P2263 Turbo problems
Old 11-21-2013, 04:53 PM
Vividsi's Avatar
I just thought of something, I had to have a new tire put on at discount due to catching a nail, do you think the SH-AWD is throwing a code due to the very different tread depths under hard accelleration? I put the new tire up front due to it being prodominately FWD.
I remember something about Subaru needing to to change out 2 or even all four tires to keep the same tread depth otherwise damage could accur to the AWD system. Somebody check me here if im wrong.
Old 11-25-2013, 08:28 PM
mikerdx's Avatar
Somebody has to have gotten this fixed. The code just disappeared after being on for 2 months. But it is only a matter of time before it comes back I am sure.
Old 01-07-2014, 10:50 AM
shivaswrath's Avatar
is there any aftermarket support for a new/different turbo? $4500 is like a new manifold/kit for most platforms!
09RDX2.3T (03-01-2023)
Old 01-07-2014, 11:32 PM
dcmodels's Avatar
Originally Posted by Vividsi
... I put the new tire up front due to it being prodominately FWD.
The 2009 RDX owner manual says to keep the same size tires on each axle: front or rear - and that means replace two tires, not just one. However, if your old tires are not very worn, then I suppose you could replace only one tire.
Just keep in mind that the handling might be compromised, and also that different sizes of tires on the same axle, will cause the differential (either front or rear) to *work* harder, since the two tires will be rotating at different speeds, even when going straight - in other words, all of the time, not just when turning.
Old 01-07-2014, 11:34 PM
dcmodels's Avatar
Originally Posted by vividsi
... Do you think the sh-awd is throwing a code due to the very different tread depths under hard accelleration? ...
no, because you said the new tire is on the front - but I am only guessing. Just what is the code? how can we even guess without the code?
Old 01-08-2014, 09:04 AM
Vividsi's Avatar
I've never been able to drive directly to a shop without clearing the code by turning off the ignition. Next time it does it I will try.
Old 01-18-2014, 11:04 AM
  #47
dduffner's Avatar
2008 RDX 115k miles turbo problem
I have the same problem. Tried all the standard diagnostics. Dealer says that turbo has to be replaced - waste gate problem.
Old 01-20-2014, 04:12 PM
elizabethvitale's Avatar
Have any of you thought to remove your turbo and give it a good cleaning? The turbo collects a lot of dust in 40,000 miles. I would have thought of this before taking my car to the dealer for the problems you are describing. Maintenance is #1 to the proper mechanical responses from a car engine parts. Codes often only sense the problem not the actual part so could be a number of issues need checked before replacements.
Old 01-20-2014, 08:16 PM
  #49
dcmodels's Avatar
Originally Posted by elizabethvitale
... give it a good cleaning? The turbo collects a lot of dust in 40,000 miles. ...
Not so easy to remove the turbo housing. Clean exactly where? just wondering as I have never heard this suggestion before. The water and oil passages in the housing are sealed. The air intake side should be OK because of the engine intake air filter, unless it has been neglected or damaged.
And the exhaust side of the impeller housing, may be coked from exhaust gases - is that your suggestion, for cleaning? and how to clean?
Old 01-20-2014, 08:46 PM
  #50
Lanesky_OH8RDX's Avatar
Seafoam the hell out of it lmao
Old 01-20-2014, 10:14 PM
  #51
XLR8R's Avatar
Originally Posted by dcmodels
Clean exactly where? just wondering as I have never heard this suggestion before...and how to clean?
Your turbo gets dusty. You should clean your turbo with a loofah, every 40,000 Li.
Old 02-04-2014, 04:58 PM
  #52
problem is acura doesn't want to honor warranty issues in my experiences with acura dealers and manufacturer.
Old 02-04-2014, 05:00 PM
  #53
if the turbo gets dusty as air filters get dirty and oil then there should be auto maintenance on this feature. I vacume mine or have cleaned at an independent rep. Mine is doing well, but I am strict when it comes to taking care of my car.
Old 02-07-2014, 07:58 AM
  #54
Vividsi's Avatar
are you saying you clean the airbox? Because how do you "clean" the turbo if thats what you mean?
