Metal grinding noise from front driver side
Old 06-17-2013, 09:44 AM
wise_optimist's Avatar
A couple of days ago, I started hearing this high pitched, metal grinding noise coming from the driver side, with the window down. Yesterday, when I lightly touch the brake, i hear this screeching sound that sounds like the indicator is hitting the rotor, but not when I'm really on the brake. I've been playing with it a bit to find out more and I noticed that when I put load onto the front left (braking and turning to the right, or just turning right carrying some speed), the noise becomes more pronounced. I thought it could be the ball joint, but shouldn't that sound more squeaky?
Any feedback is appreciated!
Old 06-17-2013, 09:47 AM
might be the brake pads.
pull off the wheels and check the pad life
Old 06-18-2013, 11:49 AM
Turned out to be a seized rear caliper. Though my mileage didn't drop much and there was no pull...
Old 06-18-2013, 12:10 PM
guitarplayer16's Avatar
I had the exact same problem.
Sound would go away when I applied the brakes.
Replace that caliper!
Old 06-19-2013, 10:38 AM
That's why I was confused. Firmly pressing the brake pedal will cause the sound to go away. It's fixed. Thanks!
Old 06-19-2013, 02:38 PM
MMkay.
Project_CLean's Avatar
Man,i feel like the same problems occur at the same time for a lot of members. Just last week i was reading another thread about seized calipers.
csmeance
09-10-2018 09:15 AM
nanos
11-12-2015 08:41 PM
Ny1718
09-11-2015 09:21 AM
08 NBP TL
09-08-2015 08:49 PM
Quick Reply: Metal grinding noise from front driver side
