TEIN SS with EDFC self install
Old 03-21-2011, 07:51 AM
jnc2000's Avatar
Was a major PITA, but well worth it in the end. A big thank you to forum member and friend gerzand.
Bottom line, each the fronts took less time then one of the rear. Overall the suspension on the 4G is more then a PITA to work on then the 3G - and at the recommended drop levels that TEIN gives you the OEM 18's do tuck.
The EDFC is not too bad. Depending on where you install the controller is another story. I chose the glove box which meant dropping the HVAC blower unit to access the grommet on the passenger side firewall.
More picture forth coming - but for now, cell phone pics.
Old 03-21-2011, 08:59 AM
I have car ADD
BLACKURA_NY's Avatar
OMG! Sex on wheels
I am so sad that I can't put my coils on my TLs anymore... i use my car for work more than ever now (25-30k a year) and I regularly have important corporate partners in the car, so driving a slammed, bouncy car isn't ideal...
i like my H&R springs, but DAMMMNN your car is looking BOSS
Old 03-21-2011, 09:07 AM
jnc2000's Avatar
Thank you!
Oh I drive.... believe me 30-45k a year
just crossed 12k this weekend. Even with this ride height it is not bouncy or harsh, actually on the TEIN recommended setting (6) it's softer then stock at this height. I have 3 presets for my driving programed into the EDFC - 6, 8, and 10 - even at 10 the ride isn't bad. I wouldn't feel ashamed taking a vendor or partner out in this car at all (as I oven do!)
I'm very very impressed with the TEIN setup - esp with the addition of the EDFC controller.
With my custom 19x9 RonJons coming and the RonJon grill I'll be set for summer
Old 03-21-2011, 10:35 AM
I have car ADD
maybe i should ditch the H&R's and go with tein SS again... decisions decisions decisions
still drooling at your pics!!
Old 03-21-2011, 04:40 PM
Chapter Leader (Northeast Florida)
FYAH TL's Avatar
Nice mod OP. I have 20's and with the TEIN SS the ride is just smooth...Looking at the pics you might need a camber kit based on how low you go.
Old 03-21-2011, 04:52 PM
djtanveer's Avatar
that looks amazing!!!!!
so how would you rate the installation difficulty on a scale of 1-10? 1 being the easiest. I plan on eventually getting coils and would like to install them myself.
Old 03-21-2011, 04:54 PM
rondog's Avatar
Justin, call me, I have updated 3D images of your wheels. I say 5 spokes instead of 7, saves weight.
Old 03-21-2011, 06:27 PM
gerzand's Avatar
Thanks for the recognition Justin. I now consider myself a "master" EDFC installer LOL. It was fun...and time consuming. But nothing is better than seeing the fruits of ones labor!
Old 03-21-2011, 06:43 PM
jnc2000's Avatar
Those pictures are pre-alignment. We had to undo a bit of the rear suspension to get the rear struts out.
As for difficulty - make sure you have a friend, and knowing the TL's suspension is very helpful. Both andy (grezand) and I have worked on the 3rd gen's suspension before installing our own, and others coilovers.
For the 4th Gen TEIN SS you will re-use the OEM top hats. it does require un-doing of a bit of the rear suspension to remove the strut. You can do it without removing the end-links but it's a PITA. Front's are way easy. You're normal 14mm and 12mm bolts up top, and the bolts holding in the forks and it drops away.
If I had to rate the difficulty with EDFC I would put it at a 9. If you choose to use the OEM grommet on the firewall to pull the front EDFC wires through you'll find it's not accessible by removing the glove box. You must drop the blower motor in order to access the grommet and pull the wires through. Then tap into a 12v switched, 12v constant (fuse panel with open slot in kick panel) ground, and dimmer in for the EDFC unit.
Old 03-21-2011, 07:37 PM
I have car ADD
^ when i installed the EDFC on my 3G, i actually clipped the wires in half... and ran it through the firewall that way... it was easier than trying to run it through with the large plastic plugs on it
Old 03-21-2011, 07:47 PM
jnc2000's Avatar
The plugs weren't that bad... it's more the location on the 4G that sucks.
