Microsoft: Windows 10 News and Discussion Thread
#601
Needs more Lemon Pledge
Crap, must be personal gremlins.
AND..... now it works fine.
#602
Go Giants
#603
There are just lots of small irritating bugs in Windows 10. Nothing that is so bad that you want to throw bricks at your computer but you still wish MS could have done better. For example, I found that Office apps, especially Excel, were very slow to open if I had Cortana enabled and I use a slideshow for my Desktop background but only changing pics every minutes seems to work - all other timeframes would make the slow show get stuck. There are others as well.
#604
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Weird W10 issue...
Open ALL SETTINGS, then UPDATE AND SECURITY. Then open Task Manager on top of it. See if you can do anything with TM while the update and security window is open. My TM is frozen while that setting window is open (it;s d/ling updates).
As soon as I close the settings page, TM goes back to normal.
#605
Sanest Florida Man
OMG so excited for this in the next version of 10!
Read more at https://blogs.windows.com/windowsexp...-14942-for-pc/
Service hosts are split into separate processes on PCs with 3.5 GB+ of RAM: If your PC has 3.5+ GB of memory, you may notice an increased number of processes in Task Manager. While this change may look concerning at first glance, many will be excited to find out the motivation behind this change. As the number of preinstalled services grew, they began to get grouped into processes known as service hosts (svchost.exe’s) with Windows 2000. Note that the recommended RAM for PC’s for this release was 256 MB, while the minimum RAM was 64MB. Because of the dramatic increase in available memory over the years, the memory-saving advantage of service hosts has diminished. Accordingly, ungrouping services on memory-rich (3.5+ GB of RAM) PCs running Windows now offers us the opportunity to do the following:
- Increase reliability: When one service in a service host fails, all services in the service host fail. In other words, the service host process is terminated resulting in termination of all running services within that process. Individual service failure actions are then run. As you may have noticed in Task Manager before, service hosts can contain a lot of services:image: https://winblogs.azureedge.net/win/2...services_1.png
- Increase transparency: Task Manager will now give you a better view into what is going on behind the scenes. You can now see how much CPU, Memory, Disk & Network individual services are consuming.
image: https://winblogs.azureedge.net/win/2...services_2.png
To see the name of the service, click on the left-most arrow such that the Display name drops down. Alternatively, right-click on the header and select ‘Command Line’ to add the Command Line column. Service names will be listed in the format ‘svchost.exe -k <svchost name> -s <service name>.’ - Reduce servicing costs: Following reports of instability, service engineers, IT admins, and Microsoft engineers can rapidly pinpoint issues to the exact service and fix it.
- Increase security: Process isolation and individual permission sets for services will increase security.
#606
That's a worthwhile improvement. Trying to figure out wtf service host is, is a big pain in the ass.
#1 STUNNA (10-08-2016)
#607
Received 2,773 Likes
Ugh, so i updated my win 10 to the anniversary edition and now my USB ports are acting all wonky. My devices keep disconnecting and reconnecting. I'd trash this computer if I could.
maybe its time to fund a new storage/torrent machine
with the new iPhone I got, I could've easily started using my Mac mini to sync with it, but no. My 256gb SSD doesn't have enough room.
#608
Sanest Florida Man
^Dope!
Big update in the fast ring of Windows 10 Insiders yesterday. Lots of new features, including the above,
Hello Windows Insiders!
Today we are excited to be releasing Windows 10 Insider Preview Build 15002 for PC to Windows Insiders in the Fast ring. This is a BIG update so please take time to look through all of the new changes we detail below.
Tab preview bar: It’s easy to lose track of what’s in your tabs, especially when you have many tabs from the same site, with similar titles and icons. Tab preview bar allows you to easily glance at a visual preview of every tab you have open without leaving your page. You can scroll through the list with touch, mouse wheel, or a touchpad. Just click the chevron icon next to your tabs to get started. Give it a try and let us know what you think!
Set these tabs aside: We often hear that it’s a headache to keep all your tabs organized, and to pick up where you left off. Sometimes you just need to set everything aside and start from a clean slate. We’ve added two new buttons next to your tabs in Microsoft Edge to help you quickly manage all your tabs without losing your flow.
Jump List for Microsoft Edge: You can now launch a new window or new InPrivate window for Microsoft Edge straight from its Taskbar icon. Simply right-click or swipe up on the Microsoft Edge icon in the Taskbar, and pick the task you want!
Component UI: This release introduces a new UWP architecture for Microsoft Edge’s multi-process model, including a new visual tree and new input model. These changes will help improve stability and input responsiveness and make the browser UI more resilient to slow or hung web page content. Be on the lookout for any issues with tab launches and activation or input (including keyboard, mouse, or touch) and share feedback in the Feedback Hub if you have problems!
Flash Click-to-Run: Microsoft Edge will now block untrusted Flash content is now blocked by default until the user explicitly chooses to play it. This means better security, stability, and performance for you, while preserving the option to run Flash when you choose. You can learn more about this change on the Microsoft Edge Dev Blog: Extending User Control of Adobe Flash with Click-to-Run. We will be evolving this experience in upcoming flights to make the option to run Flash content more contextually obvious.
