Power steering locked up - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine RDX Community > First Generation RDX (2007-2012) > Problems & Fixes
Old 03-18-2012, 10:00 AM   #1
hotbryan333
Points: 1,328, Level: 20
Points: 1,328, Level: 20 Points: 1,328, Level: 20 Points: 1,328, Level: 20
Activity: 0.2%
This morning, i was backing up from my drive way, as i got ready to turn my steering wheel, it was stuck, it was not rotating at all, so i had to turn off my car and restart it, then it worked........ My Rdx is starting to act up..... what could be the cause?
hotbryan333 is offline   Reply With Quote
Old 03-18-2012, 10:16 AM   #2
DRR98
2011 Acura RDX
DRR98's Avatar
Points: 3,427, Level: 36
Points: 3,427, Level: 36 Points: 3,427, Level: 36 Points: 3,427, Level: 36
Activity: 8.8%
Activity: 8.8% Activity: 8.8% Activity: 8.8%
SCL malfunction.
Is it still under warranty?
DRR98 is offline   Reply With Quote
Old 03-20-2012, 9:18 PM   #3
hotbryan333
Activity: 0.2%
Originally Posted by DRR98 View Post
SCL malfunction.
it is at 61k, 42 months old. so out of warranty
Old 03-20-2012, 9:21 PM   #4
hotbryan333
Activity: 0.2%
SCL malfunction.
Is it dangerous to drive as it is or do i must take it to the dealer to fix it?
Its been fine since.....
I have tried to search the web but no luck.
Old 03-22-2012, 11:06 PM   #5
Kaze66218
Copy cat shinobi
Kaze66218's Avatar
Points: 2,135, Level: 27
Points: 2,135, Level: 27 Points: 2,135, Level: 27 Points: 2,135, Level: 27
Activity: 0.9%
Still getting that squealing sound? Power steering pump cavitation does not transfer any kind of vibrations thru the steering wheel. Power steering pumps make "squeals" as they are dying(for the sake of simplicity), and the pump is driven as an accessory drive that runs off of belts on the passenger side of engine.
Check the power steering reservoir while the car is on is there overflow, the fluid should not foam up. If it is foaming, power steering pump needs to be replaced, Possibly the hoses.
Assuming it is a power steering pump. A power steering pump is a simple task to replace. It is much cheaper to do than letting an acura dealer handle it, and then if you don't have the tools then take it to someone.
1997 Honda Prelude(base): @80% rebuilt:P&P H22a4 2.4L FI(PTE 68mm billet turbo)ALL Skunk2 internals+ IM+ one off 3" exhaust; Quaife+ M2a4 Tranny+ DSS lvl2.9 axles; Tanabe Suspension; KSport Pro coilovers; Fuidyne +FAL fans; AEM ems v2 + electronics.
2007 Acura RDX: RP 75k, Ported APEX'i + K&N Intake, ATLP exhaust, Hondata reflash.
Kaze66218 is offline   Reply With Quote
Old 03-24-2012, 3:01 PM   #6
hotbryan333
Activity: 0.2%
I talked with my mechanic he could not diagnose it since it only happened once and he could not chase the ghost.
Its not a squeal but sort of grinding + rubbing, maybe my cv joints or wheel bearing. But i have to admit that i put my accord's key into the ignition and this happaned. but only once. maybe that caused the lock up and vibration could be either power steering pump, cv joints or wheel bearing... hmmmmmmm
Old 03-24-2012, 11:32 PM   #7
mstolars
Points: 1,793, Level: 24
Points: 1,793, Level: 24 Points: 1,793, Level: 24 Points: 1,793, Level: 24
Was the steering wheel locked like if you had the key out, or was the wheel just real hard to turn like the power steering wasn't working at all? I had a friend with an older toyota camry that had the steering column lock up on him while driving and he ended up smashing into a bunch of parked cars because he couldn't steer at all.
mstolars is offline   Reply With Quote
Old 03-25-2012, 12:46 AM   #8
hotbryan333
Activity: 0.2%
It wasn't just the steering wheel locked out but also the acceleration wasn't working either.
The engine was on, i could not steer at all just like the key was out, i could go into the R but wasn't backing up, but it was downhill so the vehicle moved, then i put the gear in D it didn't do anything. So i turned it off and turn it back on boom it works.
So basically It was not hard to steer but was impossible.
The steering wheel was locked up as well as the Acceleration and everything else except for the engine.
Any Clue?
Old 03-25-2012, 11:45 AM   #9
DRR98
2011 Acura RDX
DRR98's Avatar
Activity: 8.8%
You failed to mention anything about what you and kaze are refering to above about vibration? My mind reading skills suck.
As far as the steering column lock up issue, if it truly locked, you are the decider.
When locked by the scl, the steering wheel can move an inch or so in either direction before it hits the lock with a slight clunk.
Is that what you felt?
If it ever repeated a lock condition while you were driving, I think that would be bad, umkay.
C5's had what may be a similar issue and you may find info on options they used for corrections on line.
97, acura, backing, cl, driving, hard, integra, locked, locks, power, rl, rsx, steering, turn, wheel