Allan, check out my other thread for updated pictures:
https://acurazine.com/forums/showthr...1#post12801919
I vote you get the TEIN's on you're new 4G
Old 03-21-2011, 09:00 PM
-Brian
Nexson's Avatar
that looks fantastic, i wanted to just get springs, i am stick of crappy rides on my accord when lowered on all sorts of suspensions. Even had tein ss.
You can assure the ride is good?, Worth it to get the EDFC?
Old 03-21-2011, 09:19 PM
RIP RBP
upnout's Avatar
It looks good dropped
good mod
Old 03-21-2011, 11:42 PM
Steven Bell's Avatar
jnc, the coils make all the difference in the world. I know you have a huge sense of accomplishment because you did it yourself. Congrats man.....
2011 National AcuraZine Meet-Kansas City-June 12, 2011-Details Here!
Old 03-22-2011, 04:47 AM
jnc2000's Avatar
Nexson -- Ride is real good even with drop. Without EDFC and adjusted to TEIN's recommend setting (full hard) then back off 10 -- so that makes it 6 and 6 front and rear it runs slightly softer then stock. With the OEM 18's I feel less imperfections in the road, and it still remains taught when needed.
upnout -- Agree I can't stop looking at it. My friend and I are going to have to compare clearances and ride heights from 4G to 3G because he has a similar drop
Steven -- The coils do make a difference - knowing I did the work again, while in the end may have busted a few knuckles was well worth it. I have a whole new admiration for my car!
Old 03-23-2011, 02:36 PM
jnc2000's Avatar
I was right.. right now I'm running a -3.1 in the rear and a -1.3 in the front.
Time to order the camber kit
Even with all that suspension work toe wasn't that much out of alignment. I'm glad I bought the unlimited alignment package though because I'll sure be using it
midnite_tl (08-05-2011)
Old 08-05-2011, 03:23 PM
midnite_tl's Avatar
Had Teins installed in July when I was home I leave, didn't have the time to do it myself, but I couldn't be happier, EDFC to follow in the fall.
Thanks jnc for selling me on the Tein SS this past spring.
Running -2.75 in the rear and front is good with a 1.25" drop, suggestions for correcting this camber issue?? Alignment shop claims I have no room for a camber correction kit, wheels are too wide.
Old 08-08-2011, 01:42 PM
KB1Spec's Avatar
You install your EDFC at the glove box? I installed my on the coin tray between the shifter and radio unit.
Old 08-08-2011, 01:45 PM
jnc2000's Avatar
if the rim / wheel combo your running will not allow correction after camber kit installation it's time to roll your fenders.
drop + wide wheels/aggressive offset(s) often necessitate rolling of fenders. to achieve that perfect stance.
midnite_tl (08-09-2011)
Old 08-08-2011, 01:48 PM
jnc2000's Avatar
Yupp
Acc-Rite (12-30-2012)
Old 08-08-2011, 02:17 PM
KB1Spec's Avatar
I thought about in the glove but kind of far reach if I want to adjust the suspension on the fly. So I put it inside the coin tray. Will post pic later...
Old 08-08-2011, 02:20 PM
jnc2000's Avatar
I don't usually adjust the suspension on the fly... 12F / 11R seems about the perfect combo for my driving / road conditions.
Plus, I store a small bottle of cologne in the "Not An Ashtray" for the ladies :P
Old 08-08-2011, 02:45 PM
KB1Spec's Avatar
lol good call
Old 08-08-2011, 03:41 PM
KB1Spec's Avatar
My EDFC
treal512 (03-01-2017)
Old 08-09-2011, 03:51 PM
midnite_tl's Avatar
I just might do that, well I can't do anything over here, but I will be back in a couple weeks and then I will get back at it. My only other option is rotate the tires more often to keep the wear down I guess.