Web Payments: Microsoft Edge now has preview support for the new Payment Request API, which allows sites to make checkout easier using the payment and shipping preferences stored in your Microsoft Wallet. This is currently in a preview state for developers and will not process payment information until a future flight. You can learn more about Payment Request on the Microsoft Edge Dev Blog.
For a complete list of all the changes in Microsoft Edge, visit the Microsoft Edge changelog.
Updated Windows Share experience: We have redesigned the Windows sharing experience to be more app-focused and integrated with where you are sharing from. The new Windows Share experience will pop-up the new share flyout within the app you are sharing from and give you a list of applications you can share to. This list changes based on your usage.
The WIN + H hotkey, used in the old Windows share experience, has been removed.
Capture a region of your screen: OneNote 2016's popular screenshot feature is now built into Windows 10! You can use Win + Shift + S to capture a region of your screen and copy it to the clipboard for pasting into OneNote for Windows 10 or any other app. Please note that this feature replaces the one in OneNote 2016.
Improved high-DPI support for desktop apps: Continuing from our work with Build 14986, Build 15002 brings more goodness in the way of high-DPI support. First, much like we did with Microsoft Management Console (MMC), we’ve updated Performance Monitor (Perfmon) to now be more crisp on high-DPI PCs. Second, while we’ve enabled these improvements by default for some Windows desktop apps, you can now enable them yourself for other GDI-based applications, too! To do this, you’ll need to find the application’s .exe file, right-click on it, and select Properties. Go to the Compatibility tab, and turn on System (Enhanced) DPI scaling, and click OK. This setting overrides the way that applications handle DPI scaling (which sometimes uses bitmap stretching and can result in applications rendering blurry) and forces them to be scaled by Windows. The setting that was previously labeled Disable display scaling on high DPI settings is now referred to as Application scaling. This works only for apps that use GDI.
Smooth Window Resize: One of the things we’ve heard from Windows Insiders is that the animation when resizing windows isn’t always smooth. We’ve taken that feedback, and Insiders should see improved performance and smoothness when resizing GDI-based Desktop applications (such as File Explorer, Task Manager, and Notepad) and UWP apps (such as Groove Music and Outlook Mail). In addition to this work, we’ve also updated our code so that when rapidly resizing UWP apps, the window frame background will be transparent as the app adjusts, rather than a flat base color.
Desktop Icon Placement and Scaling Improvements: We've heard from you that sometimes desktop icons aren’t scaled or arranged as expected, particularly after docking/undocking your device, working with monitors that have different DPI, or projecting your monitor. We want users to feel that desktop icons are stable, scaled properly, and move predictably when changing monitor configurations, so we’ve made changes to how this logic works in order to address your feedback. Now when you change your multi-monitor configuration, dock/undock your device, project your display, add or remove monitors, or otherwise make changes that affect the icon scaling, you should see an improvement in how the system adjusts the layout of your desktop icons. Try it out and let us know how it goes!
Simplified and faster VPN access: A much requested feature from our VPN users, we’ve updated the Network flyout so that after selecting a VPN, you can now click connect from within the flyout rather needing to open VPN Settings. We appreciate the feedback and look forward to what you have to share next! If you encounter any issues, you can still connect to VPN from the VPN Settings (and please log feedback letting us know about it!)
Improved sign-in dialog for apps: We have improved the app sign-in experience for users with multiple accounts. The new sign-in dialog shows your available Microsoft, Work, or School accounts and gives you the ability to add new accounts to Windows.
Lunar Calendar support for the Taskbar: Those of you who follow the Simplified or Traditional Chinese lunar calendar can now use the taskbar calendar to quickly check the lunar date alongside the current Gregorian date. Special holidays are called out in accent-colored text. Go to Settings > Time & Language > Date & Time to pick which additional calendar you’d like to see. Thanks to everyone who sent in feedback requesting this!
Improving our notification experience for app developers and everyone: App developers are increasingly facing scenarios within their applications where they require more flexibility to organize notifications to provide the desired user experience. That flexibility is changing with Build 14993! To provide a more relevant and crafted experience to Windows users, we will now provide app developers a way to create custom subgroups for their notifications in Action Center. Also, to address issues where notifications might have the wrong time stamp (for example, if your PC was asleep when you received a cross-device notification from your phone), we’re enabling app developers to override the notification timestamp. If you’re an app developer, please check out the Tiles and Toasts blog for coming posts about how you can leverage these new features.
In addition, thanks to your feedback, we’ve added point erase to the Windows Ink Workspace’s Sketchpad and Screen Sketch. This means that now you have the option of deleting your whole ink stroke or erasing only pieces of it. You can select your desired option by tapping the eraser icon, where you’ll find new options to switch between eraser types.
We’ve also updated our taskbar logic, so that if you have the Windows Ink Workspace icon on your taskbar, it displays the taskbar of every monitor. Clicking it launches the Windows Ink Workspace on that monitor.
More recurrence options for Reminders: We’ve heard your feedback, and with this build of Windows we’ve added a new option to set recurring time-based Cortana Reminders for “Every Month” or “Every Year” —great for bill payment or anniversary reminders!
