2
10-08-2015 11:16 AM
flyromeo3
09-24-2015 11:24 PM
mellsonnj
09-24-2015 04:42 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Cracked Transmission Casing
