TL: 2003 tl backseat removal?
I'm trying to gain access to the Bose amp and I was told that I needed to take out the backseat and I can't understand and of the guides I was wondering if someone else could try explaining it to me
Um I don know about gettin to the speaker that way, personally I would just climb inside the trunk lol, ok but u asked for how to take out the backseat, I've done this to add amps and also to allow air flow in the trunk, ok ur goin to need a ratchet with a ten millimeter if I'm correct, k so lift the seat u sit on and take that out Than ur going to see two bolts so now unbolt those now grab each side of the bottom seat and lift now it will unhook from some hinges holding it, vwalah u have it all off now just make sure u put everything back correctly as it can cause safety hazard definitely did when I rolled my tl 5 times tho it was my fault since I wanted easy access to put down the seats for airspace to my subs hope I helped
Pham Alvan
03-16-2016 09:17 AM
dainmezron
10-16-2015 06:56 PM