Keyboard shortcut change for invoking Cortana: The keyboard shortcut to invoke Cortana in listening mode is changing to WIN + C. This shortcut will be off by default. If you’d like to use it now, head to Cortana’s settings and you’ll find a new option to enable it. WIN + Shift + C will be used to open the App Charms menu, seen in the title bar of Windows 8 apps.
This new experience is still a work in progress, so there are some places that still include the older OOBE pages and Cortana is unable to help you get your PC fully set up. We plan to continue to do more work on this so stay tuned! While you can’t access the Feedback Hub during OOBE, please take a moment once you've reached the desktop to complete the Quest and log feedback in the Feedback Hub.
*Works for languages that support Cortana. For languages that don’t support Cortana, you will still get the new experience without the speech capabilities.
Note: We are working on making Installation media (ISOs) available for Build 15002 in the next week for Windows Insiders to more easily try out this experience.
Narrator support for WinPE and WinRE: This build also now supports the use with Narrator from WinPE for installing Windows as well as troubleshooting options with WinRE. When we make the ISOs available for this build, you’ll be able to try this out by building a bootable USB drive or other bootable media and using the ISO files. After booting into WinPE, wait 15-20 seconds and then use the keyboard shortcut CTRL + WIN + Enter to launch Narrator. You will need to restart Narrator to use it after any reboot during the install process.
NOTE: Not all audio devices are supported. USB headsets are the recommended option for audio, since the full Windows audio drivers for the PC are not available in WinPE/WinRE. Built-in speakers may also work on some PC’s but if you do not hear Narrator announce that it is starting, try connecting a USB headset and restarting Narrator. Narrator Touch is not supported during OS install.
Braille support in Windows: Not too long ago, we mentioned Braille support was coming to Windows. That work is starting to appear in builds, and you will find a new button that offers the ability to download support for braille via Settings > Ease of Access > Narrator. While this button is present, the feature doesn’t work yet so hold off on giving it a try for now. We’ll let you know in a future post when braille can be used.
Narrator users please take note that the Narrator keyboard shortcut is changing: To help reduce accidental launch of Windows Narrator, we have updated the hotkeys to be more intentional from WIN + Enter to Ctrl + WIN + Enter.
Narrator Improvements: We’ve made several improvements to Narrator for navigation when using Scan mode. You can now navigate to headings of a specific level by typing the number of the heading level you want e.g. 1 for the next heading level 1. Add shift for the previous heading. In addition, Narrator’s Scan Mode now allows you to press Home and End to move to the start and end of a line of text respectively when pressed. Finally, when in Scan Mode you can press Ctrl + Home and Ctrl + End to move to the start or end of the web page or other content you are reading.
Improved legibility for UWP apps in high contrast: As part of the Windows 10 Anniversary Update, we improved the legibility of many websites viewed in high contrast by showing an opaque layer behind the text. We recognize that similar to the state of websites on the Internet, many UWP apps have not been tailored to present an optimal experience for users who need increased contrast. So, we’re taking a similar approach to improve how UWP apps look in high contrast. We’ve updated the XAML framework to now display an opaque layer behind the text and coerce semi-transparent UI to be fully opaque. This addresses the most common issues in apps like in the before/after screenshot below. These adjustments are applied by default in high contrast and apply to *all* XAML Store applications that run on Build 15002 and higher, whether they explicitly target this build (with the SDK) or not. However, applications that render their own text on something such as a SurfaceImageSource do not receive the automatic adjustment from the framework. If you find any issues with this work, please log them here, and as always, you can reach out to @MSFTEnable on Twitter at any time about accessibility problems and requests you have for accessibility in Windows.
In addition, we’ve updated Windows Ink to now support a rich color range experience when using your device in high contrast. Try it out in Sketchpad today and let us know what you think!
New Display Settings options: Based on feedback of the most commonly used settings, we have updated the Display Settings. In the refreshed display page, numerous changes have been made to make the page clearer and easier to use, including now being able to change resolution straight from the main Display Settings page.
Lower Blue Light: Windows can now automatically lower the amount of blue light emitted from your PC at night. Settings to turn this functionality on or off and use a local sunset and sunrise or custom schedule are in Settings -> System -> Display. If you need to quickly override the schedule or always want manual control, you can enable this quick action in Settings->Notifications & actions. Use this capability for a couple nights and send us feedback through the Feedback Hub, we’d love to know what you think!
New per app Surface Dial settings: App developers have the option of providing custom tools for the Surface Dial when using it within their app. In addition to this, Windows Insiders with Surface Dials will now be able to customize the default tool set for individual apps starting with this build. Setup the keyboard shortcuts most meaningful for specific apps – like Ctrl + Delete in Word 2016, or CTRL + Tab in Sticky Notes. Head to Settings > Devices > Wheel today to try it out and share your thoughts! We’ve also updated the custom tool creator to now enable you to set keyboard shortcuts that include a number of common symbols.
Windows Personalization now supports recent colors: We understand how important colors are for personalizing your Windows experience, and that sometimes it takes a few tries to find the perfect one to match your background. Sometimes you pick a new color, close Settings, only to discover that the color you picked wasn’t quite what you were looking for. We have a solution! With Build 15002, we’ve added a new “recent colors” section to Settings > Personalization > Colors, so you can easily pick between the colors you’ve decided on in the past.
