Small oil leak around oil pressure sensor - help
Old 02-10-2012, 10:05 AM
01RedCLS's Avatar
Question Small oil leak around oil pressure sensor - help
I took my CL-S in for an oil change (Mobil 1 Syn) and tire rotation yesterday and in the "Comments" section of the "Acura Multi-Point Vehicle Inspection Checklist", the tech noted:
"has a small oil leak around oil pressure sensor"
First of all, where is the oil pressure sensor? And what could be causing the leak - any common problems in/around this area that you know of?
Old 02-10-2012, 11:16 AM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,130 Likes on 4,801 Posts
The sensor is #17, located on the oil filter housing. Theres an o-ring on it:
#29, part number 91319-PR3-003, lists for $2.50. Isn't difficult to install but you may get some oil leaking out when you pull out the sensor. Its possible its the o-ring from the solenoid (#15) too.
Old 02-10-2012, 11:21 AM
01RedCLS's Avatar
Perfect, thank you! Is this relatively easy to get to and replace both o-rings on my own, I hope?? I know my way around my Miata and Focus (ZETEC) engine but the CL has been such an easy car to maintain, I am not as familiar under the hood .
Old 02-10-2012, 11:27 AM
TLer trash's Avatar
#16 is the oil pressure sensor, #17 is the vtec oil pressure sensor. There are no o-rings on 16, it's tapered pipe thread. Fairly common source of oil leakage,
The following 2 users liked this post by TLer trash:
civicdrivr (02-10-2012), StreetKA (02-10-2012)
Old 02-10-2012, 11:32 AM
civicdrivr's Avatar
Gah, youre right.
Old 02-10-2012, 11:50 AM
01RedCLS's Avatar
So I just need to replace #16 then due to the oil leak?
Old 02-10-2012, 03:15 PM
dfv3.2CL-S's Avatar
Most likely the oring is bad
Old 02-10-2012, 03:17 PM
01RedCLS's Avatar
TLer Trash just said that #16 is a threaded pipe - no-oring...
Old 02-10-2012, 04:11 PM
StreetKA's Avatar
if its expensive i may have one for you lmk.
Old 02-10-2012, 05:18 PM
01RedCLS's Avatar
StreetKA - PM'd you..
Old 09-16-2014, 01:47 PM
'01AcuraCL's Avatar
oil pressure sensor
[IMG] I'm trying to find where the oil pressure sensor is located. I installed a new variable valve timing switch (#17 on the drawing) and from what I can see, it appears the oil pressure sensor is just inches away. Is it covered by a black plastic/rubber Hershey"s Kiss shaped cover? If so, does it just come off by pulling it or does it unscrew? Do I need to drain the oil prior to removing the oil pressure sensor? Thanks
Old 09-16-2014, 01:57 PM
TLer trash's Avatar
^^Yes, the oil pressure sender has a boot over it. Peel the boot back (sometimes they're stiff, and will crack). The wire terminal is a spade type; it pulls straight off. You don't have to drain the oil.
'01AcuraCL (09-16-2014)
Old 09-16-2014, 02:33 PM
'01AcuraCL's Avatar
You're awesome!
Old 09-17-2014, 03:02 PM
YeuEmMaiMai's Avatar
I had to do mine last year it was only $100 for the dealer to do it.
cycdaniel
12-17-2019 10:58 AM
IIDXholic
10-08-2015 07:53 AM
winkyyy
09-11-2015 04:40 PM
HeloDown
09-08-2015 06:51 PM
NSolace
09-03-2015 08:02 PM
Quick Reply: Small oil leak around oil pressure sensor - help
