Good Machine Shop in AZ???
My car was giving me P0300 codes:annoyed; misfire all cylinders, I did all the test for the coils, injectors, and pulled the plugs to inspect all passed. Then I did compression test, here is what I found:
Cylinder:
1: 160
2: 225
3: 220
4: 215
5: 225
6: 45
With this info it was clear why it was misfiring, the other codes could have been from these two and a combo of valve adjustment needed and new timing belt.
I did my own version of a leak down test I took the schrader valve out of my compression test hose, put the affected cylinders at TDC and put the hose back in hooked it up to shop air and listened for the leak.
Found it on the intake, so I know I need new valves, what I would like to know is where is a reliable machine shop in the Phoenix, AZ area????????
Cylinder:
1: 160
2: 225
3: 220
4: 215
5: 225
6: 45
Shipit (05-06-2012)
The issue I had was a leaking valve, and just needed a valve adjustment. I was doing the timing belt and decided to do the valve adjustment at the same time. This solved the leak in compression, for my situation, and before I pulled the heads off I wanted to make sure it was not the valves, so I did a compression leak down test and heard the leak coming from the intake side and knew I probably wouldn't need to pull the heads.
Feeler gauges
I bought Mine from Snap-on
http://buy1.snapon.com/catalog/item....re&dir=catalog
They are $15.30 and are good value, the lash for the intake and exhaust valves is on the label under the hood, a word of advice watch this video
part 2
and this one
and this one
FwC (11-13-2012)
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
