2008 TL-S brakes
Old 08-06-2016, 04:31 PM
MGK
3rd Gear
MGK's Avatar
2008 TL-S brakes
Hello
I have a 2008 TL type S, and I am considering trying some different brake pads and rotors as compared to the usual Brembos. I am tired of paying every two years for the rotors and the brakes. I do spirited driving sometimes, but mostly normal driving. The 700 bucks every two years is a bit too expensive..
I have read a lot of threads here, and would just like some top suggestions for alternatives based on what you guys have tried and have worked out well for you guys. Worst case, I guess I can try it for 6 months and then pony up if needed, but I atleast want to try one alternative since I plan to keep the car for a while. I was interested in seeing what your experience were with other pads and rotors and your style of driving, what you didnt like about them(sqeal? not enough stopping power? dust? anything else?) and if you would recommend them. I am hoping it would help other folks too who are looking for the same information in one thread.
Thank you in advance!
Old 08-06-2016, 05:30 PM
mcmanut's Avatar
I have used the top end Auto Zone pads and they have been great! Low dust and stopping power is awesome. The best part is you only pay for them once. They have a free replacement policy when they wear and need to be replaced . I'm on my 3rd set and no questions asked when you replace them. Go to AutoZone.com
Old 08-06-2016, 06:34 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
Autozone Duralast Cmax gold (the name has change) cost $55 for lifetime.
Old 08-06-2016, 09:47 PM
FamilyGuy's Avatar
Pads: Akebono ASP536 rears and ASP1001 fronts.
Old 08-06-2016, 10:25 PM
llllBULLSEYE's Avatar
Yep top end Autozone Duralast pads and rotors and couldn't be happier.
Old 08-07-2016, 07:29 AM
DMZ
Head a da Family
DMZ's Avatar
Try Wagner MX1049's. They're the ones I use. Adequate stopping power without the dusting and insane price of the original pads..
Around $25 for the set from rockauto.
Old 08-07-2016, 09:21 AM
MyGuti's Avatar
Will the Duralast Cmax gold work for a 07 base?
Old 08-07-2016, 03:28 PM
truonghthe's Avatar
Yes, make sure you tell them its for a base model.
Old 08-07-2016, 07:20 PM
MGK
3rd Gear
MGK's Avatar
Which rotors go with these?
Old 08-07-2016, 07:33 PM
MGK
3rd Gear
MGK's Avatar
Are these the duralast ones?
Pad:
Duralast Max/Brake Pads DGC224M- ReadReviews onDuralast Max #DGC224M
Rotor:
Duralast/Brake Rotor 54031- ReadReviews onDuralast #54031
Old 08-08-2016, 08:17 AM
FamilyGuy's Avatar
Any rotors you like.
justnspace (08-08-2016)
Old 08-08-2016, 10:21 AM
truonghthe's Avatar
Yup.
Old 08-10-2016, 03:15 PM
Jesse729's Avatar
I am a strong believer in changing pads only if the rotors are not warped. I do this on a lot of my cars and the TL brembo stock pad material seems to be very easy on the stock rotors. It makes a OEM brake job $160 vs $400 for parts. Also since the pads come out through the top of the caliper a brake job can happen in 30min if you're quick. A lot of people advise against it but I have about 70,000 on my stock front rotors with no issues. I would finally replace them at the next brake job. I have had good experience with Auto Zone's MAX Pads as I think they are called now. Autozone's rotors are good too they just rust really bad.
Old 08-10-2016, 07:38 PM
ChristianUA7's Avatar
I also have Auto Zone's top line brakes. Have had them on the car for 10K miles with zero issues. Have had them on previous cars as well with no issues.
Flipster23
Norcal
262
05-04-2023 02:47 PM
EE4Life
12-20-2022 05:16 PM
EE4Life
03-12-2020 07:29 PM
EE4Life
03-12-2020 07:29 PM
EE4Life
05-14-2016 07:14 AM
Quick Reply: 2008 TL-S brakes