Windows Theme Management in Settings: As we’ve mentioned in the past, one of our ongoing efforts is to consolidate Settings and Control panel, and we use your feedback to prioritize the convergence into Settings. With Build 14993, we’re happy to unveil the next piece of this project: Management of themes has now moved out of Control panel and in to the Settings app. It can be found, along with all your other familiar personalization options, under Settings > Personalization. Pick one of your recent themes, or create and save custom new ones. How would you like to see Settings evolve next? Let us know in the Feedback Hub!
Improved Cross-Device Experiences Settings: With the Anniversary Update, we added the ability for app developers to create cross device experiences. Users could enable or disable this feature for their account via Settings > Privacy > General “Let apps on my other devices open apps and continue experiences on this device”. With Build 15002, we’ve moved this setting to its own page – a new entry under Settings > System, called “Cross-device experiences”, and we’ve added a new dropdown to allow you to switch between My Devices or Everyone. If you’re interested in learning more about experiences an example experience thatapp developers can create with this, check out this blog post.
Metered Ethernet Connection Support: Based on your feedback, we've added the "Set as metered connection" option to the Ethernet (LAN) connections in Settings > Network & Internet > Ethernet. Just like mobile broadband and Wi-Fi connections, this option helps you to restrict background data usage from some applications and gives you more control over how data is used over the Ethernet connection.
Polishing the Touchpad Settings page: Based on user feedback, we have made some UI improvements to the new touchpad settings page, including creating two new groups for three and four finger swipes, updating search terms to make them more discoverable, providing more flexibility to control how taps work, and fixing an issue where Touchpad Settings wasn't showing an icon next to the name.
This is still a work-in-progress and we would love to hear what you think. Next time you need a VM, please give it a try and send us your feedback!
You can read more about Windows Information Protection in Windows 10 here.
New settings page for Microsoft Pinyin IME: To go alongside with the new customization options we’re adding for the IME, we’ve revamped the Microsoft Pinyin settings page – now divided into 5 categories so you can more easily find what you’re looking for. Have a look through the new settings and setup your IME experience the way that feels best to you!
Hotkeys for the Microsoft Pinyin IME: We’ve added some new features to improve the keyboard experience when using the IME. Including candidate window switch keys configuration, Chinese/English punctuation switch, default punctuation mode, Full/half width switch, default full/half width mode, Simplified/Traditional Chinese output switch and 2nd/3rd candidate submission. Learn about this new option in Microsoft Pinyin settings > Keys. We’ve also added a new hot key to open the emoji panel (Ctrl + Shift + B), so you can open it directly without having to first have the candidate window visible.
Roaming self-learned phrases: In the last build flighted to Insiders we mentioned that the Microsoft Pinyin IME now supports imported and exporting self-learned phrases. This week, we’re happy to announce the natural extension of that work: If you have an MSA connected to your device, your self-learned phrases will now roam between all of your MSA connected PCs.
The Microsoft Pinyin IME emoji panel gets a redesign, new predictive emoji, and stickers: Since their conception, emoji have become an important tool for quickly convey thoughts. Along with our new keyboard shortcut (CTRL + Shift + B), we’ve updated the look of our emoji panel to make it easier to find the emoji, kaomoji and symbols you’re looking for. We’ve also added a totally new section: Stickers! The stickers tab will appear for apps that support sticker input. In addition, based on the words you type, we will now bubble up suggested emoji and stickers. Simply type something and then click on the face icon in the candidate pane (or use the new hotkey, tap the thought bubble, and the emoji predictions will be presented to you.
Making it easier to type complex input faster: Since there isn’t any pinyin starting with U or V, previously the Microsoft Pinyin IME would primarily just give English suggestions in that case, Knowing that about how pinyin is written, we’ve taken the opportunity to add two new modes: U-mode and V-mode. U-mode can now be used for advanced input features, like inputting complex characters, and V-mode can be used to input content which normally is not easy/quick to type (for example, 2016年6月6日”, “十三时三十分”, or “壹仟贰佰叁拾肆”). Try these new modes out today and let us know what you think! Once you start typing “u” or “v” with the IME on, a tip will appear displaying all the available options.
Name input mode: Since most names are not commonly used words, it can be difficult to type with the IME because the correct candidate will appear far down the list (or not at all). In order to solve this problem, we’re introducing a new name input mode for the Microsoft Pinyin IME. When you enter name input mode, instead of your normal candidate predictions, all candidates will be from a dictionary of names, thus making it more likely you’ll find the one you want. Press the ";" key (in double pinyin mode, press "Shift +;" key combination) and then press the "r" key to enter the name input mode. Name input mode can be disabled or enabled in the Microsoft Pinyin settings page.
Custom double pinyin schemes: Double pinyin is a method for creating shortcuts that speed up typing. With Build 14993, Microsoft Pinyin IME users can now add, edit, or delete custom double pinyin schemes, so you can create the one that feels best to you. To do this, go to the IME > General settings, and switch the pinyin style from Full to Double. You will then be presented with options for setting up the scheme of your choice
Japanese Input Method Editor (IME) Improvements:
Thank you everyone and keep hustling,
Dona <3
What’s new in Build 15002
Microsoft Edge Updates
The Microsoft Edge Team has lots of new features to share, focused on making it easier than ever to keep track of your tabs and pick up where you left off, as well as a few other surprises!Tab preview bar: It’s easy to lose track of what’s in your tabs, especially when you have many tabs from the same site, with similar titles and icons. Tab preview bar allows you to easily glance at a visual preview of every tab you have open without leaving your page. You can scroll through the list with touch, mouse wheel, or a touchpad. Just click the chevron icon next to your tabs to get started. Give it a try and let us know what you think!
