Air Bubbles in Power Steering fluid.....
Old 04-15-2011, 04:36 AM
mirrorshinecl's Avatar
Today as a preventative measure... had Timing Belt Changed in 01 CL-S (50k) along with the Water Pump, Tensioner Pulley, Tensioner, Idler Pulley and Fan Belts. Everything went smoothly, However, upon restarting Power Steering Pump was much louder then normal, then after turning the wheels back & forth, shutting off and restarting, noise is even louder and power steering fluid was mostly air bubbles and reservoir started overflowing? Would greatly appreciate any thoughts on what the problem might be?? Thanks.
Old 04-15-2011, 10:03 AM
I Drive Like A Dick 8≈
Nersh7's Avatar
Sounds like your power steering pump isn't pumping the fluid through, make sure that all the belts are tight for the power steering pulley and that everything was reinstalled correctly. The sound is from running the pump dry.
Old 04-16-2011, 11:43 PM
RooEng's Avatar
Make sure the hoses aren't kinked or collapsing. Especially the hose from the pump to the reservoir.
Old 04-17-2011, 11:24 AM
Unregistered Member
Karanx7's Avatar
Nooooo, your pump should be pumping fluid fine. The problem is that air is getting in too. Try to find the source where air is getting in. Take out the PS pump, and put it back in? DON'T over tighten the PS belt!
Old 04-19-2011, 12:15 AM
BAGII's Avatar
Definitely sucking air in the system! I see that alot. It's somewhere from the reservoir to the pump. It's a short hose and 2 clamps. just replace them to be sure.
TL-Rocket
04-29-2023 02:33 AM
Yikes
05-03-2021 04:29 PM
mike from annapolis
05-07-2017 08:21 PM
nash3222
09-10-2015 09:46 PM
Quick Reply: Air Bubbles in Power Steering fluid.....
