Front tire inside wear is this camber or something else? - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL Community > Third Generation TL (2004-2008) > Tires, Wheels & Suspension
Notices
Old 04-02-2011, 11:09 AM   #1
murph145
2007 Acura TL
murph145's Avatar
Points: 6,171, Level: 51
Points: 6,171, Level: 51 Points: 6,171, Level: 51 Points: 6,171, Level: 51
Activity: 2.9%
Activity: 2.9% Activity: 2.9% Activity: 2.9%
just noticed some wierd wear on the inside of my front tires very angeles at the inside edges of both tires like 1" wide and a 45 degree angle compared to the rest of the tire...
could this be camber or is it rubbing on something else?
my front camber is around -1.2 which isnt horrible but maybe that is enough to make a wear like this?
thanks!
2011 Lexus IS F Matador Red Mica/ Tein Springs / Arkym CF front lip, trunk spoiler, roof spoiler, rear diffuser side skirts / C-Mod CF Grill / Sikky Rear Sway Bar / Carson Tuned Silicone Intake / Straight Pipes / 35% Tint / 20" ADV.1 10TF with Nitto Invos 245/30 & 295/25
murph145 is offline   Reply With Quote
Old 04-02-2011, 8:47 PM   #2
Turbonut
Trader Rating: (1)
Points: 13,310, Level: 75
Points: 13,310, Level: 75 Points: 13,310, Level: 75 Points: 13,310, Level: 75
Activity: 17.5%
Activity: 17.5% Activity: 17.5% Activity: 17.5%
I'd get it on an alignment rack and see what the settings might be and have the tech check out the suspension. Look like a toe out with negative camber.
Turbonut is offline   Reply With Quote
Old 04-03-2011, 12:29 PM   #3
murph145
2007 Acura TL
murph145's Avatar
Activity: 2.9%
i had it aligned toe is fine camber is -1.2 front but its wearing really odd like a 1" wide patch at a 45 degree angle right on the sides
Old 04-03-2011, 4:36 PM   #4
Turbonut
Trader Rating: (1)
Activity: 17.5%
Sorry, but it's not fine, something is very wrong or it wouldn't be wearing out the inside of both front tires. Take it somewhere else.
Old 04-03-2011, 6:56 PM   #5
murph145
2007 Acura TL
murph145's Avatar
Activity: 2.9%
they gave me the report and they used a road force hunter machine
showed before and after toe along with camber... i dont have camber kits as of yet but i am getting some new tires for a stretch as soon as those go on next week i will take it to a new alignment shop and get some camber arms for the rear at least
the wear pattern is very odd though itrs right on the edge i dont even see how it can ride on the ground like that it makes me think its rubbing on something at extreme turn radius turns but im not sure ill have to take the rim off and look to see if there is a rub spot underside
Old 04-03-2011, 8:05 PM   #6
Turbonut
Trader Rating: (1)
Activity: 17.5%
Hunter Road Force is used for balancing, not alignmentm but from what I read it's on both front tires, so it's not a problem isolated to a suspension failure on one side, it's the same on both, bad alignment specs. It's been years since I tried this, but lay 2 pieces of paper down one on top of the other on a smooth surface, then drive straight over the paper slowly. If the toe is extremely out, the tire will drag the paper, if fine, the tire will roll over and no movement of paper.
Old 04-04-2011, 12:08 PM   #7
DimwitRj
that ONE RED tl
2004 Acura TL
DimwitRj's Avatar
Trader Rating: (2)
Points: 3,011, Level: 33
Points: 3,011, Level: 33 Points: 3,011, Level: 33 Points: 3,011, Level: 33
Activity: 0.1%
I'm no expert but how are your compliance bushings?
83 Supra --- 95 Integra GSR Sedan - Sold --- 04 TL Navi - Sold --- 06 Forester XT - Daily Driver
DimwitRj is offline   Reply With Quote
Old 04-04-2011, 12:19 PM   #8
murph145
2007 Acura TL
murph145's Avatar
Activity: 2.9%
^ not exactly sure what those are care to elaborate?