Start and Shell Improvements
Tile Folders in Start: As part of our ongoing effort to converge experiences across devices, and to address your feedback, we’re excited to let you know that with today’s build you will now be able to group your Start tiles into folders. Tile folders are a way for you to organize and personal your tiles in Start, and we’re happy to now bring this to Windows 10 PCs. To get started, drag and drop a tile on top of another tile in Start to create a folder.Updated Windows Share experience: We have redesigned the Windows sharing experience to be more app-focused and integrated with where you are sharing from. The new Windows Share experience will pop-up the new share flyout within the app you are sharing from and give you a list of applications you can share to. This list changes based on your usage.
Windows Ink Improvements
We have updated the Windows Ink pen, pencil and highlighter control to now visually indicate which color is selected. You can try this out now in the Windows Ink Workspace. Other apps can take advantage of this with future updates of the Windows 10 Creators Update SDK.In addition, thanks to your feedback, we’ve added point erase to the Windows Ink Workspace’s Sketchpad and Screen Sketch. This means that now you have the option of deleting your whole ink stroke or erasing only pieces of it. You can select your desired option by tapping the eraser icon, where you’ll find new options to switch between eraser types.
More Cortana improvements
Easier discovery of Cortana’s app-specific commands: Many of our awesome app developers have been adding commands for Cortana to help you get where you need to go even faster—for example directly launching radio stations, playing movies, or searching for recipes. For apps that support these commands, we will now bubble up suggested commands as you type the app name in Cortana. Clicking a particular suggestion launches the app with that command. Once you know the command, you can also trigger it by simply saying it to Cortana. Not sure which apps have added this feature? Check out this handy Store collection: Better with Cortana! Once you’ve downloaded an app, you’ll need to launch it once. Wait a few hours, and everything will be all good to go.More recurrence options for Reminders: We’ve heard your feedback, and with this build of Windows we’ve added a new option to set recurring time-based Cortana Reminders for “Every Month” or “Every Year” —great for bill payment or anniversary reminders!
Accessibility Improvements
A more inclusive experience out of the box: The Windows Out-Of-Box-Experience (OOBE) Team has been working to reimagine how people set up their PCs for the first time. Our goal is to make this simpler and more accessible so every person powering on their new PC can independently set it up. While we have made numerous improvements in past releases to achieve this goal, we now want to take it to the next level where people can listen and respond to Cortana verbally (when asked questions*) to further simplify and make the setup process more accessible to even more people.This new experience is still a work in progress, so there are some places that still include the older OOBE pages and Cortana is unable to help you get your PC fully set up. We plan to continue to do more work on this so stay tuned! While you can’t access the Feedback Hub during OOBE, please take a moment once you've reached the desktop to complete the Quest and log feedback in the Feedback Hub.
Windows Defender Improvements
We continue to make improvements to the new Windows Defender app in Windows 10. Improvements in this build include:- New options to run quick, advanced, or full scans.
- Device performance and health scans give you a report on your PC’s health.
- Family options has visual improvements and links you to great content/applications on the web to set up a family or view device information.
- Settings pages to change configuration on the app or learn more about it
- General bug fixes and improvements.
Settings Improvements
Helping you find the setting you need in Settings: One of our ongoing goals has been to make Settings easier and faster to navigate. Previous updates towards this have included improved Settings search, and adding icons uniquely associated with each Settings category. Based on feedback, we’ve made a few more design tweaks with this build:- Settings pages now contain additional information on the right or bottom (depending on the window size) providing links to support, feedback, and any other related settings if available.
- Since our System Settings list was getting quite long, we’ve moved app related settings out of System into a new category called Apps.
- You will notice that the header on the landing page of each Settings category will now stay in place as you pan the page.
Improving your precision touchpad experience:
Adjusting the volume control experience: When assigning three or four-finger swipes to control volume, the volume control UI will now appear as you're changing the volume. We have also fine-tuned the gesture, so it now takes less swipes to adjust the volume by a significant amountPolishing the Touchpad Settings page: Based on user feedback, we have made some UI improvements to the new touchpad settings page, including creating two new groups for three and four finger swipes, updating search terms to make them more discoverable, providing more flexibility to control how taps work, and fixing an issue where Touchpad Settings wasn't showing an icon next to the name.
BSOD is now GSOD
In an effort to more easily distinguish Windows Insider reports vs the reports of those on production builds, we’ve updated the bugcheck page (blue screen) to be green. Released versions of Windows 10 will continue to have the classic blue color, including the final release of the Windows 10 Creators Update.Quick Virtual Machine Creation in Hyper-V
Hyper-V Manager has a new page that makes it faster and easier to create virtual machines. Just open Hyper-V Manager and click 'Quick Create'. The simple wizard will help you set up a VM in just a few clicks. After the virtual machine has been created, the confirmation page will allow you to connect to it or enter advanced settings.This is still a work-in-progress and we would love to hear what you think. Next time you need a VM, please give it a try and send us your feedback!
