S2000 Turbo J32 Build Thread On J32A.Com
Old 01-16-2012, 01:59 PM
03 CLS-6
1foxbody's Avatar
Talking S2000 Turbo J32 Build Thread On J32A.Com
I saw this guys build thread on j32a.com. I figured I would share it since it's interesting and unique.
Originally Posted by diversat
Well I guess its time to start a build thread since its finally starting to look like something. I purchased my 2002 S2000 in October 2009 and bought the J32a2 two weeks later. Both the car and motor were bought just for this swap. My main thought behind the idea was to have a s2000 with some much needed torque. FYI, the idea was before the HFP j37 Blue CR(the released pic anyway)! I will try to keep the updates not too far apart, but I only work on the car about once a month.
Construction of mounts
Motor and tranny together with temp. wooden adapter plate
with mounts tack together and ready to install in mock-up car
Manifold construction
Rev4 template of adapter with starter location
Cutting a knock out in the oil pan for the starter and checking fitment
Material for the final adapter plate
Adapter Plate, spacer, and flywheel
Starter shim and modded pan
Stepped dowel pins (thanks to turtle @ EVO IND) are an adapter plate's best friend
...going back in to continue the fab stuff
Meanwhile, the reason my S2000 was so cheap was it was wrecked at one time. Most of the damage was cosmetic, but needed to be fixed.
Back to project. Just a few pics of fit and clearance
Old 01-16-2012, 02:00 PM
repost.
he posted this on acurazine as well.
follow the build here:
https://acurazine.com/forums/car-talk-5/turbo-j32-s2000-build-thread-844557/
Old 01-16-2012, 02:03 PM
03 CLS-6
1foxbody's Avatar
repost.
https://acurazine.com/forums/showthread.php?t=844557
Damn your right. My fault delete thread lol.
Old 01-16-2012, 06:24 PM
3.7L Nitrous Breathing CL
richardparker's Avatar
I had to make a spacer like this so I had clearance between my drive plate and my rear seal cover So it would sit right compared to the cls drive plate. If not the 3.7 crank will not work in a auto.
It's stepped the same way just much smaller.
Old 01-16-2012, 07:38 PM
shifting at 7k
azeezp13's Avatar
So a light RWD roadster with our power and torque? Wow subscribed. Probably the most interesting J32 build I've seen to date.
Old 01-16-2012, 09:45 PM
subscribe to the linked thread. the owner is answering questions and comments over there.
adrian_s2k
1G RDX (2007-2012)
23
01-12-2016 04:25 PM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: S2000 Turbo J32 Build Thread On J32A.Com
