Navigation hack for orange disk 3.a0 (all files here)
Old 11-11-2011, 06:54 PM
djspot's Avatar
Hi everyone,
So my relationship with Acurazine has been completely one sided, as in I take take take, and never give! So with that said I thought I'd put this up here to help everybody out who's had some struggles with this.
http://www.megaupload.com/?d=6W2J0YG0
The link above points to a zip file that includes the following files:
BN2HH12C.BIN
BNHH401A.BIN
BN2HHMLD.BIN
dumpnavi.exe
I included both BN2HH12C.BIN and BNHH401A.BIN...depending on your Nav you'll have to upload your image to one of those files when uploading using dumpnavi.
To find out which file your car is running do the following:
1. Turn your car's ignition to ACC
2. When the nav loads completely press and hold "GUIDE" "MENU" and "CANCEL" for approx 5 seconds to bring up the diagnostic menu.
3. Wait another 5 seconds to let it load up completely. Press "version" button on the screen.
4. Hold down the "MENU" button until you get a new window displaying what .bin you are running. Write this down so you dont forget.
Next...
Get back to your computer and open up "dumpnavi".
1. For your Bootable File, select the .bin that applies to your car (mine was NHH401A.BIN).
2. Make sure "Modify Bitmap" is checked and upload your custom background.
3. Make sure to uncheck "Modify Nag Screen". These files already include the nag screen and ok button bypass hacks.
4. Click "Modify"
You should all be set now.
Burn your files on to a CD/DVD. I used a DVD-R. I have no idea if you can use a CDR or DVD+R. I think some have used CDR's
This is important! you have to make an ISO disk. I think a lot of people run into issues because they don't do this.
Your ISO disk only needs the file you modified (in my case BNHH401A.BIN) and BN2HHMLD.BIN
Once you're done all this get back to your car and do the following (taken from the Navigation Hack Guide):
2. Open the trunk and pop out the NAVI disk (if it's in there)
3. Insert your newly burned CD.
4. Go back to the driver seat, the display will show some dvd read error, now press and hold "GUIDE" "MENU" and "CANCEL" for approx 5 seconds to bring up the diagnostic menu.
5. Wait another 5 seconds to let it load up completely. Press "version" button on the screen
6. Press "LOAD DISC" to load your custom bin into the navigation.
7. Wait until it's completely done and it will then display another error message about can't read the navi dvd, now take out your bin CD and insert your Navigation disc and you are done!
If you follow exactly what I wrote above this NEEDS to work. It's exactly what I did and it worked perfectly.
You'll have your custom background, trip computer, ok bypass and no nag screen.
I decided to make a post for this because things seem to be buried in the main navigation hacking guide. Thought this would be helpful.
djspot is offline
The following 7 users liked this post by djspot:
alexgolden (11-18-2011), aspectl253 (11-16-2011), fbatzaz (03-21-2013), Shoeface (03-22-2012), TheHypnoToad (03-22-2012), THTL (11-11-2011), triax37 (11-13-2011) and 2 others liked this post. (Show less...)
Old 11-11-2011, 09:55 PM
THTL's Avatar
Thank you!
THTL is offline
Old 11-11-2011, 10:27 PM
djspot's Avatar
No problem...
Forgot to mention, this also includes the Trip Computer
djspot is offline
Old 11-12-2011, 10:36 AM
Coolest A-zine Member
Trunk Monkey's Avatar
What programs are needed to download to do this?
Trunk Monkey is offline
Old 11-12-2011, 11:54 AM
djspot's Avatar
You don't really need any programs to download. The only thing you would need to download I included in the zip file. That would be the dumpnavi program.
Other than that, you'll need burning software thats capable of creating iso disks, and possibly photoshop or something else in which you can create your background image. You do have some options for this, a bunch of members on here have uploaded backgrounds.
djspot is offline
Old 11-13-2011, 09:59 AM
2005TL(6MT)
clsdave's Avatar
Are the bin files from version 3.A0? If not please tell us what version they are from. I don't believe the 3.A0 or 3.B0 versions have been hacked yet and the last hacked orange version is 3.80 as far as I know.
I would like to have the correct Daylight Savings Time dates which were lost when I used hacked 3.80 files for the modification. Apparently the new dates were put into effect sometime after version 3.80. This was the secondary reason I upgraded to 3.A0 from 3.40C. The primary was of course were the maps.
I would sure like to have a navi that always has the correct time and keep my custom background, trip computer, ok bypass and the no nag screen.