Improving your update experience
We’ve already made a number of updates based on the feedback you’ve shared with us and today we’re happy to let you know there are some more headed your way:- We’ve added an option that will enable you to pause updates on your computer for up to 35 days. To pause your machine, go to the Advanced options page of Windows Update Settings. This capability will be available on Professional, Education, and Enterprise editions of Windows.
- We’ve added an option that will now allow you to decide whether or not to include driver updates when you update Windows. This capability will be available on Professional, Education, and Enterprise editions of Windows.
- We’ve added a new icon to the Windows Update Settings page to make easier to see your update status at a glance. This update status and experience is consistent with the experience you’ll find in the new Windows Defender dashboard.
- We've made some improvements to our logic to better detect if the PC’s display is actively being used for something, such as projecting, and avoid attempting to restart.
- Windows Insiders with the Home edition of Windows will now also be able to leverage the increased 18 hour max window for Active Hours.
Windows Information Protection improvements for business customers
Placing Work Files on Removable Drives: Some enterprise customers have found that saving Work files to a removable drive would prevent them from accessing the files on a different device due to encryption. We’ve added a prompt to let you choose what you want to do in this case, which should make it easier to transfer work files to a removable drive:- When copying Windows Information Protection (WIP) encrypted files to a removable drive, we now ask if you want to keep your files as Work, convert them to Personal, or cancel the copy operation.
- When saving Windows Information Protection (WIP) encrypted files to a removable drive, we now ask if you want to keep your files as Work, convert them as Personal, or save to a different location.
Power usage experiments on select Windows 10 devices
We are running experiments on a small set of Insider devices to evaluate an upcoming Windows 10 Creators Update feature which helps improve Windows battery life. Depending on the experiment configuration, you may see one or more applications reported as “throttled” in the task manager (see insert). The experiment should have no noticeable impact on your user experience and we look forward to hearing your feedback. Please share your experience with us through the feedback hub (under “Power” category & subcategory “throttled Applications”). In support of this experiment, some of you will also see a new power slider in the battery flyout; we’re still experimenting with these power modes that this slider sets. Stay tuned for more updates mid- February 2017.Input Method Editor (IME) Improvements
Improved access to Microsoft Pinyin IME settings when using the language bar: We’ve heard your feedback – last week it was going to be easier to access the appropriate settings with the IME mode indicator. This week we’re happy to announce that the same will be true for those who prefer the language bar, as we’ve updated the settings icon to now directly open IME settings.New settings page for Microsoft Pinyin IME: To go alongside with the new customization options we’re adding for the IME, we’ve revamped the Microsoft Pinyin settings page – now divided into 5 categories so you can more easily find what you’re looking for. Have a look through the new settings and setup your IME experience the way that feels best to you!
- When the IME is turned on or off (by you or an application), we will now display a large indication of the current mode in the center of the screen. This is to help be more aware of active mode and avoid unexpectedly typing in the wrong mode. This large indicator can be turned on or off in the IME Properties.
- We've changed the length of the composition string to now show 3 predictive candidates by default. This will not impact those who have previously adjusted the length. If you'd like to change the length, there is an option to do so on the IME's Advanced Settings > Predictive Input page.
- We've changed the logic to show English words more frequently as predictive candidates so that IME users can input English words more easily if they choose to leave the IME on.
Windows Insider Program website updates
We are starting to update the Windows Insider Program website with new content, first starting with the landing page. We would love to hear your feedback on other changes that you would like up to plan for future updates at Feedback Hub - Windows Insider Program.Other changes, improvements, and fixes for PC
- We’ve updated how Start works to improve performance and reliability. Use Start as you normally would and file feedback if you encounter any unexpected issues
- The 3D Builder app has been moved to the "Windows Accessories" folder on Start.
- We fixed an issue where the display brightness keys on some devices weren’t working as expected.
- We fixed an issue where the display may stay black after resuming from sleep if a USB display is connected.
- We fixed an issue where opening an app that uses the camera, such as the Camera app, would sometimes result in a bugcheck.
- We fixed a crash in the RPCSS service which in turn was resulting in some Insiders experiencing CRITICAL_PROCESS_DIED bugchecks on recent builds.
- We fixed an issue for touch keyboards sometimes requiring multiple clicks to invoke on non-touch PCs.
- We fixed an issue where Disk Cleanup would sometimes unexpectedly show 3.99TB worth of Windows Update Cleanup files.
- We’ve updated our logic so if the Microsoft Edge window is narrow and Cortana has a tip, Cortana will only appear as an icon in the address bar. If you expand the window, you’ll see the full suggestion as before.
- We’ve updated tooltips for the Microsoft Edge favorites bar to wrap around for longer website names rather than truncate.
- We fixed an issue where Touchpad settings page via Settings > Devices > Touchpad wasn’t displaying an icon next to its name in the navigation pane.
- We fixed an issue that may have resulted in a recent drop in Action Center reliability for Insiders.
