ROTORA Slotted and Drilled/Slotted Rotors Special: CL, TL, TSX
This is an Acurazine special pricing event for the ROTORA Slotted and Slotted/Drilled (Combo) Brake Rotors. The pricing event will consist of the ROTORA Slotted rotors for the Acura CL (97-03) 2.2L, 2.3L, 3.0L, 3.2L, TL (99-07) 3.2L (Brembo and non Brembo), and the Acura TSX (04-07). Here is some information on ROTORA's OE replacement rotors:
Developed with the same parameters as the Original Equipment (OE) specifications in both quality and finish, Rotora’s direct replacement brake discs are assured to meet and exceed all vehicle manufacturers’ specifications and tolerances under the worldwide ISO 9001 quality standards. CNC machined and balanced for optimum performance, Rotora’s brake discs feature special segmented slot, or drill & slot pattern which is applied to the disc’s front and back surfaces to ensure maximum heat and gas dissipation for greater stopping power and minimize warping and cracking caused by repeated, high stress, high temperature braking. With an “e-coat” (black) plating finish as an added protective layer to reduce corrosion and prolong disc life, Rotora’s brake disc quality guarantees top performance and longer durability.
Mill balanced to eliminate disc vibrations.
Uniform thickness and finish of braking surface to ensure improved pad to disc fitment.
Precise tolerance to ensure correct run-out.
Rotora's slotted and combo performance rotors are double disc ground and milled balance to ensure all OE specifications and provide maximum stopping power.
Slotted Disc: Segmented slot pattern for improved pad grip and pedal feel. Cleans away debris between pad and disc. Minimize warpage and brake fade.
Drilled & Slotted Disc: Segmented radius drill & slot pattern for improved pad grip and reduce noise. Cleans away debris between pad and disc. Ensures heat and gas dissipation.
Shipping times will depend upon your location. Prices do NOT include shipping. PM me with your zip code, vehicle model, year, and parts desired to get shipping quotes.
The following payment terms are accepted: Bank or Teller Check, Money Order, sent to:
Excelerate LLC
998 West Main St
Branford, CT 06405
You may also send payment to Excelerate@sbcglobal.net via Paypal. However, if you pay through Paypal you must add 3% to the transaction. When you send payment specify what you're ordering and for what year and model Acura.
Applications are taken straight from www.rotora.com or ROTORA's catalog. The prices will run as follows. Please PM me with with your zip code and vehicle model and parts desired to get shipping quotes:
****IF YOU BUY A FRONT AND REAR ROTOR AND PAD PACKAGE WE WILL COVER THE CC/PAYPAL FEES****
Acura CL V6 (01-03)
- ROTORA Front Slotted Rotors - $175/pair
- ROTORA Rear Slotted Rotors - $165/pair
- ROTORA Front Combo Rotors - $210/pair
- ROTORA Rear Combo Rotors - $200/pair
- Russell Stainless Steel Brake Lines (F&R) $110
Acura CL 2.2L (97)
- ROTORA Front Slotted Rotors - $130/pair
- ROTORA Rear Slotted Rotors - $130/pair
Acura CL 3.0L (97)
- ROTORA Front Slotted Rotors - $155/pair
Acura CL 2.3L (98-99)
- ROTORA Front Slotted Rotors - $140/pair
- ROTORA Rear Slotted Rotors - $125/pair
Acura CL 3.0L (98-99)
Acura TL 3.2L (99-03)
Acura TL 3.2L (04-07) excluding Brembo caliper
Acura TL 3.2L (04-07) w/ Brembo caliper
- ROTORA Front Slotted Rotors - $225/pair
- ROTORA Front Combo Rotors - $290/pair
Acura TSX (04-07)
- ROTORA Front Slotted Rotors - $180/pair
- ROTORA Rear Slotted Rotors - $140/pair
- ROTORA Rear Combo Rotors - $165/pair
Acura CL/TL/TSX (All years and models except TL w/ Brembos) (Different part #'s, same prices)
- ROTORA H2 Ceramic Front Pads - $75
- ROTORA H2 Ceramic Rear Pads - $60
Acura TL w/ Brembo Calipers
- ROTORA H2 Ceramic Front Pads - $90
AIM Screen Name: Excelerate04
E-mail: Excelerate@sbcglobal.net
or PM me.
