DYNO for 2014 Acura RLX Sport Hybrid
#41
It is very possible that this won't work. I was told that all 4 tires have to engage power at the initiation of power delivery or the system might not engage. This is an experiment at best. We will see.
#42
Update on the DYNO
Well boys, I tried to DYNO the car and the electronics did not like it one bit. I don't know if it was the type of DYNO or the car, but the car did not want me doing what I did. Every light on the dash lite up in protest almost immediately. It was a grueling effort to set it up properly, and we tried to make it work. I killed it after one run. We could not get higher than 4th gear in manual sport mode. The DYNO measured 401 ft/lbs of torque @ 1,154 rpm, peaked @ 419 ft/lbs @ 3,999 rpm, showed 349 ft/lbs at 6,493 rpm. HP started at 162 @ 1,154 rpm, 288 @ 4,000, and 389 @ 6,535 rpm. I'm supposed to get the chart emailed to me so I will post when I can. Within the software, it had an option to estimate the crank numbers based on the measured numbers. It suggested that the crank peak HP is 431 and the peak TQ is 473 ft/lbs. I don't know how it came to those figures. Also it verified and cross referenced the measurements in relation to the 4.89sec 0-60, 13.6 @ 106 mph 1/4 mile times that the HP and TQ figures are likely spot on based on the weight of the car including the driver.
The following 11 users liked this post by RLX-Sport Hybrid:
2011TL (03-24-2015),
Colin (03-23-2015),
George Knighton (03-24-2015),
hondamore (03-24-2015),
Malibu Flyer (03-23-2015),
and 6 others liked this post.
#43
Imagine that--a car too complex to dyno. Only Honda could come up with such a beast. Will reserve comment until we see the actual curves but the (apparently uncorrected) results are promising.
I'll have to get off my duff and drive out to Buschur's to give it a shot. They dynoed my RL a few years ago.
Terry RL (03-26-2015)
#44
I suppose the safety-based electronics are so much smarter these days that the car knows that it is not cruising down the road somewhere but rather just spinning it's wheels while stationary and it is just trying to stop you from attempting to accelerate while the wheels are spinning. Seems logical and safe, just frustrating to anyone trying to run a dyno.
I fear the only "dyno run" will have to be accomplished with software and a computer or a good old fashioned pencil and calculator running backwards off performance numbers.
Thanks for the effort RLX-Sport Hybrid!!
#45
I tried to make it work, but it was a lot of effort and I don't have information that is more reliable than we we already had. Maybe the type of DYNO that has the rollers that the tires drive on is the better version to use. I don't know where I could test it on that version. I think someone else will do it, not me. I'm quite frustrated as I was really looking forward to seeing the results of multiple runs to share. I don't know how to blur my license plate in the pictures when the car was hooked up to the dyno. Once I can figure out how to do that, then I will post them (or give them to Dr. Bob to post them for me).
Sorry guys.
Sorry guys.
#46
#47
I tried to make it work, but it was a lot of effort and I don't have information that is more reliable than we we already had. Maybe the type of DYNO that has the rollers that the tires drive on is the better version to use. I don't know where I could test it on that version. I think someone else will do it, not me. I'm quite frustrated as I was really looking forward to seeing the results of multiple runs to share. I don't know how to blur my license plate in the pictures when the car was hooked up to the dyno. Once I can figure out how to do that, then I will post them (or give them to Dr. Bob to post them for me). Sorry guys.
I believe you already have my email, I'm happy to host what images/video you have.
#48
Grandpa
Received 2,609 Likes
It's a little low for US Net HP, too, but you can set it up any way you want and the owner probably over corrected to be on the safe side. Typical Honda drivetrain losses would put US Net HP more like 447; however, I have to admit that I have never been on a dyno with a Honda DCT transmission of any kind.
Your problems with this were predictable! :-) The load on the wheels caused by the bolt-on devices prevented proper gear changes, and it was further complicated by the front electric motor trying to pre-select a gear while also anticipating what to do with its power when trying to interpret the unusual drag on all four wheels.
I'm not an engineer, but the summary of their explanation is that the load on the wheels is not where the car's designed to take the load, if that makes sense. It's confusing to the car, and their explanation is confusing to stupid old men.
Thanks very much for giving it a go for us and reporting the results!
#49
The crank HP is underestimated if you ended up using the kind of dyno that you described to me a while back.
#50
We need to try again on an AWD dyno like that made by Mustang, one in which the tires turn the drums. Even then....it's complicated, as I found with my RL. We got puzzlingly low numbers when I tried that route.
