That's not a moon, it's a shift knob! - AcuraZine Community
Old 10-15-2012, 10:04 PM   #1
geekybiker
2006 Acura TL
geekybiker's Avatar
Points: 7,763, Level: 59
Points: 7,763, Level: 59 Points: 7,763, Level: 59 Points: 7,763, Level: 59
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
That's not a moon, that's a shift knob!
I was looking through ebay trying to find a cool shift knob a little while ago and couldn't find anything to suit my fancy. I thought "Hey a Death Star shift knob would be awesome!" but no dice. Doesn't really exist. So here's how I made one.
I started with a Titanium series Death Star die cast model. There are two of them, and both out of print, so ebay has them. There is the painted one and the raw metal one that I bought. Both can be had for about $20 loose.
Here's the model as I recieved it.
First step was to turn it over and remove the plug. It just pulls out. You'll throw it away, so feel free to mark it up.
You'll find a small phillips head screw at the bottom of that shaft. Luckily enough that hole is the perfect diameter for the shaft of the shifter. Pull it open and you'll be looking at this
Get a m10x1.5 nut. This is one I had lying in my tool box.
I epoxied the nut in place and then used epoxy putty after testing the fit to build a secure fitting. (Plumbers putty works here, comes in yellow and blue strips.) I also too a dremel cut off disc to the metal shaft on the top half to make room for the nut.
Once the epoxy on the lower half has dried, screw it on the shifter and test fit the top piece to make sure you ground enough of the shaft off. It will also allow you to get the weapon facing the way you want when fully screwed in. Apply some epoxy to the gears on the top dome and all around the inside edge. It'll drip down once you put it on top, so give it a thick coat so it will seal well. Let it harden and then clear coat the whole thing to protect the finish.
Here it is installed.
NBP '06 TL//Progress RSB, //MB Quart Q4.80. Rockford Fosgate 3sixty.2. Image Dynamics CTX65cs. Dayton DCS255-4 10" sub
geekybiker is offline   Reply With Quote
The Following 3 Users Say Thank You to geekybiker For This Useful Post:
BeezleTL85 (10-17-2012), EvilVirus (04-28-2014), greekguy000 (04-26-2014)
Old 10-15-2012, 10:20 PM   #2
pohljm
pohljm's Avatar
Points: 11,762, Level: 71
Points: 11,762, Level: 71 Points: 11,762, Level: 71 Points: 11,762, Level: 71
Activity: 14.1%
Activity: 14.1% Activity: 14.1% Activity: 14.1%
nice and geeky!
pohljm is offline   Reply With Quote
The Following User Says Thank You to pohljm For This Useful Post:
justnspace (10-15-2012)
Old 10-15-2012, 10:23 PM   #3
geekybiker
2006 Acura TL
geekybiker's Avatar
Activity: 1.4%
Forgot to mention you need to file or drill the top of the hole so the shaft can fit through. Not much metal, so it goes quick.
Old 10-15-2012, 10:28 PM   #4
justnspace
2006 Acura TL
Points: 37,222, Level: 100
Points: 37,222, Level: 100 Points: 37,222, Level: 100 Points: 37,222, Level: 100
Activity: 100.0%
Activity: 100.0% Activity: 100.0% Activity: 100.0%
cool mod!
Ding-Dong the Brock is dead!
justnspace is online now   Reply With Quote
Old 10-15-2012, 10:35 PM   #5
DaeHanMeenGuk
DaeHanMeenGuk's Avatar
Points: 2,779, Level: 32
Points: 2,779, Level: 32 Points: 2,779, Level: 32 Points: 2,779, Level: 32
Activity: 0.3%
As a Star Wars fan, this is an amazing mod.
07 CBP TL-S
03 NBP TL
DaeHanMeenGuk is offline   Reply With Quote
Old 10-15-2012, 10:36 PM   #6
Steven Bell
Administrator
Regional Coordinator
(Mid-West)
2007 Acura TL
Steven Bell's Avatar
Trader Rating: (2)
steven.bell www.linkedin.com/pub/steven-bell/7/47b/a10
Points: 53,125, Level: 100
Points: 53,125, Level: 100 Points: 53,125, Level: 100 Points: 53,125, Level: 100
Activity: 99.9%
Activity: 99.9% Activity: 99.9% Activity: 99.9%
LOL....nice write up and good work.