Old 04-04-2011, 12:25 PM   #9
murph145
2007 Acura TL
murph145's Avatar
Activity: 2.9%
If you look at my picture above the tire is wearing at a 45 degree angle right on the inside edge of the tire.... to me its weird because how can it wear at that angle its not like my car is driving on the edge of the tire with a -10 camber
Old 04-08-2011, 2:38 AM   #10
paperboy42190
2007 Acura TL
paperboy42190's Avatar
Trader Rating: (5)
Points: 17,499, Level: 84
Points: 17,499, Level: 84 Points: 17,499, Level: 84 Points: 17,499, Level: 84
Activity: 44.4%
Activity: 44.4% Activity: 44.4% Activity: 44.4%
what about the quality of the tire? i've had cheap sunny tires that wore unevenly due to the cheap material, even though i had good alignment
NBP TL Type-S//Volk CE28N//Custom BMW LED courtesy lights, License Plate Lighting//DVD Player//Genuine ZKW//A-Spec Lip Kit//Tein S.Tech on Koni SP3//Custom 4" CAI//RV6 V3 HFPC
UA7 SQUAD MEMBER #4
paperboy42190 is online now   Reply With Quote
Old 04-08-2011, 5:57 AM   #11
04WDPSeDaN
Elladas- S/C 6MT TL
2004 Acura TL
04WDPSeDaN's Avatar
Trader Rating: (1)
Points: 20,179, Level: 89
Points: 20,179, Level: 89 Points: 20,179, Level: 89 Points: 20,179, Level: 89
Activity: 14.1%
Activity: 14.1% Activity: 14.1% Activity: 14.1%
The problem is you can only adjust the toe on this vehicle. Your lowered like most on this forum and will run into one problem when you lower your vehicle.. That being Neg camber. If you want to fix this issuse then you will need a camber kit.
[]C0mptech Exhaust[]AEM CAI[]Tein SS[]TL-S Tails markers & Mirrors[]Decklid Lip[]Black'd 0ut, ZWK projectors,Sm0ked ambers Headlights[]UR Pulley[]thermo gaskets TB spacer[]Optium Red top[]Black R0of []5% tint windows][LED Lic/Int lights[]19" Stagger'd GoldVS-XX[]Comptech Swaybar[]Rotora Combination rotors[][Shaved key-hole[]Rear RDX brake covers[]6MT/NAVI/A-spec[]Type-S Front end[]A-spec Rims[]Interior C/F pieces[]DeBadged[]ATLP J-pipe
04WDPSeDaN is offline   Reply With Quote
Old 06-01-2011, 10:31 PM   #12
flstc4me
flstc4me's Avatar
Don't mean to hijack your thread, but I do want to say "ME TOO." My wife's 07 Type S Auto trans car is doing the same thing. The car has tire wear on all four tires on the inside edge over about a 1" wide area at a 45 degree angle. I'm not sure if it is wearing both the front and back because the tires are rotated frequently by the dealership. Her tires are Michelin Pilot Sport AS Plus (the 40,000 mile tread wear warranty tires) that have 13,000 miles on them and they are shot. The cords are nearly exposed.
A bit of history.
The first set of replacement Michelin Pilot Sport AS Plus tires: 13K miles ago we had the same problem with a set of Michelin Pilot Sport AS Plus tires that had been installed by NTB. Those tires had about 11K miles on them. When those were installed NTB said "you have to pay us to align your car, if you don't we can't stand behind the warranty or support you in front of Michelin." NTB did the rotate and balance for one year and I paid for the 1 year alignment which meant they checked the alignment twice after the initial alignment and each time they said all is well, the car is aligned. At the end of the 1 year alignment the inside of the tires were down to the cords. NTB said Michelin had defective tires and Michelin said NTB did a bad alignment. That same day we took it to the Acura dealer and Acura said the "alignment by NTB although acceptable to NTB was not optimal". This is how I worked out a deal on the replacement pilot sports that today have 13K miles and are spent.