#51
Grandpa
If the DCT is 3% more efficient than a conventional manual transmission with an LSD, I just don't know what.
#52
#53
It could be the same problem that Honda sees when estimating total power. Probably why they quote gas hp and electric motors separately but when combined they don't add up. But maybe the actual work they do adds up and then some.
#54
Once you have opened the image, use the "eraser" tool (the icon looks like the pink eraser) to obliterate whatever you want to remove. Save the file, and you are done.
#55
Grandpa
I think it's going to be a rare occurrence that the ICE and all three electric motors are putting down maximum power at the same time.
If you were Honda and about to put out a 450 US Net HP car, that nobody would be able to buy and which you refused to advertise, while remembering the ITR heritage and the Fast and Furious debacle, you probably wouldn't talk to talk about it very much.
#56
Amazing
As I was gassing up tonight a 2011 MB SL550 driver pulled up and started to fill up in front of me. He asked about the SH and we struck up a conversation. Soon after we both departed at the same time. At the first light he joked with me that we should race to 60mph for kicks. The road was clear, and nobody was around, so two dudes hit the gas. I put it in Sport, Brake Hold and M1, then we took off. Shockingly I got him all the way by a car length and a half. At the next light which was a few hundred yards away, he asked me to pull over because he wanted to learn more about the car. Of course I obliged and we talked for a few minutes. He was very impressed. My phone performance app displayed a 4.93 sec to 60 mph which is fractionally slower than I recorded previously. Mind you it was in the rain at the time.
What a cool car. Good night everyone.
#58
If you have a Windows laptop, it's really easy to do it with Paint (which you will find in the Accessories menu).
Sorry everything was so dirty before shooting the pictures. Here they are from Monday's attempt to dyno the car:
https://www.flickr.com/photos/129921...6/16760222880/
#59
https://www.flickr.com/photos/129921819@N06/16921732446
https://www.flickr.com/photos/129921819@N06/16327616533
#60
Grandpa
Thanks for sharing so much. :-)
#61
I'll see if I can get on a local AWD dyno. It's going to be a while before I can do it because I am, honestly, overwhelmed with work (and thankful I have enough work to be overwhelmed with it, thank you), but it will happen.
#62
When I dynoed my TL AWD on a Mustang dyno the ECU and tranny went all wonky and it was near impossible to get a full pull. - Acura's dont dyno well.
Does anyone have a Vbox? I'd be interested in seeing some true performance data. I'd be happy to let someone use mine. - I've gotten much data on my RLX FWD
#63
The 2014 4450lb E550 4matic makes 400hp and 440ft/lbs, It runs a 4.3 to 60 and runs the 1/4 in 12.8@112mph.
The 2010 4300lb E550 4matic made 382hp and 390 ft/lbs ran a 4.8 to 60
The 420hp (rated) 4.0 turbo in the Audi S6 & S7 usually dynos in the 390-415whp range and 400-410 ft/lbs of torque. The S6 has the same weight to propel as the RLX hybrid... but the S6 runs 0-60 in 3.7 seconds.
I'd say at best the RLX hybrid is equal to a 380-390hp gasoline engine, and the dyno results are very inaccurate due to the electric motors coming in and out of duty as speeds climb.
I'm willing to bet a FWD RLX with sticky rubber could come within 2 tenth of the hybrid in the 1/4 mile.
has any magazine or member done a full performance test on the RLX hybrid? I only see estimated out there.
#64
You'll Never Walk Alone
The 0-60 time doesn't line up with a 430hp and 470 ft/lb car, even with the weight being 4300lbs+ that should be running a very very low 4 if those numbers were accurate. 1/4 mile is hard to judge as your running only on the 3.5L after 80mph.
2011 BMW 550i ? Instrumented Test ? Car and Driver
A Infinti M56X with 420hp/417lbft at 4243lb does 0-60mph in 4.9s and 1/4 mile in 13.5s@108mph.
