Best LED's on the Market! Who Needs HID's?!
#322
under renovations....
Well you guys, after a month of waiting ive finally installed my DRL leds for my 07 TLS. Now I can confirm that the leds will work without a relay harness but, you dont get the full light output due to the low voltage. I went ahead and installed my relay harness since I had already ordered it. I get a brighter LED output and im 100% satisfied. Ill post the pictures when I get a chance
#323
You've probably done this, but try flipping the adapter plug that connects to the factory wiring. There is only one way it can go. The SRX that I installed these on used a 9005 LED as well. I remember it LOOKING like I had the adapter plugged in correctly, but it was wrong.
#324
#325
This is the solution that VLEDS has come up with for their Acura DRL kit:
ACURA HONDA LED DRL CONVERSION KIT
#326
Tried to order this past hour but keep getting hash mismatch error.
Tried Chrome, Internet Explorer, Safari, my iPhone over 3G, nothing worked.
#327
I flipped them around and nothing. When I plug in the old ijdmtoy harness from the pass side I get the 13v on one end of the harness and on the other I get 8.98v. there is apparently something going on with the stock harness on the driver side with not showing any voltage which I find strange. Maybe I need to change out the oem plugs? I know I have seen them on one of the vendor's site so this may be a common problem. but nonetheless I should have been able to plug in the one bulb without any harness on the 13v side. I can't see how jays_kbp610 is getting his to light up on an 07tls and I can't.
Hmm... It may be because you're in Canada. I'll let the seller know, and he can just send you a PayPal invoice.
#328
so do canadians need a harness for these to work? any particular harness we should order or this one from ebay would work? TWO 9005 Load Resistor 50W FOR LED Light FOG Light Headlight DRL Error Free NEW | eBay
and for Canadians its 9005 bulb size if i am not mistaken for the drls?
#330
Yes you'll need a harness.
I have the iJDMToy harness (Option R3).
Frosty will contact the seller for you.
I received my paypal invoice yesterday and paid it.
Hope he ships it out to me soon.
#331
do you have a link for the harness I couldn't locate it on there site, thanks
#332
I will have the seller send you a PayPal invoice.
Those look amazing! Perfect match for the HIDs! Thanks for sharing the pics.
#335
Those that are searching for the brightest fogs ever, do you use your fog lights for actual fog or to supplement the headlights in good weather?
I can't remember what I put in mine but they're a little brighter than stock and halogen. The fogs are supposed to throw a wider pattern and they're supposed to not blind you in fog. Anyone do research into the best type of light for foggy conditions? It seems like a lot of these bulbs would be the equivalent of using your brights in the fog.
I like the idea of LEDs, my whole house is LED now. I'm sure newer cars are using LEDs inside and out for the minuscule mpg improvements. However, they still have a lot of glare. I have a 650 lumen and a 3,600 lumen light for my mountain bike and the glare just from the 650 lumen manages to piss a lot of other bikers and cars off and the 3600 doesn't see street use. I'm sure the proper lens could do s lot but I can't imagine them being nice in the fog. If I'm wrong I would buy a set Monday.
#336
Stay Out Of the Left Lane
Received 1,236 Likes
I've read/skimmed all 9 pages but don't believe I saw anyone that was able to get the H8 fog LEDs to fit properly in an 07/08?? Seems like a few members were able to get them in the lenses, but "pointing down and to the left". I would like to try these in my fogs, but not if they don't fit correctly.
I hate cars - I use my fogs all the time regardless of the weather conditions and have done similar to you and swapped out to a whiter and slightly brighter bulb color. I agree with you about the brights in the fog but the occurrence of fog is so infrequent I prefer to augment my headlights. The other thing is in the later 3G models with the fogs mounted lower to the road there is less light reflectance back to the driver.
eastcoastguy (09-28-2014)
#338
#339
I can't remember the last time I actually drove through fog. If I only turned on my fog lights for that reason, they would never get used. I basically have them on anytime the HIDs are on, and sometimes all by themselves if I'm using them as DRLs.
Where are you reading about people having fitment issues with these LEDs in the '07-'08 fogs? I found two posts from members that installed them in that location, and neither one mentioned any problems, or described them as "pointing down and to the left". (Post #115 and #122)
#340
At the end of the day, I'm just trying to make sure these led bulbs are in fact plug and play for 07/08 fog lights.
Depending on how this plays out, I may look at replacing the halogens on the 09 Accord my kids drive. Not really interested in replacing wiring harnesses or adding ballasts.
#341
Could someone who has installed these in the 07-08 fog light location take a picture of them close-up when they are off? I would like to see how the LEDs point and if they clear or get impeded by the metal ring in the fog light housing.
I am trying to find something comparable to the stock bulb that doesnt shoot light forward but into the reflective housing. These LED's look like they would do that but trying to find out for sure.
#342
Thanks for the replies regarding using these lights in fog. I think I'll pass since they occasionally, well, very rarely get used in fog but I still need them to work in fog. I was hoping someone would say they work well in the fog so I could buy a set.
If anyone else reads this that has used these lights in the fog with success (visibility at least as good as stock), I'm interested in hearing about it.
#343
How long did it take him to ship for you guys?
I paid on Thursday 25th, and no update yet.