The second set of replacement Michelin Pilot Sport AS plus tires: These lasted 13K miles as mentioned above and about 1 year. During the oil changes at the Acura dealership we asked that the dealership rotate the tires and check them for tread wear, etc. Each time they rotated and checked we got back a summary sheet that said good tires with good tread depth readings. Admittedly I did not look at the inside most edge because the outside edge looks good and the center of the tread looks good too. The inner edge is difficult to see due to tire width even if you turn the wheel completely to one side.
Two weeks ago my wife had brakes checked at the Acura dealership and they left the left rear wheel lug nuts very loose so that about 1/4 mile from the dealership only two loose lugs remained and three were gone. The dealer picked here up, installed some lug nuts and tightened up the lug nuts "gorilla tight." I could not get the lugs to budge at 140 ftlbs. I took the wheels off to re-torque them and noticed that the inside edge of the tires on all 4 tires are worn nearly to the cords. Days earlier the service tech wrote tread depth of 7/32 and said the tires were fine. The tires are good on 80-90 percent of the tread width, but the 10 - 20 percent thiat is not good is really not good.
What causes this? Most miles are driven locally and short distance trips by my wife, say 10K of the 13K. The additional 3Kmiles were from PA to Richmond, VA, or Charlotte, NC or Nags Head, NC. On these longer trips we had luggage in the trunk, car cleaning supplies, fishing gear, books, etc. There were probably a couple hundred extra pounds in the back of the car. These trips were spread out throughout the last year. Otherwise most of the 10K was with my wife alone in the car or my wife and I. I have heard that excessive weight in the trunk will cause premature tire wear.
The car is stock aside from a K&N air filter (who wants to pay for a new Honda filter when the K&N can be reused) and the Michelin Pilot Sport As Plus tires.
I have to call the dealer and ask them to check the alignment again. I won't go to NTB unless I have to and do not trust their alignment. When we had them check the NTB alignment and found error with it my wife decided to take it to the dealer for oil changes and ask them each time how the tires are wearing. They always tell her the tires are wearing well and never comment on abnormal wear patterns.
Any advice on how to keep tires on the car? I can't afford $1K for tires every 10 - 15K miles.
HELP! Any suggestions or experience appreciated.
flstc4me is offline   Reply With Quote
The Following User Says Thank You to flstc4me For This Useful Post:
MR1 (06-11-2011)
Old 06-01-2011, 11:31 PM   #13
murph145
2007 Acura TL
murph145's Avatar
Activity: 2.9%
^ i wish i knew the answer too my original stock tires did the same thing wore on the inside edge and now being lowered with lower profile tires the wear is faster and more severe....
you might want to check your compliance bushings to see if they are shot i here that may cause this issue... basically front horizontal bushing on lower control arm about 2.5" in diameter ... ive heard that if these are busted/cracked that it can keep throwing off the toe even after alignments.... i visually looked at mine the other day saw small cracks but nothing too horrible.... im still confused too... i cant even rotate my tires so its wearing fast in the front right now.... im going to take it to another tire shop and have it aligned there get the report back and see what they say or suggest i do.... my back tires are running a -3 camber but are not wearing anywhere as bad as the front with a lil over -1 camber.... i know its a fwd car but still its ridiculous wear...
let me know if you find anything out id really be interested as well to finally get this fixed!
Old 06-11-2011, 2:26 AM   #14
MR1
05/5AT/Navi/ABP/Quartz
MR1's Avatar
Points: 9,681, Level: 66
Points: 9,681, Level: 66 Points: 9,681, Level: 66 Points: 9,681, Level: 66
Activity: 2.2%
Activity: 2.2% Activity: 2.2% Activity: 2.2%
A bit of history.
10 - 15K miles.
I'm in the exact same boat. Car is stock, no accidents little aggressive driving. It has just under 70,000 miles. Had no problems till I replaced the original tires at about 45,000 and got my first alignment. I'm getting ready to replace the Pilot A/S again for the second time after 12,000. Readout from alignment is within specs. I'm going to a different Firestone and try to get it aligned to the tires instead of specs.
Let's see if we can't get this straightened out.
