Daytime running light bulb wattage?? 2007 TL-S
Old 07-13-2011, 01:30 PM
no44specialk's Avatar
Hey guys Im looking to buy the nokya hyper yellow lights (9005) for my DRLs. I have a 2007 TL-s. I know there are threads out there that I searched through but every other thread lists a different wattage. I just want to double check on what the correct wattage is for the DRLs?? I've heard 55w and 65w, which is correct? If I buy the 65w would I be able to run them without fear of burning up the wiring or installing a wire kit?
Thanks for your help guys!
Old 07-13-2011, 01:37 PM
Balling in the...
Mafyoso's Avatar
Are you gonna get the Module for them to turn on brighter? Its gonna suck spending all that money on yellow bulbs when they do a half ass job. I want Yellow bulbs for my DRLs as well but haven't really thought over what I want to do yet. I want them to turn on and off with a switch so that even if my headlights are on I can have them on as well. Plus I want them to turn on at Full brightness that the bulbs are made for. Maybe someone can lead me in the right path...
joe-gill (07-02-2014)
Old 07-13-2011, 01:42 PM
I'm just looking to swap the bulbs... I just want to make I'm getting the right wattage. I don't want to do anything too involved.
I know the bulb size is 9005, but the only wattage that comes of for that bulb type is 65w or higher so I'm assuming the stock wattage is 65w?
I just hate the stock yellowish/brown color.
Old 07-13-2011, 01:45 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
Neither 55W not 65W is correct.
33115-S84-A01 BULB, HEADLIGHT (HB3) (12V 60W) (SYLVANIA) ....
http://www.acuraautomotiveparts.org/...s=&view=normal
Are 9005 and HB3 the same?
And Mafyoso is right - what ever you put in there only runs at 1/2 power (or less). That's why the DRL's we have are piss yellow instead of regular white.
Originally Posted by no44specialk
.... I just hate the stock yellowish/brown color.
Get the DRL LED's and the wiring kit (if needed). Search should turn up parts and DIY instructions. You can try here (https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/) to start.
Old 07-13-2011, 01:51 PM
Balling in the...
Mafyoso's Avatar
Get the DRL LED's and the wiring kit (if needed). Search should turn up parts and DIY instructions. You can try here (https://acurazine.com/forums/showthread.php?t=553554) to start.
Yeah Those bulbs are the same.
Old 07-13-2011, 02:06 PM
Would I be harming anything by putting the 65w in the drl? I understand they will not be bright, I'd rather having them actually BE yellow than "looking yellowish".
Old 07-13-2011, 02:08 PM
MattB07TL's Avatar
If you wanted to go LED route I bought this setup and it works and looks great
http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r3.htm
Old 07-13-2011, 02:30 PM
UA7 NBP TL-S
vladkarnafel's Avatar
get led bulbs... run them with a relay and 2 load resistors, and they will put out full brightness
here is in white 60cmd bulbs:
Amber 60cmd bulbs...
all white....
Old 07-13-2011, 02:35 PM
Balling in the...
Mafyoso's Avatar
all white....
I Like this setup...So all you need is 2 Load resistors? You don't need the Module the everyone's tryna to get? Also does your Dash light up with warning lights about the DRLs? I've been tryna find Yellow LEDs to put in my DRLs pero No Luck!
Old 07-13-2011, 02:38 PM
MattB07TL's Avatar
^ You dont need load resistors with the kit I bought they have them build in to the wire kit and you get full brightness. How where you able to run your DRL's with your headlights on? I thought they turn off when the headlights are on
Old 07-13-2011, 02:39 PM
UA7 NBP TL-S
yeh there is no yellow leds... all of em are amber or white/blue.
I did add a relay... that way I have a switch to turn them on/off whenever I feel like.. there is no error on the dash cause of the load resistors...
The relay kit you have will do the same as mine to run them with headlight on or whenever you feel like it, all you need to do is a run a wire for switch inside of the car. Ground one end on the switch and run other wire to the relay, so when turn the switch on the relay will come on and will turn the DRLs on
Old 07-13-2011, 02:53 PM
The led kit does look great! For right now I'm not ready to spend the money on it just because I want to see how the yellow looks in person.
Can I safely run the 65w bulbs without the additional wiring?
Old 07-13-2011, 03:53 PM
Balling in the...
Mafyoso's Avatar
I've actually found yellow LEDs but iffy about buying them
Old 07-13-2011, 04:58 PM
I was finally able to pull one of my DRLs and see that it was a 60w bulb. Would I be doing any harm to the harness if I put a 65w in?
Old 07-13-2011, 05:11 PM
Balling in the...
Mafyoso's Avatar
I Would install them on my car, But thats My . I really dont think the 5 watts would do damage since you they are connected to a fuse in the fuse box.
Old 07-13-2011, 06:06 PM
That's my line of thinking too. I just want to make sure I wouldn't be doing any harm to the wiring harness. If anyone else has input that would be great!
mada51589
05-03-2022 08:54 PM
space_boy
ILX
51
08-15-2017 12:06 PM
JnC
09-11-2015 06:06 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Mcj270
08-31-2015 04:45 PM
Quick Reply: Daytime running light bulb wattage?? 2007 TL-S