Old 02-14-2014, 07:29 PM
  #55
ltcjim505's Avatar
well my 2007 RDX Tech had the same problem. Driving down the interstate and the check http://www.militarybrat.com/birthcerts.cfm and SH AWD lights came on. Checked the video display and there was no power to the rear wheels in the display. Stopped at the dealership on the way home and they identified that the seals on my turbo failed, they showed me a light oil film inside my intercooler. Quoted me just over 3k for the turbo and 900 for labor. Stated that there is oil bleeding through the turbo into the intake and causing the check engine light, plus there is a loss of power from the turbo so the computer identifies the power loss and shuts power to the rear wheels. Can this turbo be rebuilt or is it a replacement?
Old 02-15-2014, 03:33 AM
  #56
FLETCH
TheWrench116's Avatar
ltcjim505
I haven't had issues with the CEL. however I did have a light oil film on the inside of my intercooler. this will happen on a turbo motor that has 0 issues due to the crank case ventilation system which circulates fresh air through the crank case to cool the engine oil and also remove moisture and combustion gasses that get past the rings.
bottom line get a good degreaser (I use purple power) and a decent sized tub fill it with HOT water and stick the intercooler in it and agitate (shake it). be sure to remove the sensors first! after you no longer have any crap coming out of the intercooler dry it off reinstall sensors and pop it back on you should be good to go.
if a seal goes on a turbo your going to have the entire back of the car covered in dirt. and your most likely going to see a trail of smoke following you down the road.
The following 2 users liked this post by TheWrench116:
jngnyc (04-17-2018), ltcjim505 (02-15-2014)
Old 02-15-2014, 09:03 AM
  #57
ltcjim505's Avatar
TheWrench116,
Thanks for the alternative diagnosis. The oil in the intercooler was clean and had made it all the way through it and into the the hose to the intake. That said, it makes sense that the turbo did not fail since I did not have any debris on the rear of the vehicle and did not see smoke behind. After getting over the shock of the cost, i had them reasseble the car and I drove home. The trouble lights did not come on, but the turbo boost guage did not register any boost. I did baby her on the way home but i did accererate quickly a couple of times and she seemed much slower and the guage did not register. If this ends up being a turbo issue, can it be rebuilt?
Old 02-15-2014, 11:45 AM
  #58
After reading all this it makes me worried the turbo is gonna quit before i even pay the car off. Is this a really common issue? I haven't really heard of the turbo itself failing, especially the seal of the turbo itself. The turbo is cooled via oil and engine coolant yes? So if that's the case you would think overheating wouldn't be an issue. I'm all paranoid now. I have technical proficiency just not the cash flow to fix this if this was to quit.
Old 02-15-2014, 08:07 PM
  #59
FLETCH
as a general rule yes turbos can be rebuilt. another thing to look for, is you engine using oil between changes? I don't mean like 1/8 of a qt I mean like 1-2 qts.
ltcjim505
about not having any power did you have a cel coming home from the dealer? if so make sure they put the intercooler back together right by: checking the hose clamps the sensor hook ups and the bypass valve connections. the dealership is notorious for F#$%^& up cars. if your local id be willing to donate time to try to help. also Ebay for used turbos they go for around 450-700 +shipping. way cheaper then a dealer.
ltcjim505 (02-26-2014)
Old 02-15-2014, 09:58 PM
  #60
Barely uses an 1/8th so I'm good i guess.
Old 02-17-2014, 12:06 AM
  #61
dcmodels's Avatar
Originally Posted by TheWrench116
ltcjim505
I haven't had issues with the CEL. however I did have a light oil film on the inside of my intercooler. this will happen on a turbo motor that has 0 issues due to the crank case ventilation system which circulates fresh air through the crank case to cool the engine oil and also remove moisture and combustion gasses that get past the rings. ...
At what mileage did this occur, what year car? no CEL as you say - any other indicators? and why was the intercooler *opened* for you to look inside? which oil have you been using? following the MID for oil changs? since I have not read any other posts indicating this condition, wondering if it is indeed *normal*, as you suggest.
just wondering how I would know if this has happened to my own RDX. Thanks.
Old 02-17-2014, 01:21 AM
  #62
FLETCH
dcmodels the short answer is yes this has happened to your rdx. every motor of every configuration I've ever taken apart has had an oil film in the intake track from where ever the crank case system dumps into it all the way to the intake valve in the head. in the case of the rdx it dumps in right before the turbo inlet and this is where I am trying to figure out how to mount a catch can in this location to give the oil vapor a place to fall out of suspension. most of the other factory turbo cars have them available via the aftermarket support they receive. once I figure out how to do it ill post a DIY. the catch can I installed on my jeep pulls a massive amount of crap out of the crank case and prevents it from getting into the intake track.
this occurred at 20,000 miles using amsoil with no cel. opened it cause im nosy.
