MacBook Pro
MacBook Pro
I have this laptop, it`s a cool machine, aluminum body, backlit keyboard, nice screen. My question is if I can upgrade this computer or optimize it? Just need it for browsing the internet. Right now it works well when it wants to and lags at other times.
Here are some specs:
Model Name: MacBook Pro
Model Identifier: MacBookPro5,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.66 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache: 6 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
L2 Cache: 6 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Put a SSD drive in it and it will be like brand new.
Good candidate for SSD
Unfortunately IIRC, that model's max RAM capacity is 4GB so you're stuck there. It's a decent machine though so will get a definite improvement with an SSD
The Third Ball
Received 4,824 Likes
You should also run some form of optimization software every once in awhile.
Originally Posted by Nicks2001tl
What about doubling the memory from 2x2gb to 2x4gb?
Upgrade options for MacBook and MacBook Pro 'Unibody' Models
OWC tested to support Maximum Memory up to 8.0GB:
MacBook Pro 15" 2.66GHz (All)
Works with Model Identifiers: MacBook5,1; MacBookPro5,1; MacBookPro5,2; MacBookPro5,3; MacBookPro5,4; MacBookPro5,5; MacBookPro6,1; MacBookPro6,2 & MacBookPro7,1
And MacBook Pro "Core 2 Duo" 2.66 15" (Unibody) Specs (Late 2008/Early 2009*, MC026LL/A, MacBookPro5,1, A1286, 2255) @ EveryMac.com says it unofficially supports up to 6 GB but 3rd parties have been able to upgrade to 8 GB
Apple MacBook Pro "Core 2 Duo" 2.66 15" (Unibody) Specs
Identifiers: Late 2008/Early 2009* - MC026LL/A - MacBookPro5,1 - A1286 - 2255
Quietly unveiled without a press release, the MacBook Pro "Core 2 Duo" 2.66 15-Inch (Unibody/Early 2009) is officially the same as the MacBook Pro "Core 2 Duo" 2.53 15-Inch (Unibody/Late 2008) that it replaced -- and like all other "Unibody" models, has a case milled from a single block of aluminum -- but replaced the 2.53 GHz processor with a 2.66 GHz one (unofficially it also supports an additional 2 GB of RAM).
Standard RAM: 4 GB
Maximum RAM: 8 GB*
By default, 4 GB of RAM is installed as two 2 GB modules, no slots free.
*Apple officially supports a maximum of 4 GB of RAM but third-parties have been able to upgrade the system to 8 GB of RAM using two 4 GB memory modules regardless of the installed operating system.
Standard RAM: 4 GB
Maximum RAM: 8 GB*
But if the OP just needs it "for browsing the internet," 4 GB is enough.
juniorbean
03-11-2016 09:22 AM
CLOSED: Brand new afe air filter pro dry
Daniel Omar Ramirez
01-29-2016 02:48 PM
lil12002
01-28-2016 03:56 PM
zup2sky
01-19-2016 11:59 AM
