2006 Acura TL REAR rotors - AcuraZine Community
Old 02-18-2011, 9:41 PM   #1
stiffdogg06
Get Money
stiffdogg06's Avatar
Trader Rating: (1)
Points: 3,383, Level: 36
Points: 3,383, Level: 36 Points: 3,383, Level: 36 Points: 3,383, Level: 36
Alright guys, I need your help BAD.
I am at my brothers house without a manual of any kind.
Front rotors and brake pads went fine.
We removed the caliper and the 2 screws from the rotors in the rear but the rotors will only come off about half an inch and not one inch more and we were pulling with our might... I personally never changed rear disc brakes (always had drums)
Made sure the e-brake was off, even pulled up and let off the ebrake to see if that helped. Nothing. Pounded it to hell with a rubber mallet. I didnt want to go to crazy and damage something since it is my brothers car.
My question is this:
How in the hell do you remove the REAR rotors from a 2006 Acura TL Automatic?
- 2006 NBP Acura TL
- 434whp/332ftlbs Methanol Fed 27psi GT3076R Civic
*10.557ET - 130.64MPH*
stiffdogg06 is offline   Reply With Quote
Old 02-18-2011, 9:56 PM   #2
stiffdogg06
Get Money
Trader Rating: (1)
My apologies. My buddy called and told me you need to remove the rubber access plug and stick a flat head in the hole to loosen the tension on the shoes against the rotor...
Sorry guys....
- 2006 NBP Acura TL
Old 02-18-2011, 10:45 PM   #3
Bearcat94
2007 Acura TL
My Garage
Bearcat94's Avatar
Faceless Not a Twit Un-Linked No Live Box StealMyInfoPls
Points: 54,818, Level: 100
Points: 54,818, Level: 100 Points: 54,818, Level: 100 Points: 54,818, Level: 100
Activity: 5.6%
Activity: 5.6% Activity: 5.6% Activity: 5.6%
D-085: Front and rear Brake disc (rotor), knuckle, hub, and front wheel bearing replacement
http://tl.acurazine.com/forums/showthread.php?t=132940
Check SM page 18-30 steps 7, 8 & 9. Ignore the stuff about the spindle nut in earlier steps - you don't need to remove it for a rotor change.
You only need to remove the caliper then ONLY the steps 7, 8, & 9 on 18-30 to remove the rotor.
'07 WDP/Taupe TL-S 5AT
'02 WDP/Parchment TL-S 5AT
Bearcat94 is offline   Reply With Quote
Old 02-19-2011, 1:01 PM   #4
stiffdogg06
Get Money
Trader Rating: (1)
Didnt really help. Thanks though. What I had to do was remove the rubber access plug on the rear rotors to access the ebrake shoe spring assembly which I turned to retract the shoes. I then was able to pull the rotor almost all the way off. Had to use a prybar at the end to finish the job to finally get them all the way off. I was just so use to just brake drums. Never messed with 4 wheel disc brakes. At least until yesterday.
- 2006 NBP Acura TL
Old 02-19-2011, 1:08 PM   #5
Bearcat94
2007 Acura TL
My Garage
Bearcat94's Avatar
Activity: 5.6%
Originally Posted by stiffdogg06 View Post
Didnt really help. Doesnt mention anything about how to remove the rear rotors. Thanks though. What I had to do was remove the rubber access plug on the rear rotors to access the ebrake shoe spring assembly which I turned to retract the shoes. I then was able to pull the rotor almost all the way off. Had to use a prybar at the end to finish the job to finally get them all the way off.....
It's the step with the 8 x 1.25 bolts that tells you how to back the rotor off the hub using the bolts - that would replace your need for a prybar. Step #9.
I'd think that simply releasing the e-brake would eliminate the need of backing the e-brake shoes off with the adjustment knob.
Regardless, glad you got 'em off and hopefully the thread and links will help someone else in the future.
The Following User Says Thank You to Bearcat94 For This Useful Post:
YeuEmMaiMai (07-19-2014)
Old 02-19-2011, 2:58 PM   #6
nickadamini
Points: 1,573, Level: 22
Points: 1,573, Level: 22 Points: 1,573, Level: 22 Points: 1,573, Level: 22
nothing more irritating then when something stupid like that completely screws up what should be a 30-60 min job
nickadamini is offline   Reply With Quote
Old 02-19-2011, 9:05 PM   #7
I hate cars
Points: 36,355, Level: 100
Points: 36,355, Level: 100 Points: 36,355, Level: 100 Points: 36,355, Level: 100
Activity: 24.2%
Activity: 24.2% Activity: 24.2% Activity: 24.2%
Rotors should come off fairly easy with the e-brake off without backing off the shoes unless you were pulling crooked. If that's the case the shoes are always dragging and you have issues.
