FYI - P0339 and P0344 After Timing Belt Change - AcuraZine Community
Old 11-23-2011, 8:00 PM   #1
jda123
Dogmatic Dinosaur
Points: 5,383, Level: 47
Points: 5,383, Level: 47 Points: 5,383, Level: 47 Points: 5,383, Level: 47
Activity: 0.3%
I was unable to find any help on here for these, so I am posting my experience.
I changed the timing belt. I have done at least 20 timing belts before - easy as pie. Started and drove fine most of the time. Every once in a while at the first VTEC, it would surge-and-cut, CEL, VSA and Delta! lights would come on. About half of the time and the second VTEC, the same thing would happen except it would stall some of the time. The surging-and-cut was similar to when the APP sensor starts to go out. Sometimes, it was fine at WOT.
The codes read P0339 and P0344 - crank sensor and cam sensor.
Turns out that both cams were one tooth off - they were behind because I apparently didn't get the slack out of the money side of the timing belt. It was an easy fix. I am glad that the computer let me know, because I otherwise was not able to tell for the 30, or so, miles that I drove it.
Anyway, I wanted to post my experience in case this happens again to somebody. Save your hydraulic tensioner pin, just in case... and double check your slack and marks so that you don't waste 40 minutes fixing this like I did.
72 Cutlass Conv, 525hp * 02 Excursion V10 * 04 RRP TL * 06 NBP TL
jda123 is offline   Reply With Quote
Old 11-23-2011, 10:07 PM   #2
flyromeo3
Points: 6,174, Level: 51
Points: 6,174, Level: 51 Points: 6,174, Level: 51 Points: 6,174, Level: 51
Activity: 5.0%
Activity: 5.0% Activity: 5.0% Activity: 5.0%
you didnt check your marks once all was said and done?
2001 Audi S4 +stage 2
2006 Acura TL
flyromeo3 is offline   Reply With Quote
Old 11-04-2013, 10:41 AM   #3
Sergio Restrepo
Points: 129, Level: 2
Points: 129, Level: 2 Points: 129, Level: 2 Points: 129, Level: 2
Activity: 0.2%
I have the same issue :-(
Guys,
So over the weekend, My friend and i changed out the belts, tensioners, water pump, etc. on my 2005 TL.
I drove the car fine home no issues. The next day from cold start I could tell it took longer for the engine to start. When it did similar to the post above my check engine light came on, VSA came on.
Took it to auto zone and got the p0344 error code, anyways drove to run some errands and when heading back home i noticed the car started up w/o any issues and the check engine light was gone.
Fast forward to this morning, getting ready to go to work, the car again started up funny, and i have the check engine light back on the car.
Any idea, could it be a cam sensor issue? Or could it be my timing is off by a tooth.
any help or guidance would be appreciated
Thanks,
Sergio
Sergio Restrepo is offline   Reply With Quote
Old 11-04-2013, 12:35 PM   #4
jda123
Dogmatic Dinosaur
Activity: 0.3%
Mine was because I had a bit of slack on the pulling side of the assembly and I was off a tooth once the slack was out. Check the timing.
Old 11-04-2013, 4:10 PM   #5
Majofo
Wishes he owned a..
2012 Nissan GT-R
Majofo's Avatar
koobecaf rettiwt nideknil $2PlayNay NSP
Points: 29,363, Level: 99
Points: 29,363, Level: 99 Points: 29,363, Level: 99 Points: 29,363, Level: 99
Activity: 35.7%
Activity: 35.7% Activity: 35.7% Activity: 35.7%
Check timing. All marks should be TDC on cams and crank. Check the actual cam marks, not the cover marks.
Majofo is offline   Reply With Quote
2003, 2004, acura, belt, mdx, p0339, p0344, po344, problems, replacement, start, timeing, timing, tl, wont