I don't know if I can put it into the TL DIY Garage, but still......
20% Tint--Tinted License Plate Cover--ASM Color Keyed Engine Covers--Momo Shifter Knob--Roof Spoiler--Dead Pedal w/Type S Logo--Carbon Fiber: Interior Trim Kit, OEM Steering Wheel, Emergency Brake & ACURA Nose Logo--Shaved Door Handles--Chrome Inlay Door Handle--Audi Style LED Headlights w/Carbon Fiber inserts & switchback bulbs--ACURA logo'd: Valve Stem Caps, Side Mirrors & License Plate Screw Covers--Red LED interior underdash lights--Nokya 7000k fog lights & DRLs--Red doorlight bulbs--Red ACURA illuminated door sills--Amp'd Emblem lighted nose & trunk "A" logos--H&R Sports Springs--Progress Rear Sway Bar--Eibach Adjustable Rear Camber Kit--5k LED License Plate bulbs--Red Lug Nuts--P2R Chromed Throttle Body Spacer--RV6 V3 Long Tube J-Pipe--Continental ExtremeContact DWS Tires--5K LED Interior Cabin Light Bulbs--AckTL cleared taillights with Carbon Fiber inserts--Red Brembo Brakes and Premium Gold Pads, Red Rear Brake Calipers--Akata Spacers: 15mm (Front) & 20mm (Rear)--Aspec Kit--USR Switchback Side Markers--Rear Brembo Brake Covers--AEM Short Ram Cold Air Intake--Sickspeed Oil Cap--KP Technologies Window Roll-Up Module
Steven Bell is offline   Reply With Quote
Old 10-16-2012, 8:14 AM   #7
EvilVirus
2005 SSM 6MT
Trader Rating: (6)
Points: 5,810, Level: 49
Points: 5,810, Level: 49 Points: 5,810, Level: 49 Points: 5,810, Level: 49
Activity: 19.9%
Activity: 19.9% Activity: 19.9% Activity: 19.9%
pretty sweet g/j op
join the dark side...........we got donuts
Originally Posted by justnspace View Post
The first time I saw a non-circ'd penis was shocking.
it looked like the Alien in Alien with Sigourney Weaver
EvilVirus is offline   Reply With Quote
Old 10-16-2012, 10:27 AM   #8
The Machine
2008 Acura TL
The Machine's Avatar
Trader Rating: (5)
Chip Pelikoski themachine18
Points: 5,489, Level: 47
Points: 5,489, Level: 47 Points: 5,489, Level: 47 Points: 5,489, Level: 47
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Nice work, but is the shift knob heavy enough?
When I had a MT car, I liked having a counter weighted shift knob for a more solid feel when shifting.
My Progress Thread
http://tl.acurazine.com/forums/showthread.php?t=843060
The Machine is offline   Reply With Quote
Old 10-16-2012, 10:34 AM   #9
geekybiker
2006 Acura TL
geekybiker's Avatar
Activity: 1.4%
Its die cast metal, so its reasonably heavy. It is heavier than the stock knob. As a extra bonus, it sits noticeably lower than the stock knob so it feels a little like a short shift kit.
The Following User Says Thank You to geekybiker For This Useful Post:
The Machine (10-16-2012)
Old 10-16-2012, 11:19 AM   #10
SharksBreath
2007 Acura TL
Trader Rating: (33)
Points: 19,965, Level: 89
Points: 19,965, Level: 89 Points: 19,965, Level: 89 Points: 19,965, Level: 89
great job, you did!
