P0453 - Evaporative Emissions Control System Pressure Sensor High Input
Old 10-01-2012, 03:31 AM
18psi
libert69's Avatar
I cant seem to get rid of this code.
Things I tried.
Replaced fuel cap - no good
Replaced ftp sensor on evap canister - no good
Replaced evap purge valve - no good
Dont know what to do next. Already wasted 150$ on parts with no luck. Once I clear the code, it comes right back as soon as the car is started.
Old 10-01-2012, 08:01 AM
LowNslowTL
nismopowerdqg's Avatar
A P0453 code may be caused by one or more of the following:
  • Open on FTP sensor signal wire
  • Short to voltage on FTP sensor signal wire
  • Bad FTP sensor
  • Abnormally high pressure in fuel tank due to blockage in EVAP purge hoses or overfilled tank
  • Loose/damaged FTP sensor connector
  • Loss of ground to the sensor
hope this helps
Old 10-02-2012, 12:07 AM
18psi
libert69's Avatar
^yea ive read that list before.
was hoping that someone else had this code before and figured it out
ordered a used evap canister on ebay to see it that cures it.
Old 10-09-2012, 03:47 AM
18psi
libert69's Avatar
bump
Old 02-05-2014, 03:10 PM
row2ray's Avatar
I'd like to know how this problem was solved, I'm having thesame problem with my TL
Old 06-19-2014, 01:33 PM
jpm3071's Avatar
Any update on this?
Old 06-19-2014, 02:21 PM
Majofo's Avatar
Old 03-06-2020, 02:16 PM
Nate Dam's Avatar
Possible Solution
I got this same code on my 03 RSX Type s. I replaced the evap canister and the purge valve. I think it may be that the actual wires in the connector become damaged. Talking about the orange plug/connector that plugs into the evap canister. Will see what I can find.
Old 02-19-2024, 06:25 PM
MrBlue's Avatar
Any Update in this Thread?
I am getting the same P0453 code on my 2007 RDX along with P2422, Replaced the FTP Sensor (yellow Circle), Purge valve is open (red Arrow), can plow air thru canister. I Haven't replaced the Fuel cap yet.
cycdaniel
12-17-2019 10:58 AM
SpraykwoN
ILX
09-23-2015 11:44 AM
HeloDown
09-08-2015 06:51 PM
Quick Reply: P0453 - Evaporative Emissions Control System Pressure Sensor High Input
