I got the codes; P0300,P0301,P0302,P0303,P0304, p03050 - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL Community > Second Generation TL (1999-2003) > Problems & Fixes
Old 06-06-2011, 4:33 PM   #1
smilecow
Points: 749, Level: 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Activity: 0.8%
My car is a 2003 actura tl type-s.
I got these codes P0300,P0301,P0302,P0303,P0304, 0305.
2 weeks ago.
I replaced spark plugs and wire with genuine parts but they came back. I repeated to install and the light usually came back in 1 days..
but the car is like a normal car that doesn't show any thing bad except the lights on.
plz give me some or any advice?
Is it possible that the timing belt is bad, or valve adjustment that I have not done?
thank you so much for your replies
smilecow is offline   Reply With Quote
Old 06-06-2011, 7:44 PM   #2
closetprisoner
2000 Acura TL
closetprisoner's Avatar
Points: 3,829, Level: 39
Points: 3,829, Level: 39 Points: 3,829, Level: 39 Points: 3,829, Level: 39
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
You replace the wire? or are you talking about the coil pack?
closetprisoner is offline   Reply With Quote
Old 06-06-2011, 9:00 PM   #3
01tl4tl
Points: 40,286, Level: 100
Points: 40,286, Level: 100 Points: 40,286, Level: 100 Points: 40,286, Level: 100
Activity: 66.8%
Activity: 66.8% Activity: 66.8% Activity: 66.8%
we dont have spark plug wires
coil packs can be damaged if handled roughly-dropped- banged etc
You used ngk iridium or ngk platinum plugs???--about 8 dollars each
you are getting multi cyl misfire which usually means just 1 coil has failed
50 bucks,,fairly easy diy to figure out which one is bad
after new part installed:
reset the ECU by removing the CLOCK fuse on passenger end of dash for 1 minute
thats its secret backup power and clears all codes + forces a master relearn to see if all is well
Old 06-06-2011, 9:00 PM   #4
01tl4tl
Activity: 66.8%
is it running just a little rough at idle now?
Old 06-07-2011, 1:13 AM   #5
smilecow
Activity: 0.8%
thank you for your replies
I am sorry for misleanding. I didn't replace any wire, just the spark plugs which were the genuine parts at dealer. It's not rough at idle at all. It doesn't show any symptom. How can I check which coil is bad?
Old 06-07-2011, 1:27 AM   #6
smilecow
Activity: 0.8%
One more question, what is the interval to change the coil pack?
my tl is on 180k
Old 06-07-2011, 8:27 AM   #7
fsttyms1
2000 Acura TL
fsttyms1
Points: 98,389, Level: 100
Points: 98,389, Level: 100 Points: 98,389, Level: 100 Points: 98,389, Level: 100
Activity: 99.5%
Activity: 99.5% Activity: 99.5% Activity: 99.5%
Coil packs dont need to be replaced unless bad.
Best method is to buy 1 new coil pack start on one side of the motor, replace 1 coil pack with the new one (save the one you pulled off), go to the passenger side dash fuse panel pull the clock backup fuse for 30 seconds and then put back in and drive. If the code comes back, take the new coil pack from the cyl you put it on, and move it to the next cyl and put the old coil (the one said to save) back in its original position and repeat till you find the cyl that is causing the misfire. 99.9% of the time its just 1 pack causing the issue.
Old 06-07-2011, 10:44 AM   #8
01tl4tl
Activity: 66.8%
or the cheater method--pull the power lead to one coil at a time, have helper note any rpm change with each one
the coil that doesnt result in rpm drop is the bad one
Old 06-07-2011, 6:30 PM   #9
smilecow
Activity: 0.8%
thank you for your advice. I ordered the part so I'll post the result on thrusday.
0300, 0301, 0302, 2004, acura, code, engine, mdx, p0300, p0301, p0302, p0303, p0304, po300, rsx