SharksBreath is offline   Reply With Quote
Old 10-16-2012, 11:24 AM   #11
ggesq
ggesq's Avatar
Trader Rating: (1)
Points: 36,681, Level: 100
Points: 36,681, Level: 100 Points: 36,681, Level: 100 Points: 36,681, Level: 100
Activity: 17.7%
Activity: 17.7% Activity: 17.7% Activity: 17.7%
suite.
2005 Acura TL slushbox
ABP/Camel w/ Navi
ggesq is online now   Reply With Quote
Old 10-16-2012, 11:54 PM   #12
Airblizzard
Airblizzard's Avatar
Points: 1,659, Level: 23
Points: 1,659, Level: 23 Points: 1,659, Level: 23 Points: 1,659, Level: 23
The only thing that would make that cooler (and possibly more nerdy) is if it lit up from the inside. Nice job.
Airblizzard is offline   Reply With Quote
Old 10-17-2012, 1:01 AM   #13
v|nsan|ty
v|nsan|ty's Avatar
Points: 11,345, Level: 70
Points: 11,345, Level: 70 Points: 11,345, Level: 70 Points: 11,345, Level: 70
Activity: 1.0%
Lol epic mod! +1 for creativity.
07 KBP TL-S
v|nsan|ty is offline   Reply With Quote
Old 10-17-2012, 1:20 AM   #14
geekybiker
2006 Acura TL
geekybiker's Avatar
Activity: 1.4%
Thanks everyone. I just have to let my inner geek shine through.
Old 10-17-2012, 6:49 AM   #15
damaged442
damaged442's Avatar
Points: 1,937, Level: 26
Points: 1,937, Level: 26 Points: 1,937, Level: 26 Points: 1,937, Level: 26
Activity: 3.1%
Activity: 3.1% Activity: 3.1% Activity: 3.1%
These aren't the shift knobs you're looking for...
WIN!
2009 TSX 6MT, Crystal Black Pearl Non-Tech
damaged442 is offline   Reply With Quote
Old 10-17-2012, 8:17 AM   #16
truonghthe
truonghthe's Avatar
Points: 7,076, Level: 55
Points: 7,076, Level: 55 Points: 7,076, Level: 55 Points: 7,076, Level: 55
Activity: 7.7%
Activity: 7.7% Activity: 7.7% Activity: 7.7%
when looking at the shift knob I was LOL, but after that I have to give you great prop for making it happen from your imagination.
MRP / TAUPE / 07 Type S / AT
truonghthe is offline   Reply With Quote
Old 10-17-2012, 12:10 PM   #17
andURpoint
andURpoint's Avatar
Points: 3,527, Level: 37
Points: 3,527, Level: 37 Points: 3,527, Level: 37 Points: 3,527, Level: 37
Activity: 0.4%
...Now witness the fire power of this fully armed and operational TL....
Sorry, couldn't resist....LOL. Kewl mod though.
2006 Anthracite Metallic TL
MODS (So Far): Blue int and door LED's. White LED Tag lights/ Ron Jon Rev's on Falken Ziex 912 in 245/40/18.
andURpoint is offline   Reply With Quote
Old 10-17-2012, 12:42 PM   #18
perilousp
Points: 1,422, Level: 21
Points: 1,422, Level: 21 Points: 1,422, Level: 21 Points: 1,422, Level: 21
Have a friend that is a huge Star Wars fan... maybe I should do this for him great mod for sure though!
perilousp is offline   Reply With Quote
Old 10-17-2012, 1:58 PM   #19
AnthraciteAspec
RPF1+RS3 FTW
2004 Acura TL
AnthraciteAspec's Avatar
Trader Rating: (6)
Points: 8,702, Level: 62
Points: 8,702, Level: 62 Points: 8,702, Level: 62 Points: 8,702, Level: 62
Activity: 2.6%
Activity: 2.6% Activity: 2.6% Activity: 2.6%
Needs a laser pointer built in lol
Cool mod man!