MR1 is offline   Reply With Quote
Old 06-11-2011, 3:10 AM   #15
nokiaboy808
06 6spd TL BAGGED
nokiaboy808's Avatar
Points: 8,000, Level: 60
Points: 8,000, Level: 60 Points: 8,000, Level: 60 Points: 8,000, Level: 60
i have the same problem with my front tires... i'm pretty sure it has to do with negative camber and toe being off. just installed camber kits so we'll see after i get the car aligned.
nokiaboy808 is offline   Reply With Quote
Old 06-11-2011, 7:10 AM   #16
Turbonut
Trader Rating: (1)
Activity: 17.5%
What causes this?
If the alignment is in spec according to the printout, there will be no uneven tire wear, so for the guys that are stock and notice uneven wear there is a problem with the alignment.
Many years ago, after the installation of new tires, I had the shop do the alignment on both the Cadillac and Buick I owned. A while later I installed new pads on the front of the Buick and as the tires were wide, the right front stood upright when off the car, but the left front fell over, looked closely and worn on the inside. I then looked at the Cadillac and sure enough the left front was worn on the inside also. Took the Buick back, put it on the rack and it was perfect. Drove to his brother’s shop, put it on the rack and the left front camber was way out. Corrected and no future problem other than one worn tire that naturally no compensation was offered. Actually, there are many horror stories over the years with alignment and balancing when other shops were doing the work.
There's your problem, you got it aligned. If the tires show no signs of eneven wear, don't get the car aligned.
Post the before and after printout and let's take a look to see what they adjusted incorrectly.
Old 07-19-2011, 9:17 PM   #17
oIce_BreakeRo
Points: 4,286, Level: 41
Points: 4,286, Level: 41 Points: 4,286, Level: 41 Points: 4,286, Level: 41
I'm having the exact same problem. I got some Yokohamas about 15,000 miles ago and the insides are completely worn. You can see the metal on the front ones. I just had an alignment done as well and the camber wasn't off by much. The guys at Meineke acknowledged as well that the alignment wasn't that off so they are not sure why the tires are wearing excessively on the inside. My car is completely stock.
Is this a widespread problem amongst the third gen TLs? What options do I have?
oIce_BreakeRo is offline   Reply With Quote
Old 07-19-2011, 9:36 PM   #18
murph145
2007 Acura TL
murph145's Avatar
Activity: 2.9%
^ i think its a pretty common problem i still have no clue whats going on with my tires either... i checked the one thing i thought it could be (compliance bushings) and they are not cracked.... so i duno it actually pisses me off but what am i guna do now
Old 01-01-2013, 9:50 AM   #19
Acuralin
Points: 4,251, Level: 41
Points: 4,251, Level: 41 Points: 4,251, Level: 41 Points: 4,251, Level: 41
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
Hey Murph,
It's been a long time...have you figured it out the inside wearing?
I just switched to the winter tires and noticed my front tires are all done, will need to buy new ones in the spring, exactly the same type of wearing as yours and the other folks' who replied later.
At first, I thought it was the negative camber causing it but did the alignment and all measurements were within specs.
Thanks.
thanks!
Acuralin is offline   Reply With Quote
Old 01-01-2013, 1:37 PM   #20
GeeCastle
2007 Acura TL
GeeCastle's Avatar
Points: 2,272, Level: 28
Points: 2,272, Level: 28 Points: 2,272, Level: 28 Points: 2,272, Level: 28
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
This happened to me to an then I got a ball in my tire. Is your tire rubbing on anything?
07 CBP UA6 5AT/Navi Mods: Aspec lipkit Plastidipped grill & wheels Function and Form type 1 Rolled and pulled fenders Ichiba wheel spacers 20mmF/25mmR Ingalls rear camber kit
GeeCastle is offline   Reply With Quote
Old 01-01-2013, 1:46 PM   #21
LaCostaRacer
2005 Honda Pilot
My Garage
Points: 8,440, Level: 61
Points: 8,440, Level: 61 Points: 8,440, Level: 61 Points: 8,440, Level: 61
Activity: 11.2%
Activity: 11.2% Activity: 11.2% Activity: 11.2%
Those look like Michelin Pilot A/S Plus tires. I had a similar experience as flstc4me above and my alignment was dead on. Those tires wore like that on the fronts and the rear too- the rear seems worse though.