And thanks for helping others out!
clsdave is offline
Old 11-13-2011, 10:21 AM
TLX-S
wilztlxs's Avatar
the files are from the 3.80 hack
wilztlxs is offline
Old 11-13-2011, 11:32 AM
aspectl253's Avatar
unable to download from link??
aspectl253 is offline
Old 11-13-2011, 04:39 PM
djspot's Avatar
They're not from my 3.a0 disk. My time and date are correct.
I'm going to give the 3.a0 files a try when I get the chance. I just wanted something quick I knew would work.
If you're only worry is the time, if its effected by this being the 3.8 files, changing it manually isn't a big thing, I don't think.
Also, just tested the link. it is working for me
djspot is offline
Old 11-13-2011, 08:36 PM
triax37's Avatar
djspot - just want to clarify one point:
So you've already made the nag screen and ok button changes to the files* in the zipped folder?
* Files:
BN2HH12C.BIN
BNHH401A.BIN
BN2HHMLD.BIN
triax37 is offline
Old 11-13-2011, 08:41 PM
TLX-S
wilztlxs's Avatar
* Files:
BN2HH12C.BIN
BNHH401A.BIN
BN2HHMLD.BIN
yes, they already include the changes, they're the files from the 3.80 hack.
wilztlxs is offline
Old 11-13-2011, 09:26 PM
djspot's Avatar
Thanks WLZRSX.
Ya I basically just compiled files that I found from other threads and put it into this.
i didn't actually do any work to these files myself. my goal was just to have this in one easy place to find.
djspot is offline
Old 11-14-2011, 02:53 PM
triax37's Avatar
Originally Posted by djspot
Thanks WLZRSX.
Noted...and appreciated. Props to AngryDad and kennyc for all of their work as well, but I admit my brain was lazy to process everything in kennyc's stickied thread (linked). Thanks to djspot, my ISO disk is burned and I'll be hacking away this evening!
triax37 is offline
Old 11-15-2011, 10:04 AM
aspectl253's Avatar
Hi everyone,
djspot: what program are you using to create the iso disk??
Old 11-15-2011, 10:48 AM
djspot's Avatar
I used Nero to burn my ISO disc.
For a long time I used IMGburn to create ISO disks http://www.imgburn.com/
Should work fine, and its free.
djspot is offline
Old 11-15-2011, 11:12 PM
d5civic's Avatar
files are gone from the link...well temporarily unavail.
d5civic is offline
Old 11-16-2011, 12:03 AM
TLX-S
wilztlxs's Avatar
link to download still works for me
wilztlxs is offline
Old 11-16-2011, 12:17 AM
d5civic's Avatar
Eh? I just tried right now and it still says file are temporarily unavailable try again later...
d5civic is offline
Old 11-16-2011, 10:29 AM
djspot's Avatar
Hi guys,
just looking into my Megaupload account...it showing it being unavailable for me as well. Stupid megaupload...if I can't get it going, I'll uploaded to another file sharing service. I'm thinking the downloads may be capped. It's at 68 downloads.
djspot is offline
Old 11-16-2011, 10:35 AM
djspot's Avatar
Looks like its up and running again.
I sent them an email asking why this is happening...I'll get back to you guys with an answer.
So seeing as this has had 68 downloads I wonder if its working for anybody. Haven't got any feedback on it working or not, so if you've downloaded and applied the hack let us know if it worked for you.
djspot is offline
Old 11-16-2011, 02:51 PM
aspectl253's Avatar
i downloaded yesterday and it worked for me. After months and months of trying to figure this out.
Big Thanks to you djspot.....
Old 11-16-2011, 03:11 PM
djspot's Avatar
Thanks...I cant take the credit for the work though AngryDad and kennyc did amazing work with this...
I just thought it would be awesome to have the info consolidated, especially for the new versions.
I'm glad it worked for you!
djspot is offline
Old 11-16-2011, 05:17 PM
Drive it like its Stolen
Hammer5312's Avatar
so what is the purpose of doing the "Nav Hack"?
I just got my TL just a couple of days ago and am still learning.....
Hammer5312 is offline
Old 11-17-2011, 09:56 AM
djspot's Avatar
A few things...
Megaupload support got back to me....they let me know if we get that temporary file is unavailable message, it means the server that the file is on may be down and usually gets resolved shortly after, within an hour or so. So if you get that message just check back later....