- We’ve updated the Speaker Properties dialog to now allow you to configure Spatial Audio for different endpoints. If the current playback device has Spatial Audio enabled, the volume icon in the notification area will now indicate this.
- We’ve made some tweaks to the backend for how users connect to devices, such as Miracast displays and other PCs. Use the Connect UI (WIN+K) as you normally would, and file feedback if you encounter any issues.
- We’ve removed the rerouting of mspaint.exe to Paint 3D – appreciate everyone who’s shared feedback on the Paint 3D experience, please keep it coming.
- We fixed an issue Insiders may have experienced on recent builds where navigating to OneDrive folders could unexpectedly result in popup saying there had been a “Catastrophic Error”.
- We fixed an issue that could result in a Visual Studio crash when trying to open, add, or save a file.
- We fixed an issue resulting in some Insiders using PCs with certain older chipsets from seeing colored boxes in the place of text and various other UI in UWPs apps.
- When you use Miracast to a device that supports input (for example, an Actiontec Screenbeam or Miracast-enabled Windows 10 PC), you will now see a toast notification to help you enable input (touch, keyboard, etc) on that device.
- We fixed an issue where the Home and End keys were unexpectedly not working in certain Settings pages, for example "Apps & features".
- Fixed an issue that could cause some progress indicators in UWP apps to appear to wobble or glitch.
Dona <3
#609
When are they going to fix the "calculator opens super slowly from keyboard shortcut"...
I have a keyboard shortcut assigned to open the calculator. Sometimes it takes 5-6 full seconds after hitting the key combo for the app to open...
#610
Go Giants
never
#611
Sanest Florida Man
Tried it on different PCs?
#612
You have a keyboard shortcut set up for it?
This is a known and well reported issue.
#613
Sanest Florida Man
My Logitech keyboard has a calculator icon on it. If I hit Fn+ F7 it opens the calculator app.
Another way is to make it one of the first 10 icons on your taskbar and if you hit win key + n (n being the number of that icon from left to right) it will open it then. You've been able to that since Vista and that works fine for me too.
#614
I simply put a shortcut on the desktop (which I use as well and works instantly) and then open properties for the shortcut and assign a key combo for the shortcut. Using the key combo on W10 it takes 5-6 seconds to open the app. Double slicking on the shortcut it opens immediately. On W7, the key combo opened the program instantly.
#615
FFS...
I am so effing tired of MS forcing reboots of my W10 machine for updates no matter WHAT internet solution I do...
Who in their right mind thought this was acceptable?
I have edited the group policy, edited the registry, leave a user logged in, etc. and it still logs me off and reboots.
Go ahead, ask me why my production machines are still W7Pro....
#1 STUNNA (01-13-2017)
#616
Sanest Florida Man
They're definitely too aggressive with their updates, no way to delay reboot indefinitely.
With the next update you'll be able to turn off Windows updates for up to 35 days.
Also they've decided to take "Control Panel" out of the Win + X menu and replaced it with settings. But if you search setting for control panel it will open it.
stogie1020 (01-13-2017)
#617
Bizzaro world. I find Control Panel SO much easier to find what I need in than "Settings"...
#618
Hate the settings.
#619
Outlook 2016 issue.
I need to copy the name of an attachment that was sent to me. There is NO EFFING way to do it without saving or opening the attachment.
Since MS wants the UI to be consistent across keyboard and touchscreen users, they make the attachment huge for the file icon so it's easy to "press" with a finger, but in doing so only show half the file name...
Thanks MS...
Thanks MS...
#620
FFS...
#621
Microsoft offers free Windows 10 upgrades to certain customers - TechRepublic
Windows customers who have subscriptions through the Cloud Solution Provider program can now upgrade their Windows 7 and Windows 8.1 PCs to Windows 10 for no cost.
#622
Sanest Florida Man
That free upgrade using the assistive technology link still works
#623
Go Giants
yep
#1 STUNNA (01-22-2017)
#625
Sanest Florida Man
For real? I was curious about that just wasn't sure. I haven't tried it since the free upgrade period "expired".
It seems they're still willingly giving 10 away if you want it. They want everyone on 10 so they aren't going to do anything that inhibits that
#626
Sanest Florida Man
I can confirm that you can do a clean install of WIndows 10 on a PC and it will still pull the Windows 8 product key saved in the BIOS and activate 10 with it.
The following 2 users liked this post by #1 STUNNA:
doopstr (01-25-2017),
YeuEmMaiMai (02-08-2017)
#627
#628
#629
I regularly switch between W7 and W10 and need a hand with something.
On my W7 machines, I very regularly use a certain keyboard shortcut that I cannot seem to find a replacement for in W10.
While in a folder, I often need to create a new item, perhaps a folder or perhaps an Excel spreadsheet. In W7 I hit Alt-F, then W and I have a menu of items to "create 'new' with the focus already on a folder. All I need to do it hit "enter" and the folder is created, or I can choose from the menu for a different file type.
I know about the W10 CTRL-SHFT-N for a new folder, but I am trying to figure out how to get the "new" menu rather than ONLY create a new folder. I know it's available as I can Right-click in a folder and choose "new" and there it is, but I am looking for a keyboard shortcut to get there....