Can't wait to get the LEDs, I'm driving without DRL right now lol
guitarplayer16 (09-29-2014)
#345
I confirmed with the seller that your LEDs have shipped. The transit time may be slightly increased since they are traveling all the way to Canada. They'll be worth the wait!
guitarplayer16 (09-30-2014)
#347
Hmmm, good thing I don't listen to radio much.
I'll try it out when I get the bulbs in though, and report back.
#348
Yeah, I dont either. I installed them a month ago and just now used the radio. I would still like to know the cause for when i do use it. Let us know what happens.
#349
You didn't by chance install an aftermarket amp around the same time, did you?
#350
Ok so I got around to working out my issue. I found that the driver side oem harness is load activated from the passenger side. I also had to reverse how I use the vleds harness. I don't know how jays_kbp610 got his to work with just bulbs into the harness when the bulbs need 12v to light up. I'd still like to see his voltage readings. But anyway I can get mine to work with a little reverse engineering of the harness and such. And they are brighter then before. I'll work on permanently wiring them in over the weekend and get pics.
#351
I think the seller may have a solution to the radio interference for those that are experiencing it. As I've stated before, I have no interference whatsoever, even with all 4 of my LEDs running, so this issue is definitely not universal. I'll share the details of the solution once I know more.
The LEDs DO NOT require 6v to power on. In addition to jays_kbp610, multiple Civic owners have put these in their DRL bulb locations (which receive 6v) and they work perfectly fine. I'm glad you got yours working though. Post some pics when you get a chance!
#352
Also which relay harness did you install them with?
#353
They need 12v to turn on. Halogen bulbs don't require the full 12v but LEDs do. I would still like to see jays_kbp610's set up and voltage readings. 8th gen civics go from 2006-2011 so it is possible that Honda switched up their wiring system. I couldn't plug in my LEDs direct when I got them years ago when vleds and ijdmtoy came out with their harness. I bought my TL-S new so no one cut into anything to create a problem. Back then the only harness working good was the ijdmtoy version vleds was still working out the kinks with theirs. I was one of the first few people to get them and went back and forth with them on why it wasn't working and they couldn't figure it out then.
#354
As long as you're happy with them, that's all that matters!
#355
Ha, wow! You are not an easy one to convince, are you? Even with jays_kbp610 CLEARLY stating in post 319 that his LED DRLs (6v) turn on with no harness, and me (the creator of this thread) telling you that I know multiple 8th and 9th Gen civic owners who I recommended these lights to, and that are now running them for their 6v DRLs with no harness, you STILL insist that they need 12v to turn on. I guess we can agree to disagree, but you are definitely the minority on this one, buddy.
#356
I just ordered a pair of the ones Frosty posted about, thanks for the discount code once again! I drive a 2007 TL, with navi, and plan to use these LEDS for my DRL's, (So sick of the yellow/stock ones), so once I get them, I will post back here and let you guys know if they work and fit. I will definitely have to look up a DIY to figure out how to exchange the bulbs, but I think it should be relatively easy. You just remove your old bulb and twist and plug these ones in right?:P
#357
I've never changed the DRL bulbs on a 2007 TL, but I would assume the procedure is just like you said - very simple. The LEDs will come with 2 small cables that pair the factory wiring with the sockets on the back of the new lights. This gives you some extra cable length too, so it's easier to maneuver the lights around while installing them.
Post some pictures here once you get them installed!
#358
Do these ones come with a driver? I ordered a set from diode dynamics for the fogs on my 2012 accord, they're 2x XML LEDs on each, H11 type bulb and they came with a driver housed inside the base of the heat-sink for each of the LEDs.
Just curious if the other manufacturer is direct-driving them or if there is some type of DC regulator in them.
I also just ordered a set of 9005 MT-G2's from VLEDs that also come with a driver and I ordered separately 2 of their 10,000 microfarad caps that go into the harness to reduce low-voltage flicker on the DRLs.
If anyone else is getting flicker these might help:
9005 9006 IN-LINE 10,000uF CAPACITORS | 1 PAIR
$25 on VLEDs they also have a package for their high-power LEDs + the caps for like $225.
I picked the MT-G2's because I took a look at CREE's binning spec-sheet and they're rated for the luminous flux at the current (2.5A @ 12V) that VLED is rating them at at 85 degrees centigrade. VLED is rating them at 3000 lumen, likely from CREE's binning spec-sheet and whatever current they're driving each LED at.
The XML's are rated at 25 degrees centigrade, both are CREE high-power LEDs, but the MT-G2's are spec'd to operate at a higher temperature, which is important in this application for LEDs.
As temp goes up, light output goes down inside of an LED.
It's about time these guys started putting out bulbs with high-power LEDs, I always thought all the little ones were a joke, with cheap LEDs, now they're finally getting into the high-power LEDs that have been around for several years now. I've been using these in my dive lights for a few years now.
Here's some good info on LED lumen output that diode dynamics had on their site:
LED Brightness - LED - Research
I don't think they mentioned it in the article, but the way the LED is mounted onto the board is important too, the thermal junction that is created can be less-than-ideal if done poorly, leaving a diode that may heat up too much.
I had been wondering for a while when manufacturers would start putting these out, with drivers attached, to the automotive aftermarket. I've been playing with these high-power LEDs for years now.
#359
Does that capacitor fix the flickering DRL while starting up the car?
Sometimes I forget that my handbrake is down such as when I'm waiting for someone in my car, and I didn't put the ebrake up, and then I start up my car again.
#360
Does it continue to flicker after the car is started or only during the cranking process?