Old 05-22-2012, 10:55 AM
2012 TL SH-AWD
Zelaya's Avatar
Hey KB1Spec, can you close the " This is not a ashtray" with the EDFC? I'm still thinking either install it on the glove compartment or your setup.
Old 05-23-2012, 11:51 AM
Blueberryyumyum's Avatar
Not to bring this thread back from the dead but which chamber kit did you choose to go with?? I would PM you but think many lurkers on this forum will probably want to know as well =)
Old 05-23-2012, 12:36 PM
potmilkz's Avatar
off topic. lol
but to answer your question, go with spc.
Old 05-23-2012, 02:36 PM
Originally Posted by potmilkz
off topic. lol
How is asking which camber kit he choose off topic?? Is the question suspension related to JNC's setup? Yes... Has JNC clearly stated the amount of drop he's on with the neg camber he was currently at on post #16? Yes... Thanks for answering the "off topic question" which wasn't directed towards you
Old 05-23-2012, 04:28 PM
potmilkz's Avatar
clearly you haven't done your research..
there is only two possible camber kit on the market.
spc or j-power.
spc = more expensive, quality is top notch
j-power = less expensive, unknown quality but vouched by many members
now really think to yourself.. which one JNC used on his 40k car..
its not rocket science
Old 05-23-2012, 07:55 PM
Ingalls and Eibach also make camber kits as well for the 4G.. Clearly you haven't done your research... All are reputable brands with comparable prices..
Researching> E-Thuggin
Old 05-23-2012, 11:32 PM
jnc2000's Avatar
SPC guys... its not really a question
Old 06-07-2012, 02:40 PM
VRCD_NY's Avatar
Just a stupid question, im getting my tein ss today, will it void my warranty? Jnc your whip looks sick!! Thanks guys!!!
Old 06-07-2012, 08:23 PM
jnc2000's Avatar
No the manufacture can not blatantly void the warranty on the car due to the installation of an aftermarket part. However, if the aforementioned aftermarket component causes a failure / or compromises the integrity of an OEM part which would question the legality of a warranty clause they would be within their rights to void the warranty on that part of the car.
IE: Coil overs -- and you have suspension problems afterwords.
-- they couldn't not cover something not directly related (ex: EGR/ drive train -- unless the it is a drive-shaft and they intent to prove adverse wear due to stress of the aftermarket component....) -- you see its really a grey area in you need to really read up on your rights as a consumer. Hold the dealer to the wall if you have an issue, and don't be afraid to press it if you feel you are within your rights. Now if you cause a failure and try to get it covered... man up and pay for it.
Old 07-22-2012, 06:49 PM
sympley's Avatar
question from a noob here, if I go with the TEIN SS and don't drop the height too much do I still need the camber kit?
Old 07-22-2012, 07:48 PM
dragonwang's Avatar
Most likely not. My H&R dropped the fronts and rear by an average of 1.3" F/1.4" F respectively and I did't need a camber kit.
sympley (07-22-2012)
Old 07-23-2012, 11:03 AM
Excelerate's Avatar
You would have to get an alignment or at least determine how much your camber/toe is off in order to know that for sure.
Old 07-27-2012, 06:02 PM
sympley's Avatar
KB1SPEC, how did you run your wiring for the EDFC in the tray? Did you had to take the dash apart? It looks really good in that spot.
Old 12-12-2012, 01:45 AM
ReneC's Avatar
Bump on this question, I'm interested in that area in general and would appreciate any info on how that part of the dash comes apart.
Old 12-12-2012, 05:54 PM
potmilkz's Avatar
oh sorry i miss this.. but were you looking for just a front ball joint and a rear toe arm? because that is what Ingall offers.
what about your rear lateral arm and rear camber arm? I was under the impression that you were looking for a full 3 piece rear kit with a front ball joint kit..
You are right that they are all reputable brands but Eibach and SPC are the same product, eibach just sells it with their name on it. if you go to eibach and spc website and look at their part number, you will know..
CLEARLY you havent done your research..
Quick Reply: TEIN SS with EDFC self install
