'07 TL Type S trunk under speaker cover
There should be 2 plastic push pins on the left and 2 on the right holding the carpet in place. Use a big flathead to pry the pin down. Sometimes you can partially remove the pin with the flat head and just grab it real hard with you hand and pull it down.
If you use cargo nets you might also have to remove 1 of those giant cargo net pins on each side that is screwed into the carpet up top.
I just removed my sub and amp yesterday and had to completely disassemble my trunk
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
