03 tl-s overheating..please help
Old 09-20-2012, 02:18 PM
kambo_inspire's Avatar
Ok so I've replaced the t stat and did a radiator flush..but the car still overheats,I've read something about a bleeder valve but I don't kno where its at.I think it might have air in the system but idk also when it overheats the overflow tank boils..someone please help
Old 09-20-2012, 02:49 PM
MilwaukeeDave's Avatar
If its boiling I think there's a leak somewhere. It shouldn't boil unless the pressure is reduced. That's why when it's hot and u take the cap off the antifreeze boils up and out due to increase of pressure.
Old 09-20-2012, 03:06 PM
Ok so any suggestion on where to start looking for a leak?? And don't kno if this is related but b4 the car started to overheat I was driving about 85-90mph on the freeway and ran over some tire debris..u think this could've caused my radiator to crack?? There IS no leak tho that I notice coming from the radiator area
Old 09-20-2012, 04:53 PM
how does the temp come up- normal temp then suddenly hot?
road debris will put a hole in rad!!!
are both rad fans running? driver fan run a few times at stoplights
special tool need to pressure test for leaks- go to a radiator shop
Did you use a honda genuine thermostat==tl picky about that and its position
Burping the system after filling
see owner manual for specifics to your year ,get one free www.owners.acura.com need cars VIN for that
heater must be turned on to hot
you run engine with rad cap off, fill system as needed,,takes 10-20 minutes to be sure its all done
air will cause many problems
Old 11-22-2012, 09:42 AM
mrbustrbrown's Avatar
make sure both fans kick on,mine was overheating too,overlooked the fan and spent alot of money,even new radiator....let idle and wait and see or idle and turn ac on and both fans should be on,if not then buy just a new motor for the fan that doesnt kick on and swap em,problem solved...note..easier to do when u take radiator out
Old 11-22-2012, 10:26 AM
kuba12's Avatar
i have a 2002 acura tl i rebuilt the trans myself i recently put the trans back in my car the speddometer doesnt work and i wont go out of second gear please help
Old 11-22-2012, 11:11 AM
this is a thread about overheating,,not `my trans wont shift!`
please make new thread- `I rebuilt trans- but it wont work`
,,one of our trans gurus that have rebuilt them may be able to help
usually no shift after rebuild is a line not connected or an internal problem with incorrect assembly, clutchpack issue, or bad part
same with speedo
did you install 7.3 qts of honda dw1 atf?
being a holiday today dont expect an immediate response with factual answers too quickly,,but kris and the piggylover should be back soon--those guys know inside the trans
MetalGearTypeS
08-29-2016 08:28 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
Timmy18
10-17-2015 03:58 PM
Acura604
09-28-2015 12:24 PM
UA7_Ando
09-28-2015 07:53 AM
Quick Reply: 03 tl-s overheating..please help