The A/S Plus tires appear to be incompatible with our cars- the outer edges have a softer compound that must wear much faster than the middle.
2006 TL WDP/Parchment/5AT/Nav - purchased 7/29/06
- 22% Tint
- Comptech Rear Sway bar
- White interior LEDs and blue door LEDs / Hardwired Bel Sti Driver / Neopro Link IPod Adapter
LaCostaRacer is offline   Reply With Quote
Old 01-01-2013, 4:42 PM   #22
Acuralin
Activity: 2.1%
I know for sure it's not the alignment because:
1. the "before" measurements of the alignment I did last week matched the "after" measurements of the alignment I did last spring (very minor changes) - I did not even need another alignment lol
2. the front tires are wearing on the very inside portion at 45 degrees angle. There is not way I can drive on that portion of the tire on the street. If I did, the wheel must be 45 degree tilted to get that wearing. This is why I say it is no the camber....
If I didn't take a look underweight and made sure there is no rubbing when turning or free running, I would have said it was rubbing the inside of the fender for sure.
I even put the front car on the 2 ramps I have (as opposed to having it on the jacks), leaving it on its own weight, and I didn't see any rubbing at all neither when turning left or right nor when rolling the wheels straight.
But what it bugs me the most is, I do recall in the summer time I used to hear some rubbing when taking off from my driveway and having the steering maximum left or right, but didn't pay attention to that, maybe that was the cause.
Here is the setup I am running:
- 2006 TL automatic
- lowered all around ~1-1.5 inch
- 8.4 inch rims, 38 mm offset (8 inch / 45 mm offset is standard)
- 245/35/19 Bridgstone RE-11 (235/45/17 is standard)
- camber kit in the rear, none in the front since camber came out fine within specs
Murph's scenario seems to be very close to what I am seeing, really interested how he (she- figured it out.
Thanks.
Old 01-01-2013, 4:46 PM   #23
TLDude876
Chapter Leader (Houston)
TLDude876's Avatar
Trader Rating: (7)
Points: 8,951, Level: 63
Points: 8,951, Level: 63 Points: 8,951, Level: 63 Points: 8,951, Level: 63
Activity: 22.9%
Activity: 22.9% Activity: 22.9% Activity: 22.9%
I think this issue occurs depending on the wheel/tire combo. I was running Nitto Invo on my XXR's with no issues. Once I put them on my VS-XX, I noticed the issue.
04 AM UA6 5AT/NAV Mods: Aspec - BC Racing - Ingalls - Inspire Fogs - BrakeMotive- Redline - Magnaflow - ES1
Progress Thread - http://tl.acurazine.com/forums/showt...ight=tldude876
TLDude876 is offline   Reply With Quote
Old 03-03-2013, 2:04 PM   #24
ackebous
ackebous's Avatar
Points: 4,222, Level: 41
Points: 4,222, Level: 41 Points: 4,222, Level: 41 Points: 4,222, Level: 41
Activity: 1.1%
I have the same problem. 05 TL with RDX accessory wheels and Continental DWS tires. Had them on less the 2 years and the binding was showing. Back tires perfectly fine. Replaced both front and got an alignment $500. Tire shop said the specs were nearly on spot. They had no explanation. Anyone contact a dealer?
ackebous is offline   Reply With Quote
Old 04-25-2013, 6:15 PM   #25
wcurrin
2008 Acura TL
foreWard
Points: 1,741, Level: 24
Points: 1,741, Level: 24 Points: 1,741, Level: 24 Points: 1,741, Level: 24
Activity: 3.6%
Activity: 3.6% Activity: 3.6% Activity: 3.6%
I had this saem issue on my continental dws tires.....chords showing after 30k miles always rotated, figured it was camber, but had alignment done with new tires yesterday and within specs. Hopefully these toyo proxes p1 sports will wear better. IF not Im going back to michelins as much as i hate to pay for the name....
2008 TLS CBP 5at/ ivory int./ 35% tint/ AEM CAI/ Blacked out badges and grill/ roof spoiler
wcurrin is offline   Reply With Quote
2007, acura, balding, camber, cl, front, inside, mdx, negative, normal, tire, tires, tl, ware, wear