AnthraciteAspec is offline   Reply With Quote
Old 10-17-2012, 4:11 PM   #20
NetoAzul
NetoAzul's Avatar
QuattroDRV
Points: 2,635, Level: 31
Points: 2,635, Level: 31 Points: 2,635, Level: 31 Points: 2,635, Level: 31
This is by far one of the best mods that one can do to a TL lol
NetoAzul is offline   Reply With Quote
Old 10-18-2012, 1:49 AM   #21
Toddy
Chapter Leader (Arizona)
Toddy's Avatar
Trader Rating: (5)
toddy_968 R1PKORD
Points: 9,677, Level: 66
Points: 9,677, Level: 66 Points: 9,677, Level: 66 Points: 9,677, Level: 66
Activity: 1.0%
04 DGP 6MT
Toddy is offline   Reply With Quote
Old 10-18-2012, 6:55 AM   #22
lazytik
Points: 6,889, Level: 54
Points: 6,889, Level: 54 Points: 6,889, Level: 54 Points: 6,889, Level: 54
Haha that's awesome. I have a Storm Trooper hanging from my rearview mirror (my car is white and I'm eventually going for a black and white theme minus the tan interior..). Good mod.
'06 Carbon Grey Pearl RL
'06 White Diamond Pearl 6MT + Nav TL (sold)
'04 Silverstone S2000 (sold)
'06 Anthracite 5AT Base TL (sold)
'94 Red Pontiac Grand Prix (donated)
lazytik is offline   Reply With Quote
Old 04-25-2014, 1:30 PM   #23
geekybiker
2006 Acura TL
geekybiker's Avatar
Activity: 1.4%
Gaby12386, if you're watching this, your PM box is full. PM your email and we'll talk.
Old 04-25-2014, 1:36 PM   #24
justnspace
2006 Acura TL
Activity: 100.0%
just wanted to let you know, I saw your pic on a website and thought it was a TL. Glad you bumped this thread cuz the website even has the same title and even points to this thread:
http://geektyrant.com/news/thats-no-...tar-gear-shift
Old 04-25-2014, 3:07 PM   #25
geekybiker
2006 Acura TL
geekybiker's Avatar
Activity: 1.4%
Yah, its been around the web a few times at this point. Seems every couple months it pops up somewhere. I was kinda shocked nobody had done it yet when I was googling to find one.
Old 04-25-2014, 8:44 PM   #26
CrazyEights
2004 Acura TL
Points: 308, Level: 6
Points: 308, Level: 6 Points: 308, Level: 6 Points: 308, Level: 6
Awesome mod man, wonder if you could a small red led up to where dimple is for the laser.
Nonetheless, props
CrazyEights is offline   Reply With Quote
Old 04-26-2014, 5:57 AM   #27
greekguy000
2007 Acura TL
greekguy000's Avatar
Trader Rating: (1)
greekdaddy000
Points: 3,308, Level: 35
Points: 3,308, Level: 35 Points: 3,308, Level: 35 Points: 3,308, Level: 35
Activity: 1.4%
haha pretty cool - thumbs up for creativity
greekguy000 is offline   Reply With Quote
Old 04-27-2014, 8:11 PM   #28
tomlinsonj
2006 Acura TL
tomlinsonj's Avatar
Trader Rating: (2)
Points: 2,776, Level: 32
Points: 2,776, Level: 32 Points: 2,776, Level: 32 Points: 2,776, Level: 32
Activity: 4.0%
Activity: 4.0% Activity: 4.0% Activity: 4.0%
This is excellent - and a nice thread revival. As a Star Wars fan I can only hope that you've replaced the Acura chimes with "Commence primary ignition" whenever you turn the key.
'06 MT RRP >> Progress Thread
tomlinsonj is offline   Reply With Quote
Old 04-28-2014, 11:00 AM   #29
geekybiker
2006 Acura TL
geekybiker's Avatar
Activity: 1.4%
Heh. I never got into electronics. There wouldn't really be any clean way to run power to the knob anyways. I suppose you could always do a battery operated version. It worked out real well as a shift knob though. Perfect size and nice and solid feel.
2006, acurazine, car, death, illuminate, knob, light, s2000, shift, shifter, shiftknob, star, stick, swap, tl, top