RETURN POLICY
- ALL RETURNED AND/OR CANCELLED ORDERS ARE SUBJECT TO A 25% RE-STOCKING FEE PLUS ALL SHIPPING CHARGES (Includes original and return S&H fees).
- ALL AUTHORIZED RETURN MERCHANDISE MUST BE NEW, UNUSED, AND IN ITS ORIGINAL PACKAGING. ALL DOCUMENTATION, WARRANTY CARDS, INSTRUCTIONS, AND HARDWARE MUST ALSO BE RETURNED.
- ITEMS MAY BE RETURNED WITHIN 15 CALENDAR DAYS FROM THE RECEIPT OF MERCHANDISE.
- SPECIAL ORDERS ARE NOT RETURNABLE.
- ALL DEPOSITS ARE NON-REFUNDABLE.
EXCELERATE LLC
998 West Main St
Branford, CT 06405
(P) 203-483-6100 (F) 203-483-6101
www.ExceleratePerformance.com
Joshua Lockwood
Owner[/QUOTE]
Excelerate LLC
998 West Main St
Branford, CT 06405
Acura CL V6 (01-03)
Acura CL 2.2L (97)
Acura CL 3.0L (97)
Acura TSX (04-07)
or PM me.
RETURN POLICY
EXCELERATE LLC
998 West Main St
Branford, CT 06405
Joshua Lockwood
Owner[/QUOTE]
Just FYI I have tons of rotors here and they will ship immediately after the payment is received.
Also, the ROTORA H2 Ceramic pads that I am selling are the same pads that ROTORA uses with its big brake kits. So therefore the quality is extremely high and it will brake well without all the squealing and dust known to occur with other brake pads.
ive been having really bad time with my Axxis Ultimate Ceramics.. the way it squeals like crazy all the time really gets on my nerves..
how does the rotora rotors and pads sounds and perform?? if you tested it before and doesnt have any problems, i'll add the price of the rotors and pads to the Injen intake im about to pay for too...
shipping cost on both rotor and pad to 07661
Blackbird baby..
I switched to the Rotora slotteds w/Akebono ceramics about a year or so ago.. Absolutely love the rotors. The pads could use a little more bite sometimes but it's a solid setup. No squeals whatsoever. And the brake dust is a minimum (which might partially explain the lack of squealing too)
Also put SS brake lines on.. makes a huge difference with pedal feel.
Anyone considering rotors--the Rotora slotted are awesome.
PM sent.
Masshole
Wow, the rotors and pads were waiting for me when I got home today. That was some seriously fast shipping!
I know who to buy from again if I need something for the CL-S.
mine still hasnt gotten here yet.. but im never home anyways.. do they waiver the packages? (meaning they drop it off at the door even if no one's home)??
wish i can get it by tomorow so i can get it put in on saturday, or sometime during the weekend..
ABP TL
Excelerate is a great vendor; contected him on friday afternoon and i already received my new 4 rotora rotors plus pads as he advertised. great communication.
anyways i am giong to install them within an hour, we will see how good are they :P
ps thanks excelerate for that faaaaast shipping
steve
steve
Originally Posted by Excelerate
I still have a number of rotors in stock.
More $$? (Realize they may not be available for this group buy).
2. Do Porterfield pads work with this Rotora?
Originally Posted by NighthawkBlue
1. What would be advantage of drilled as well as slotted?
2. Any pad should work with the rotors. You can contact ROTORA to be certain. What material is the pad made of? Is it oversized?
