Grinding noise from rear wheel
Old 08-12-2011, 10:28 AM
schebro's Avatar
A few days ago, I started noticing a sufficiently loud grinding (feels metal on metal) noise coming from the passenger side rear wheel intermittently. Looked like it was coming from the caliper area when I took a closer look (while my wife as slowly backing up the car). It is not very consistent, appears once or twice a day, and disappears when I apply the brake. I jacked up the car to see if something got stuck in the wheel but couldn't find anything. I am not sure if worn out brakes will cause this kind of issue. Does anyone have any suggestion or opinion before I shell out money at the dealer?
Old 08-12-2011, 05:08 PM
in the 24th and a half...
DuckDodgers's Avatar
Especially if it's only currently when backing-up, it's the wear tabs on the brakes.
Old 08-14-2011, 10:15 PM
npolite's Avatar
Yep it is probably the wear indicator or you are touching metal on metal with the pads.
Take a look at how much padding you have left and replace ASAP!
Old 08-22-2011, 02:28 PM
schebro's Avatar
It turned out to be my wear indicator. I got the brake pads replaced and the noise is now gone. Thanks all for the replies.
jblessing
08-08-2018 09:43 PM
wilztlxs
12-01-2015 09:16 AM
Quick Reply: Grinding noise from rear wheel
