My hood doesn't stay up anymore
Old 06-24-2011, 01:43 AM
TL260power's Avatar
It doesn't stay up by itself anymore. I think I need to replace hydraulic lifts or the hood shocks? Whichever one it is for our car. (02 TL-S) Where can I get them? The dealer charge as much as $200! Ridiculous! I bet it's mostly labor.
Old 06-24-2011, 02:36 AM
10 minute DIY
local parts store for 2 new hood stuts
careful of heavy duty ones which can rip the hood from your hands as it opens
good way to knock yourself out~
Old 06-24-2011, 03:13 AM
SSM FTW
luder917's Avatar
i like using amazon...
http://www.amazon.com/StrongArm-4160.../dp/B003NHF1TM
...or ebay. they are very easy to pop off. just make sure you have a helper holding the hood up. some have little clips on the end and some are screwed on. just look at it and you can figure it out.
webmastir (06-24-2011)
Old 06-24-2011, 04:27 AM
Unregistered Member
Karanx7's Avatar
That's fucking disgusting...
Dealers are just charging whatever they think they can get away with. They charged me $100 total for the same exact job. I saw the tech do it in EXACTLY 2 minutes. Trying to charge you $200? That's a 100% increase in price... How do they justify this shit?
Old 06-24-2011, 10:57 AM
shops have a MINIMUM charge time,,say 1 hour at 100$ an hour
or 1/2 hour plus parts = 100
like diagnostics charge, 1.5 hours = 150$ and they get to charge it even if problem found in 10 minutes--you agreed to 150 so they get to screw you
Old 06-24-2011, 02:26 PM
TL260power's Avatar
Ok thanks. Good price. Which one does ours use? In the picture I see like five different kinds. Just wondering because I would like to get the same one that came with the car.
Old 06-25-2011, 03:06 AM
SSM FTW
luder917's Avatar
That's just a generic picture they use on amazon. Just make sure it says 02 TL and they should send you the correct one.
Old 06-25-2011, 09:52 AM
martinb's Avatar
Try www.acuraoemparts.com (Acura of Delray) or www.oemacuraparts.com (Acura of Peoria). You can get the exact Honda part, based on your VIN, for a good price.
I needed hood struts in my '02, and the independent shop that did the timing belt/plugs, etc. service installed the struts I purchased on-line for free...
Old 06-25-2011, 11:02 AM
I need 2 more gears
sbuswell's Avatar
You can buy them for $12 ea. on Rock Auto. They all work fine. Don't need to buy OEM for the hood supports.
Old 06-25-2011, 11:20 AM
another example of aftermarket exceeding oe quality
I use a local store when possible- so its there when I need oil and small parts
if only a few dollars differance,,keep brick and mortar shops alive!!
Old 07-11-2011, 12:45 PM
TL260power's Avatar
Based on the pic, I would only need #13? (Stay Assy Hood Opener) I don't think I would need #21 which is the stud ball?
https://www.oemacuraparts.com/index....component=HOOD
Old 07-11-2011, 01:11 PM
Correct. All you need is ( 2) #13's
Old 07-11-2011, 05:55 PM
TL260power's Avatar
Are they easy to change? DIY please.
ImageShack.us
ImageShack.us
Old 07-11-2011, 08:43 PM
Unregistered Member
Karanx7's Avatar
Pull the clip thing. I pointed to it with the red arrow.
It'll come right out. New one snaps into place the same way. 5 min job max.
Old 07-11-2011, 10:09 PM
TL260power's Avatar
Once I pull the clip, the bottom part will, I guess, slide off? Also would it require another person to help me out or I'll be fine doing it myself? Just curious.
Old 07-12-2011, 07:48 AM
The bottom has a clip just like the top. Do one side at a time using your shoulder to hold the hood or use a vise grips on the other one to lock the hood open while you replace it.
Old 07-28-2011, 12:04 AM
TL260power's Avatar
Ok cool. Just replaced them over the weekend. I used a flat head screwdriver to get the clips out. Yup easy job! Screw the dealer...:ghey:
Thanks guys!
miner
3G RLX (2013+)
36
01-11-2016 04:17 PM
mugen_kid
11-13-2015 10:38 PM
PortlandRL
09-14-2015 12:01 PM
ninersfgiantsfan
09-09-2015 01:14 PM
drewdeezy03
09-03-2015 08:04 PM
Quick Reply: My hood doesn't stay up anymore