Old 02-18-2014, 07:41 PM
  #63
dcmodels's Avatar
dcmodels the short answer is yes this has happened to your rdx. ... this occurred at 20,000 miles using amsoil with no cel. opened it cause im nosy.
Well, now wait - the car model in your signature is a 2008 RDX, although you did not reply specifically to my question concerning the year model of you car. So, did you purchase the RDX *new* or *used*? Did you first check the intake at 20K from new, or from your purchase date?
I ask these questions, because if the PCV valve sticks closed, that will not allow the crankcase to vent, even when the Turbo does not presurize the crankcase (and close the PCV). And that will cause oil vapor to exit the valve cover and go into the turbo intake even when the turbo is not spooled-up.
The following poster indicates that his RDX has no oil in the turbo intake, I do not doubt that yours does, just wondering why the difference? perhaps the car in the following link had low miles?
The following link does discuss catch-cans, and I would certainly be interested in how you mount a catch-can.
https://acurazine.com/forums/showthr...&highlight=pcv
Old 02-20-2014, 06:00 PM
  #64
pwu_1's Avatar
Any other updates on this issue? My 2007 with 126K miles just started throwing this code so something is definitely wrong. From reading on the forums, seems like the most likely problem is one of the 3 solenoids since the turbo seems to spool fine and no oil leaks or anything. But before I go and order the parts and try to replace them(the 2 wastegate solenoids are buried in the back of the engine and very difficult to remove) did anyone else replace those solenoids and resolve the issue?
Old 02-26-2014, 07:51 PM
  #65
ltcjim505's Avatar
ltcjim505
no loss of oil and i change it bases on the MID and this is about every 5K or 6K. No the CEL did not come on. I pulled the turbo and had it inspected by a local turbo rebuild shop and the actual turbo is good. That said, it appears the variable Venturi control actuator failed. Did a vacuum check on it and it seems the diaphragm is bad. Now I can not find just the actuator. Acura only wants to sell a complete turbo assembly. Any recommendations?
Old 02-26-2014, 07:57 PM
  #66
ltcjim505's Avatar
The milage on my 2007 is just over 134,000 with the last 36K mostly highway. The CEL came on at highway speed (75-80 mph) with the SHAWD light also. The dealer pulled the code and it is the turbo fail code. I guess to demonstrate this the dealership pulled the intercooler and showed me a light film coating of oil. I have been using mobile one synthetic called for. I use the MID for oil changes and am getting between 5 to 6 K between changes.
Old 02-27-2014, 08:45 PM
  #67
is not very hard to remove a turbo... you take off the cover then unconnect the main turbo element clean it and replace...
weeoz (12-25-2023)
Old 03-02-2014, 09:45 PM
  #68
ltcjim505's Avatar
I believe I solved the problem with my turbo. My son and I pulled it and as stated earlier it received a clean bill of health. Next we checked the actuators and the variable venturi actuator had a rattling noise. My son proceeded to open it. He discoved that the post that goes through the diaphram has a washed holding it in place. This washer had seperated and caused the actuator diaphram to not operate and in turn the venturi would not open and all the boost went out the waste gate. He took the pieces and had the washer tack welded to the post. He then closed it back up and used 1200 degree JB weld to ensure it was sealed. We test drove it and I have noticed a difference in the turbo boost profile. I bought the car with 90+ K on it and when I accelerated hard it immediately went to full boost. With this fix I now have boost readings throughout the guage. I will post some photos of the inside of the actuator and the weld repair once I figue out how to do it. I have now put 200 miles on the repair and so far so good. I hope this helps.
Old 03-03-2014, 12:41 AM
  #69
dcmodels's Avatar
Originally Posted by ltcjim505
... Next we checked the actuators and the variable venturi actuator had a rattling noise. My son proceeded to open it. He discoved that the post that goes through the diaphram has a washed holding it in place. This washer had seperated and caused the actuator diaphram to not operate and in turn the venturi would not open and all the boost went out the waste gate. ...
Is the variable venturi actuator inside or external to the turbo body? just not sure what you are describing - and is the diaphram metal/ rubber/ what? just trying to understand how this was actually repaired, and why the actuator cannot be purchased? looking foward to any pics. thanks.
