3G TL j-series swap
3G TL j-series swap
I have a 3G 2005 Acura TL the car has a 6 speed manual transmission and I was wondering what j series cylinder heads or blocks are compatible with my transmission that will gain it more horsepower
the motor you have is already a solid base 258-270 hp already. Do work on the existing motor. Swap J35 heads bsis cam PNP the heads, intake manifold, runners , then full exhaust , intake flashpro and you should be pushing close to 320-330 WHP. Do some research I have owned my TL for a little over 2 yrs and I learn something new every day
The following 2 users liked this post by 314_04TL:
EvilVirus (03-16-2017),
justnspace (03-16-2017)
314_04TL (03-16-2017)
I would have kept the 3.7 heads, if I didn't accidentally bind the block...
i forgot to install the tiny pin to the crank, and the crank shaft spun out of position, then my dumbass tried to start the car...locked the whole engine up!
Just ended up buying a used j32 and had a mechanic swap it for $650
^^^ Loose power? its must be a myth...
i'm sure if you tuned the car for the extra air, you'd see gainz.
as some of you may recall, i didnt change the heads cuz i wanted too, i changed them cuz i bent valves
which lead me to the 3.7l heads...which then lead to a broken block.
and that is why they call me JustonJacks
Evilvirus or wajo once said "I am suprise that car isn't on jack" LMFAO
The following 2 users liked this post by truonghthe:
EvilVirus (03-20-2017),
Slot Machine Lubricator
jkilla369
45
03-16-2024 07:27 PM
benjizema
12-25-2016 12:19 AM
