SOLD: 70mm TB 2G CL/TL
3.5 psi
70mm TB 2G CL/TL
Category: Accessories
Price: $170
Part Fits (you may select multiples): CL 2G, TL 2G, Other Honda/Acura
Location (State/Prov/Terr): Can-ON
Item Condition: Used
The P2R adaptor is brand new never used. I'll also include a 70mm thermo gasket from P2R. To get the IAC working properly you'll need to tap for a vacuum line before the throttle body (into your intake) and after. Because i'm supercharged, my TB is right before the blower and i don't want to tap into the blower for a vacuum line.
Asking $170 obo.
3.5 psi
these engines love to breathe. I measured the s/c inlet at the TB and it is 70mm so you would be getting rid of a bottle neck essentially. I believe the stock TB is 64mm so you're gaining about a 1/4 inch.
3.5 psi
Since you're s/c'ed you would put a nipple where the MAP sensor would go. That would give you vacuum after the TB for the IAC. Then you just need a nipple before the TB to the IAC. P2R uses this setup on their accord.
3 pedals in my 99 TL
since the TB is direct bolt on and I'm running a stock motor (J32A2 from a CL-S6) would I still need to tap a vacuum line for the IAC? if so how is this done. not really sure what it means to tap a line, forgive my noobness. i would love to get this if you don't end up using it for yourself, just need to get an idea of what I'm going to have to do to run it correctly.
3.5 psi
so you would need to have a vacuum fitting/nipple after the TB which you could put on a TB spacer or tap into the neck of your manifold. Youtube "how to drill and tap" and you'll see. then you screw in your barbed nipple. You essentially create a threaded hole to screw something into.
