Intake manifold, how do i remove it? - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL Community > Second Generation TL (1999-2003) > Problems & Fixes
Old 04-22-2011, 9:28 PM   #1
UBERTL
07 TL-S
2007 Acura TL
UBERTL's Avatar
Points: 3,251, Level: 35
Points: 3,251, Level: 35 Points: 3,251, Level: 35 Points: 3,251, Level: 35
I need to get to the knock sensor wire to replace it (a rat chewed through it ) but im having difficulties. Basically I just don't want to f*** anything up. I need to know what bolts to remove after removing the top part of the manifold and where I need to disconnect the manifold from the TB. Pics help me alot lol but I can follow instructions too. Also, do I need to replace any gaskets after I remove the manifold? I've searched for intake removal but all I come up with is egr port cleaning threads. Help would be much appreciated
WTF!!
UBERTL is offline   Reply With Quote
Old 04-22-2011, 9:44 PM   #2
Karanx7
Unregistered Member
2002 Acura TL
Karanx7's Avatar
Trader Rating: (2)
Kranax
Points: 7,724, Level: 58
Points: 7,724, Level: 58 Points: 7,724, Level: 58 Points: 7,724, Level: 58
Activity: 5.4%
Activity: 5.4% Activity: 5.4% Activity: 5.4%
Explain plz
2002 TL-P
CL-S6 Engine, CL-S6 Tranny, ATLP Cat-back Exhaust, OEM Lip Kit, UR Crank and Accessory Pulleys, XS-P Headers
Karanx7 is offline   Reply With Quote
Old 04-22-2011, 9:48 PM   #3
Karanx7
Unregistered Member
2002 Acura TL
Karanx7's Avatar
Trader Rating: (2)
Kranax
Activity: 5.4%
Those EGR port cleaning will tell you how to remove the IM. You don't have to replace the metal gaskets if they are not bent. You WILL need a torque wrench I believe.
2002 TL-P
Old 04-23-2011, 12:01 AM   #4
UBERTL
07 TL-S
2007 Acura TL
UBERTL's Avatar
I couldn't find instructions on how to get the entire intake off to get to that wire
WTF!!
Old 04-23-2011, 1:40 AM   #5
01tl4tl
Points: 40,286, Level: 100
Points: 40,286, Level: 100 Points: 40,286, Level: 100 Points: 40,286, Level: 100
Activity: 66.8%
Activity: 66.8% Activity: 66.8% Activity: 66.8%
once you get the manifold off there are several sensor wires exposed for you
follow procedures in egr cleaning for manifold removal
Once the manifold is off you will see the need for egr cleaning.. so do it now!
needed every 75kmiles,,,buy 3 cans carb cleaner
TB has 4 bolts, the lower rear is tough to get off with it on the car
You can remove the manifold and tb together --then seperate on the bench
I would get a TB to manifold gasket (comes in thermospacer kits) and IACV cover gasket
Just to have them in case one gets torn in removal
Clean the Iacv rod and chamber so it restores full movement and ability
torque spec 16 foot pound for intake manifold main bolts- critical to get right!!
Old 04-23-2011, 7:51 PM   #6
Rejckt
2003 ACURA TL
Rejckt's Avatar
Trader Rating: (2)
Points: 7,191, Level: 56
Points: 7,191, Level: 56 Points: 7,191, Level: 56 Points: 7,191, Level: 56
http://tl.acurazine.com/forums/showt...4#post11434934
2G TL SUPERCHARGER FOR SALE
http://acurazine.com/forums/showthread.php?t=838633
Rejckt is offline   Reply With Quote
Old 04-23-2011, 11:32 PM   #7
UBERTL
07 TL-S
2007 Acura TL
UBERTL's Avatar
Thanks, im going to get some gaskets and try it.
WTF!!
04, 2003, 99, acura, cl, clean, cleaning, intake, lower, manifold, removal, remove, replace, rsx, tl