2011 Infiniti M56x - Short Take Road Test - Car Reviews - Car and Driver
The Hyundai Genesis 5.0 at 4600lb with 420hp/383lbft does 0-60mph in 5s and 1/4 mile in 13.6s@105mph
2015 Hyundai Genesis 5.0 Test ? Review ? Car and Driver
The older Genesis 5.0 at 4234lb with 429hp/376lbft does 0-60mph in 5.1s and 1/4 mile in 13.7@103mph
Hyundai Genesis R-Spec 5.0 Sedan Test ? Review ? Car and Driver
Most of the above cars don't have AWD, so may be they are a couple tenths slower to 60mph. But without the AWD losses, their trap speeds should also be higher. When you compare the Genesis numbers to the RLX numbers, the RLX is slightly faster. Yet, the Genesis is rated at 429hp.
hondamore (03-31-2015)
#66
The RLX Sport Hybrid is unique in that the peak horsepower numbers don't tell the whole story. The instant torque from the electric motors and the high rev boost from the VTEC complement each other making the sum of the two greater than the total hp/torque numbers would suggest. What I'm trying to say is that, even though the total HP is only 377, the complementary nature of the power train's multiple components will result in performance numbers equal to or better than cars with much higher peak HP numbers.
#67
After driving the rental 2015 Chrysler 300 with the V6, getting back in my MDX at the airport was refreshing. However getting into the Blackbird SH was like a hot knife through butter awesome. Damn I love that car. How anyone drives it and not fall in love with it is beyond me. Have to take it to dinner tonight with the family. Now if it could stop snowing already..... Florida 80's felt great and a real shock to step out of the airport at JFK to get smacked in the face with the cold.
#68
I'm playing catch-up here! What did you mean by "Blackbird SH" when you said:
"However getting into the Blackbird SH was like a hot knife through butter awesome. Damn I love that car. How anyone drives it and not fall in love with it is beyond me."
#69
Make sense now?
#70
Yes, I "suspected" you may have referred to the fastest plane ever made but it simply didn't register that it would be mentioned in an auto forum and when you said "Damn I LOVE THAT CAR" I immediately assumed the was a new model out there somewhere that was named "Blackbird"... :-)
#71
#72
Yes. I tried everything. If you look at the begining of the thread you will see the graph I created with the data that came from the Vbox which was generally very conservative relative to the dyno measurements. Regardless of the exact numbers which we may never really know scientifically, the car hauls ass regardless. Hey I read tonight on Car and Driver that the new Ford GT will be limited to 250 units. That means that the RLX-SH will be just as rare!
neuronbob (06-24-2015)
#74
Grandpa
Honda Challenge has basically given up on monitoring a lot of things and relies on horsepower limits to regulate what cars are in which class.
This means that there will be a portable dyno at all NASA events.
I thought I'd be able to avail myself of these, but after speaking with them they're saying that they know that they cannot get an accurate reading.
This is probably why Honda plays it safe and rates the car for 377 HP when the total of electrics adds up to something like 430 HP. I know from the acceleration times that 430 is unreasonable, but I also know from the acceleration times that 377 is too low.
The following 2 users liked this post by George Knighton:
hondamore (06-24-2015),
RLX-Sport Hybrid (06-24-2015)
#75
The following 5 users liked this post by RLX3G:
George Knighton (07-18-2015),
Malibu Flyer (07-18-2015),
neuronbob (07-18-2015),
pgeorg (07-18-2015),
wstr75 (07-18-2015)
#76
Grandpa
I can't help wondering about the real world performance figures for the NSX Sport Hybrid and how they're going to end up publishing its HP.
Nobody's floored it so far with the two red tour cars, but everybody's curious. It's not worth anybody's job to do it, but you know they want to do it. :-)
#77
I'm sure "obey all traffic laws" is in their contract, somewhere. Too bad, really. I'd love to see how it does on a drag strip, somewhere.
#78
Grandpa
They have not been obeying all traffic laws.
The command might've sounded more like, "Don't give too much away yet."
#79
#80
What might be nice if Acura allowed the auto press a chance to drive the NSX and SH back to back to demonstrate more than one application of the "hybrid" drive train. The we might get some positive press on the RLX-SH.
While I am dreaming, I am still dumbfounded at why Acura has so far been keeping the RLX Sport Hybrid under a peach basket. It just fails to make any sense. Those of us with the car continue to report how wonderful and impressive the electric/gas drive train is, yet Acura doesn't seem to want to publicize it. While Acura seems to ignore the car, the early reports on the 2016 indicate that Acura has invested in developing additional new features. They aren't abandonding the model. No matter if they want it to be a limited production car, why not use it to highlight Acura's cutting edge engineering? In the meantime I just take solace in the fact that I have a Sport Hybrid sitting in my garage. Whatever Acura chooses to do or not do, I can enjoy my ride. That is a whole lot nicer than getting frustrated in trying to make any sense reason out Acura's marketing.