#630
Sanest Florida Man
alt,h,w,f
type one after the other not at the same time
that makes a new folder but it opens the same menu and you can create an excel file as well
stogie1020 (03-03-2017)
#631
That works, thanks. I wonder if there is any way to remap those keyboard shortcuts to make them the old Alt-f, W just for consistency sake.
#632
Win 10 Creators Update out April 11 : https://blogs.windows.com/windowsexp...pands-markets/
#633
Sanest Florida Man
The Windows 10 Creators Update is now available for manual upgrading
https://arstechnica.com/information-...ual-upgrading/
The "official" release of the Windows 10 Creators Update, version 1703, won't come until Patch Tuesday on April 11, but if you want to upgrade now—and don't want to enroll your system in the potentially unstable Windows Insider Program—you can now do so.
The Windows 10 Update Assistant will upgrade any Windows 10 Home or Pro system to the Creators Update; you'll need to grab the latest version of the Assistant and then run it, but it should be straightforward enough. If you're upgrading more than one machine or want to perform a clean install, the Media Creation Tool, available from the same link, is the better bet; the Media Creation Tool can fetch an ISO to burn a DVD or create a bootable USB drive, and that can be used for bare metal installs.
The Creators Update itself is build 15063.0, but there will be a small Cumulative Update delivered on April 11. Previews of this patch have been rolled out to insiders, with the fast ring Insiders on 15063.14 and slow ring Insiders on 15063.13. Using the Update Assistant or Media Creation Tool appears to also update to 15063.13. This situation may well change by the actual release day next week.
If you're already in the Insider Program and want to get off that train, now is a good time to do so. If you elect to stop receiving Insider builds in the Windows Insider Program section of the Settings app, you'll be asked if Windows should "Keep giving me builds until the next Windows release." Pick that option and you'll continue to receive the previews of Cumulative Updates until Tuesday, at which point your system will revert to only receiving the stable updates. This is a handy way of making sure you don't accidentally overshoot and receive a post-Creators Update build.
New builds of the next major update, likely to land in about six months, will soon be shipping. As has been the pattern in the past, the initial Insider builds won't include much in the way of new functionality, with Microsoft instead using them to continue refining its engineering processes to handle development of the OneCore unified Windows platform and the migration to Git source control.
#634
Weird W10 occurrence...
I often lose the ability to drag and drop. Desktop items, emails in Outlook (from inbox to folders), etc.
It is NOT the hardware. I RDP into other machines (W7) and drag and drop works fine via RDP on those machines. Additionally, I plugged a basic wired mouse into the W10 machine and it has the same issues.
I reloaded the Logitech setpoint software anyway to be sure, no joy. I also removed the setpoint software and the problem persists.
The only way to get drag and drop back easily for me is to CTRL-ESC to open the Start menu. Clicking on Start and pressing the keyboard Start key do not work to recover drag and drop abilities.
Any ideas?
Any ideas?
#636
Has Microsoft announced an upgrade to Windows 7 yet?
#637
#638
Sanest Florida Man
Based off of this I've made a .bat file that you can run that automates the uninstall of a bunch of Windows 10 apps that come with Windows 10. This won't uninstall Apps that MS considers part of Windows 10 like the Cortana, Xbox, or Hololens apps. But it gets rid of Candy Crush, all the Bing apps, skype, solitaire, Netflix, twitter, etc. You can add or delete to it if you want. The letters in between the asterisks is what the command will search for, if your search term gets multiple results then anything matching that term will be removed. For example the *bing* removes Bing News, Bing Finance, and Bing Weather. You can also search for multiple terms to narrow down a search. For example I use *power**dell* to find and uninstall PowerDVDbyDell (can't remember the exact title of the app), that was the only app the met both of those search terms so it was uninstalled. If app that's on this list isn't on your PC then it just skips over it, it doesn't error out. Just save it as a .bat file and run as admin.
Code:
PowerShell -Command "Get-AppxPackage *3DBuilder* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Getstarted* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *WindowsCamera* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *bing* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *MicrosoftOfficeHub* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *OneNote* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *people* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *WindowsPhone* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *photos* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *SkypeApp* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *solit* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *WindowsSoundRecorder* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *windowscommunicationsapps* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *zune* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *WindowsMaps* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Sway* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *CommsPhone* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *ConnectivityStore* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Microsoft.Messaging* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Facebook* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Twitter* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Drawboard PDF* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Minecraft* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Candy* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Bubble* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Plex* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Sketchbook* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Power**Dell* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Cyberlink* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *3Dviewer* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *Netflix* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *keeper* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *microsoft.reader* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *powerbi* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *eclipsemanager* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *pandora* Remove-AppxPackage" PowerShell -Command "Get-AppxPackage *actiprosoftware* Remove-AppxPackage"
stogie1020 (10-05-2017)
#639
Sanest Florida Man
We just purchased an Enterprise license and a lot of this junk was on the Enterprise version too. But that'll get rid of a lot of it in about a minute
#640
Did the Win 10 v. 1703 upgrade last night from v. 1607 and it messed up my laptop. It didn't detect my ethernet or wireless card. Now I cannot get online. Will have to roll it back to 1607.
Prefer the old pre-Windows 10 update method where I got to choose what updates I wanted to get.
