Help with lower grill fogs on an 05
Old 05-26-2009, 10:57 PM
zaino'd
jmkiang's Avatar
So I was trying to this mod this past weekend and quickly discovered it was a lot more involved that I had anticipated...
Do I need to cut the circled sections out?
Old 05-26-2009, 10:59 PM
TLNY04's Avatar
yea cut that out actually exactly what u have circled cut that out from the 2nd clip over
Old 05-26-2009, 11:51 PM
zaino'd
jmkiang's Avatar
Dammit I thought so but I ddin't want to make the cuts til I was sure.
Old 05-26-2009, 11:57 PM
ezland00's Avatar
can you take some pictures after it's cut. i am want to do this mod and would like to see as much details as posible.
thanks
Old 05-27-2009, 08:07 AM
CarrieLynn's Avatar
yes, those need to be cut. This mod is much more time consuming then it appears. I am doing the ebay accord fogs and 07-08 lower grilles and it looks awesome but is taking some time! Are you planning on hid's in the fogs? If so ddmtuning has an awesome kit for $40!
Old 05-27-2009, 08:09 AM
zaino'd
jmkiang's Avatar
I already have my HID kit... I just need to find a day to sit down with my bumper and cut away.
For mounting, is there any reason to not mount these with a strong plastic adhesive? Theres essentially only 1 adjustment screw on my housing (up/down) and that'll still be functional. I'm 90% I'll be doing this and just cutting off the existing mounting brackets since they don't fit up anyway.
Old 05-27-2009, 08:16 AM
CarrieLynn's Avatar
well, mounting the actual fogs is the last thing I have to do, everything else is in. I don't think I will be using the brackets either but we'll see what happens when I actually go to put them in. Last time I had everything apart I didn't see how the brackets would line up to fit in there.
Old 05-27-2009, 08:42 AM
zaino'd
jmkiang's Avatar
^ Yeah I have a friend wiring everything and mounting the ballasts. I just have to take care of the fitment and mounting the housings. I'm probably gonna cut off the flappy plastic stuff and the grind off the metal brackets... then get some plastic weld and install them.
Old 05-27-2009, 09:40 AM
sixsixfour's Avatar
Dont just start cutting away. If you can, put the foglight over the area and mark it before cutting. its better to cut less and trim some more, than to over cut, and be left with nothing to hold the fog light assembly.
Old 05-27-2009, 09:55 AM
zaino'd
jmkiang's Avatar
^ Yeah my bad. Thought that was implied.
Old 05-27-2009, 10:07 AM
sixsixfour's Avatar
sorry 'bout that. I'll try to go under the car later and take a pic from behind the bumper. hopefully that will give you an idea where to cut if you havent done so. i feel bad I wasnt able to take pics of the cut areas when mine was done.
Old 05-27-2009, 10:18 AM
zaino'd
jmkiang's Avatar
^ That would be helpful. Its very annoying that the Aspec needs to be partially removed... right now, my lower grills are out so the sooner I can get this done, the better.
Old 05-27-2009, 10:23 AM
CarrieLynn's Avatar
lol I drove around for 2 days with my aspec lip off and my grilles out. One of my friends was even like "Carrie wtf happened to the front of your car?" hahahaha I even had pieces of the 3M tape on the bumper
Old 05-27-2009, 10:33 AM
"Like None Other"
djbonsu's Avatar
jason, let me know if you need some help....
Old 05-27-2009, 10:45 AM
gerzand's Avatar
Ive posted this pic before on other lower fog threads, but since jmkiang is a friend, I have no problem reposting
Notice how the bracket on the right side is used, and how its tab is bent prior to install to make it all work like cake.
Old 05-27-2009, 11:15 AM
zaino'd
jmkiang's Avatar
Haha yeah I put my Aspec back on but the inserts are in my trunk.
I should be straight but I'll let you know.
Thanks man! I do like how you utilized the existing piece and only cut where necessary. I think I'll try your approach first... because if/when I f*ck that up, I can just cut the whole thing off and do what I intended. Why didn't you just remove that bracket? From the pic, looks like theres just 2 screws holding it in place.
Old 05-27-2009, 12:02 PM
sixsixfour's Avatar
that looks similar to mine actually. the plastic in the bumper is quite sturdy. once you just have it screwed in place it wont move.
