Squeaking belt - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL Community > Second Generation TL (1999-2003) > Problems & Fixes
Old 02-18-2012, 4:18 AM   #1
teohenwhy
Points: 545, Level: 10
Points: 545, Level: 10 Points: 545, Level: 10 Points: 545, Level: 10
Activity: 0.8%
Squeaking belt
My 02 TL-S has this problem where when I start the car when it's cold there is this loud squeaking noise coming from the passenger side where the belts are at. After the car warms up the noise goes away. What could it be? Thanks in advance.
teohenwhy is offline   Reply With Quote
Old 02-18-2012, 10:32 AM   #2
01tl4tl
Points: 40,142, Level: 100
Points: 40,142, Level: 100 Points: 40,142, Level: 100 Points: 40,142, Level: 100
Activity: 56.6%
Activity: 56.6% Activity: 56.6% Activity: 56.6%
a worn out belt, the main belt tensioner failing, the ps belt not tightened correctly
(caution: it does need more play than a normal belt)
The Following User Says Thank You to 01tl4tl For This Useful Post:
teohenwhy (02-18-2012)
Old 02-18-2012, 10:39 AM   #3
AznWay
1999 Acura TL
AznWay's Avatar
Trader Rating: (8)
Aznway
Points: 11,075, Level: 69
Points: 11,075, Level: 69 Points: 11,075, Level: 69 Points: 11,075, Level: 69
Activity: 0.7%
try showing us youtube video so we can help you out better.
99 6speed Type-S SSM TL w/ Samsung Tab3 Navi replacement-OEM Bodykit-WW Rear Lip & Spoiler-Roof Spoiler-JDM Visor-SABER Grill-INSPIRE/32V/H Badges-02/03 Mirror & TailLight-CUCSO Strut Bar-NRG & Ingall Engine Damper-PnP Lower Runner-MDX Spacer-P2R Spacer/TB/Manifold Gasket- 3.5" CAI-XS Header-UR Stock Crank Pulley-XLR8 CAT & 62A Mount-Comptech Exhaust-F&F Type 1-RL BBK-Irotors Disc Brake-XXR 530 Chomium Black 18"
AznWay is offline   Reply With Quote
The Following User Says Thank You to AznWay For This Useful Post:
Old 02-18-2012, 6:35 PM   #4
teohenwhy
Activity: 0.8%
Could it be the timing belt? I will try and upload a video soon.
Old 02-18-2012, 6:44 PM   #5
teohenwhy
Activity: 0.8%
The funny thing is that this started after getting my oil changed at Jiffy Lube. Could something they did while doing inspections cause this? I know they inspected the belts.
Old 02-18-2012, 6:52 PM   #6
teohenwhy
Activity: 0.8%
http://www.youtube.com/watch?v=8JrX4...ature=youtu.be
Old 02-20-2012, 1:16 PM   #7
almightycrunch
Points: 130, Level: 2
Points: 130, Level: 2 Points: 130, Level: 2 Points: 130, Level: 2
Activity: 0.4%
No, a timing belt cannot sqeal.
almightycrunch is offline   Reply With Quote
Old 04-07-2012, 12:38 PM   #8
Ronmarr1
Points: 8,151, Level: 61
Points: 8,151, Level: 61 Points: 8,151, Level: 61 Points: 8,151, Level: 61
Activity: 0.3%
I am having this issue on cold mornings as well - sounds like either a belt or maybe a bearing squeal - I had all belts/ idlers/tensioner, water pump, seals, etc. changed out when I had the timing belt service done 2 yrs ago @ 101k mi. Now at only 113k miles.
Ideas?
2000 TL - Nighthawk Black
Ronmarr1 is offline   Reply With Quote
Old 04-07-2012, 3:43 PM   #9
fsttyms1
2000 Acura TL
fsttyms1
Points: 98,281, Level: 100
Points: 98,281, Level: 100 Points: 98,281, Level: 100 Points: 98,281, Level: 100
Activity: 99.6%
Activity: 99.6% Activity: 99.6% Activity: 99.6%
Ideas?
Miles mean less than age. Was the belt a honda belt or a autoparts store belt?
Old 04-07-2012, 7:36 PM   #10
Skirmich
2002 Acura TL Type-S
Skirmich's Avatar
Points: 9,538, Level: 65
Points: 9,538, Level: 65 Points: 9,538, Level: 65 Points: 9,538, Level: 65
Activity: 27.2%
Activity: 27.2% Activity: 27.2% Activity: 27.2%
It doesnt sound like a Belt Tensioner problem... By looking in the video the PS Belt looks like the "Mitsuboshi" OEM.. but I dunno about the ACC belt.
IMO Use only OEM I had a Gatorback in there sometime ago and It did squeal alot...
2G Acura TL-S (WDP)
Current AudioSystem: Optima Yellow, Big3, Dynamat to hell, HU KENWOOD DDX514, JL Audio C5-650 x4 Mids, KENWOOD KFC-270 Tweets on A-Pillars, JL Audio JX360/4, JL Audio Sub 12W6v2 in 32hz box, JL Audio SLASH 500/1v2 < TUNED FOR DA SQ..
Mechanical Mods: All Bolt-Ons (Engine) to Straight Pipes!.
Skirmich is online now   Reply With Quote
Old 04-07-2012, 7:57 PM   #11
Ronmarr1
Activity: 0.3%
All parts for the timing belt replacement, including all belts, idler(s?), tensioner, seals, water pump, etc, were Acura OEM - only 2 yrs ago and about 12k miles since the install. Belts look fine and tension "appears" correct. Wonder if it might be alternator or power steering pump bearing? Noise is only when cold.
1999, 2002, 99, acura, alternator, belt, cl, cold, loud, squeaking, squeal, squealing, squeck, squeeking, start, tl, tsx