Old 03-03-2014, 08:07 AM
  #70
FLETCH
Glad that you got her going again and for way less then the dealership wanted at that! I think if enough people start asking for it then they need to mask it available.
Old 03-03-2014, 09:06 AM
  #71
ltcjim505's Avatar
It is the top set of vacuum lines that run to the turbo and is external to the turbo but bolted to the entire housing. The diaphram is rubber and is inside the metal chamber. I am unable to answer why the actuator is unavailable from ACURA, but we were told to get it you had to purchase the entire turbo. Still working the pics.
Old 03-07-2014, 11:50 AM
  #72
pwu_1's Avatar
wow thanks for the update and the description of the fix.
I replaced the solenoids in hopes that that was the issue but after replacing, I still see the P2263 code show up so I was thinking the wastegate actuator/diaphgram is bad on the turbo. Can the actuator be removed from the turbo? If so I don't see why Acura can't just sell that part instead of making us buy a whole new turbo.
How did you get to the turbo? from the bottom? seems like the turbo is tucked in there and really really hard to get to
Old 03-07-2014, 12:03 PM
  #73
pwu_1's Avatar
Which actuator is it? the one towards the top or the one towards the bottom of the turbo?
Do you think it would be possible to remove just the actuator without removing the turbo from the engine first?
That turbo is buried in the engine bay and looks very very difficult to remove.
Did you get to it from the bottom of the car?
Thanks in advance for any additional info. I'm thinking I'll have to do the same fix for my car since changing the solenoid didn't fix the issue.
Old 03-07-2014, 02:03 PM
  #74
Tomtwtwtw's Avatar
Just curious, any record of this happening on anything other than an 07-08 RDX? Obviously higher mileage, older models would be more prone to general part failure from age and wear, but there are tons of 9-12 models over 100k by now as well. Wonder if it affects potentially all RDX or only the early ones.
Old 03-07-2014, 04:54 PM
  #75
pwu_1's Avatar
The turbo part number is the same for all year RDX so I would think all model year would be susceptible to this issue.
Old 03-07-2014, 07:54 PM
  #76
Tomtwtwtw's Avatar
True, but sometimes parts are revised without the part number changing. For instance if they switched to a different manufacturer that makes a better quality version of the same part, the part# may not change. Sadly I have no idea how to find something like that out with certainty.
Old 03-08-2014, 08:57 AM
  #77
ltcjim505's Avatar
PWU,
yes it is the upper vacuum housing on the top of the turbo. you should be able to remove it from the turbo without removing the entire turbo. can not explain why Acura does not sell the actuators separately.
i used "all data" for the sequence to remove it. did not think to document the sequence separately.
the turbo come out the top. to gain clearance you have to remove almost everything from the drives side of the engine compartment. the airbox, the fuse box next to it, disconnect the brake maser cylinder from the firewall and flex tie if off to the side, drain the coolant so when you disconnect the heater hoses, the heat shield, and all the vacuum lines to gain clearance. the entire assembly is surprisingly large and requires a lot of space to get it out. the most difficult parts to remove was the oil lines and the bolt in the turbo support bracket at the bottom(access and angle).
Old 03-10-2014, 04:08 PM
  #78
pwu_1's Avatar
ltcjim505 was nice enough to send me the pictures he took of the actuator so I'm posting here for everyone to see.
Bottom picture looks to be the washer that broke off the actuator rod when he first took it apart. Top picture shows the actuator re-assembled and the washer welded back in place.
The following 4 users liked this post by pwu_1:
dcmodels (03-11-2014), ltcjim505 (03-10-2014), Mr Marco (03-11-2014), SinCity (03-28-2014)
Old 03-24-2014, 08:51 AM
  #79
Vividsi's Avatar
My light came on for which I think is the 6th time now saturday night when I was out with some buds and I have to say it is disapointing. Did you have to do any cutting to remove this part and is this the true solution? Im on my last stand with this RDX and I'm tired of throwing parts at it hoping for a fix.
Old 03-24-2014, 11:01 PM
  #80
ltcjim505's Avatar
Vividsi,
No cutting. We took it all apart which took about five hours. I would pull the upper vacuum actuator off the turbo, should be less than an hour. I guess I was lucky since it rattled Pictures show the internal repair. Is it the true solution, I am not sure it but I have about 800+ miles on the fix and it is running better than it had for awhile. So for me it seems to be the fix.
Quick Reply: P2263 Turbo problems