Also...as far as using imgburn...I think I messed up, I think that software only burns iso files.
so I found this
http://www.afterdawn.com/guides/arch..._with_nero.cfm
It would have you downloading a trial version of Nero ROM or the Nero suite. From their you'd follow the instruction for burning an image.
Nero or any other burning software seems to be bundled with every computer.
Oh and Hammer...the hack allows you to throw up your own customized splash screen for the nav. Also, it eliminates having to press the ok button and doesn't give you the navigation use disclaimer....AAANNNDDD you get a fancy little Trip Computer.
djspot is offline
Old 11-17-2011, 11:12 AM
triax37's Avatar
Yep, I downloaded your files, burned an ISO using ImgBurn, and everything worked perfectly. Thanks to everyone for your AZ contributions!
triax37 is offline
Old 11-18-2011, 05:05 PM
alexgolden's Avatar
Thanks djspot! I know others have put a lot of hard work into this but this made it easy to do. I used imgburn and it worked just fine! I added this to my wife's '06 TL as the start up image:
Attachment 117327
alexgolden is offline
Old 03-21-2012, 08:33 PM
djspot's Avatar
updated link since "The Man" got to Megaupload
https://rapidshare.com/files/1331935...vi-gui-new.zip
Unfortunately, I can not for the life of me find the original zip file that BN2HH12C.BIN file. However, if your nav uses this and not the bin ending in 401A, you can simply copy this bin file from you nav disk.
djspot is offline
Old 03-22-2012, 12:24 PM
Shoeface's Avatar
Thanks for the new upload!
Shoeface is offline
Old 04-21-2012, 01:03 AM
yah yah's Avatar
do i just drag and drop the BN2hh1c file from the disk to the computer? It says file has sucessfully been moded but do not know where it is at to burn the image.
yah yah is offline
Old 04-21-2012, 03:28 AM
yah yah's Avatar
Okay i got the start up image to work, my own background but i went into setup/info where is the A/C, TRIP mod ??? that was mainly what im looking to hack. please help thank you
yah yah is offline
Old 04-25-2012, 04:06 AM
unbreakable379's Avatar
Backup Download
Do you have a backup download site since mega was taken down? Has anyone figured out which files on the nav disc upgrade are actually updated?
unbreakable379 is offline
Old 04-25-2012, 09:50 AM
Look about 4 posts up, he uploaded it to RapidShare.
GuyWithNoLife is offline
Old 04-25-2012, 02:17 PM
Cesspool of Knowledge
żGotJazz?'s Avatar
OK ... My Navi runs the orange 3.80 disk, and my boot file is BN2HH12C.BIN - Which is the file that djspot unfortunately lost.
So, if I copy the BN2HH12C.BIN file from my stock DVD, should I enable the "Modify Nag Screen" checkbox, since my version of BN2HH12C.BIN is not hacked yet?
Thanks,
żGotJazz? is offline
Old 04-25-2012, 02:37 PM
żGotJazz?'s Avatar
Well, I couldn't seem to get this to work on my BN2HH12C.BIN file.
When I enabled the "Modify Nag Screen", I got a "Nag modification is not supported on your car" message.
When I tried to modify the bitmap, I saw an "Invalid .XIP" file.
Old 04-25-2012, 11:34 PM
żGotJazz?'s Avatar
For those of you with a Version 3.80 (Orange Disk) Navi and bootloading BN2HH12C.BIN file (required!), I have a solution for you here: https://acurazine.com/forums/showpos...postcount=1634
Cheers!
Old 08-11-2012, 04:39 PM
Bruce Banner's Avatar
Does this hack have AC controls etc..
Bruce Banner is offline
Old 08-13-2012, 04:45 PM
8th Gear
lonestar3's Avatar
Is there an easy way to change the background photo using the link provided?
Don't think my wife would appreciate the "welcome jorge" screen.
Other than that, many thanks.
lonestar3 is offline
Old 11-18-2012, 01:47 PM
My first ricer
350's Avatar
Thanks for this, I tried it today and I only got the image to work, still have the nag button and no trip computer. My disc is the 3.B0, can anyone help me out or have any input?
350 is offline
Old 11-18-2012, 11:30 PM
Ccvn0's Avatar
Can someone burn me one
Ccvn0 is offline
Old 11-23-2012, 03:02 PM
crod147's Avatar
The image loads up with a slight delay, im having to hit "go" instead of "ok". also i do not have the trip computers or a/c controls. Any suggestions?
crod147 is offline
Quick Reply: Navigation hack for orange disk 3.a0 (all files here)