Old 05-27-2009, 12:16 PM
zaino'd
jmkiang's Avatar
^ I was referring the unused metal bracket to the left of the housing. If its not being used, why not remove it? Weight reduction
Old 05-27-2009, 12:19 PM
sixsixfour's Avatar
oh lol sorry man. im so out of it today
did you get the OEM fogs or aftermarket?
Old 05-27-2009, 12:22 PM
zaino'd
jmkiang's Avatar
I bought them from another AZ member... they aren't OEM but he claims they aren't from eBay either. Purchased from another aftermarket parts site but most probably they are eBay quality. The lenses are plastic
I did get the OEM switch though
Old 05-27-2009, 01:30 PM
aw1
aw1's Avatar
you ladies and gents just saved me a lot of trouble with this post. will be doing this in the next 2 weeks with oem accord fogs with hids.
Old 05-27-2009, 03:35 PM
Crook's Avatar
Thanks for posting that pic. It looks exactly the same as the way I mounted my fogs. The bracket on the left is actually clamping down on the plastic to hold the fog in place. It is functional.
See how I used it in this thread.
https://acurazine.com/forums/showthr...ght=grate+grin
Old 05-27-2009, 10:35 PM
"Like None Other"
djbonsu's Avatar
can hids be used with the plastic lenses?
Old 05-27-2009, 10:45 PM
Dont Touch My Car !!!
Tonywp75's Avatar
Im going to be doing the same mod soon. This info will be helpful.
Im still stock on the wiring part, any help would be great.
Old 05-27-2009, 10:46 PM
zaino'd
jmkiang's Avatar
Your headlights are all plastic man!!
Old 05-27-2009, 11:08 PM
"Like None Other"
djbonsu's Avatar
seriously, i thought some people with non-OEM plastic fogs and hids had foggy lenses after usage? just thought i saw it in a thread somewhere,,,,could be wrong
Old 05-28-2009, 12:31 AM
h2point2's Avatar
took me about a total of 7 hours of meticulous cutting to get mine good. i will post a pic tomorrow. me and a friend of mine are very picky so i let him do the cuts cause i get impatient lol
Old 05-28-2009, 12:32 AM
h2point2's Avatar
heres one better ones tomorrow
Old 05-29-2009, 11:42 AM
Mjakaz09TL's Avatar
Any updates and more pics jmkiang!
Old 05-29-2009, 11:46 AM
zaino'd
jmkiang's Avatar
No time to install these this weekend I dont think.
Old 05-29-2009, 12:46 PM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
OEM headlight plastic and ebay foglight plastic are considerably different...lol
Old 05-29-2009, 06:20 PM
Tonywp75's Avatar
any pic on how u wire them up.
Old 05-31-2009, 11:25 PM
zaino'd
jmkiang's Avatar
Old 05-31-2009, 11:32 PM
zaino'd
jmkiang's Avatar
10000K fogs... 6000K low beams.
I think I need 10000K low beams too.... they look too yellow against the LEDs and 10000K fogs.
Old 05-31-2009, 11:45 PM
sixsixfour's Avatar
that just looks sick. very nice man!
Old 05-31-2009, 11:56 PM
zaino'd
jmkiang's Avatar
^ Thanks. It wasn't the cleanest install I must say but I was more worried about secure mounting and proper aiming. Everytime I had the housing in place to bolt down, it always shifted a bit once everything was tightened. I used some custom brackets to mount everything (thin sheet metal strips). Its pretty secure and I finally got the aiming a little better. After the install, the fogs were pointing higher than my low beams!
My friend did all the wiring so major props to him. I got an OEM switch too so it looks nice and pretty.... just gotta change the bulb colors so they all match.
Still have to cut my grill inserts and put them in. I also want to see if I can "fill" in the gaps around the housings with something... maybe some type of black plastic adhesive...?
Old 06-01-2009, 07:44 AM
CarrieLynn's Avatar
NICE!!!! those 10000k's look sick but I agree you may need some matching low beams as well.
Old 06-01-2009, 08:08 AM
zaino'd
jmkiang's Avatar
^ Yeah don't remind me. A pair is on order right now.
MrHeeltoe
20
02-23-2023 01:54 PM
08KBP_VA
10-22-2019 01:55 PM
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
Avenger411
10-11-2015 03:53 PM
rhdune16
09-28-2015 11:31 AM
Quick Reply: Help with lower grill fogs on an 05