'06 TL Dynaudio182/430/110 2x ID Max15s 2x JL HD600/4, HD750/1, PS8..255/40 NT05s..H&R FSB..Progress RSB..A-spec+Konis..Stoptech 13" BBK..Redline 5w-30..Redline ATF PSF '84 GN602rwhp 620lbs tq 3,000lbs.Awaiting the heart transplant..4.5L 2,300hp in 2015.
'14 Giant Trance SX
I hate cars is offline   Reply With Quote
The Following User Says Thank You to I hate cars For This Useful Post:
Old 02-28-2014, 10:39 PM   #8
07_J35A8_noob
say wattt??
2007 Acura tl-s
07_J35A8_noob's Avatar
Points: 1,653, Level: 23
Points: 1,653, Level: 23 Points: 1,653, Level: 23 Points: 1,653, Level: 23
hello,
I know this thread is old but the only thing that come close to my problem. I cannot get the rear rotor out no matter what i tried to do. it wiggle a little bit but does not slide out. I need help, i don't know what else to do.
Any other suggestion that would possibly help?
thanks in advance
91 corola-sold
99 legacy - sold
03 RSX-s - totaled
07 TL-s -- DD
07_J35A8_noob is offline   Reply With Quote
Old 03-01-2014, 8:33 AM   #9
Ccvn0
2007 Acura TL
Points: 1,892, Level: 25
Points: 1,892, Level: 25 Points: 1,892, Level: 25 Points: 1,892, Level: 25
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Or try this. Put everything together take long drive. Come back home park the car WITHOUT using e-brake. And start to remove the rear brake.
Ccvn0 is offline   Reply With Quote
Old 03-01-2014, 8:51 AM   #10
justnspace
2006 Acura TL
Points: 36,787, Level: 100
Points: 36,787, Level: 100 Points: 36,787, Level: 100 Points: 36,787, Level: 100
Activity: 100.0%
Activity: 100.0% Activity: 100.0% Activity: 100.0%
Originally Posted by 07_J35A8_noob View Post
hello,
thanks in advance
Did you get the rotor screws out?
the two little screws that are on the face of the rotor hub.
those screws are a bitch!
once those two screws are out, bang on the rotor itself with a soft mallet to loosen up the rust.
once you have banged on it pretty hard, rust will start to drop from the middle of the rotor and the spindle.
when loose, pull off rotor.
Do not do as the other poster above suggested and put everything back on. that is a big waste of time!!!!!
justnspace is online now   Reply With Quote
Old 03-01-2014, 8:59 AM   #11
07_J35A8_noob
say wattt??
2007 Acura tl-s
yes, screws(2) are out. hammer (check), all rust are loose, i could wiggle the rotor but it would not slide out as if something is holding it from behind
Old 03-01-2014, 12:48 PM   #12
paperboy42190
2007 Acura TL
paperboy42190's Avatar
Trader Rating: (5)
Points: 17,512, Level: 84
Points: 17,512, Level: 84 Points: 17,512, Level: 84 Points: 17,512, Level: 84
Activity: 40.5%
Activity: 40.5% Activity: 40.5% Activity: 40.5%
There should be nothing else holding it. Maybe just pull harder?
NBP TL Type-S//Volk CE28N//Custom BMW LED courtesy lights, License Plate Lighting//DVD Player//Genuine ZKW//A-Spec Lip Kit//Tein S.Tech on Koni SP3//Custom 4" CAI//RV6 V3 HFPC
UA7 SQUAD MEMBER #4
paperboy42190 is offline   Reply With Quote
The Following User Says Thank You to paperboy42190 For This Useful Post:
justnspace (03-01-2014)
Old 03-01-2014, 1:06 PM   #13
jkopuffs
jkopuffs's Avatar
Points: 2,277, Level: 28
Points: 2,277, Level: 28 Points: 2,277, Level: 28 Points: 2,277, Level: 28
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
drench with brake cleaner, beat the shit out of it. if still not off repeat.
06 Base w/ Nav // Cleared Headlights w/ CF Inlays, Halos, switchbacks // USA Spec // Brake Motive rotors & pads // WeatherTech custom mats // De-badged // Roof spoiler// All-around Limo Tint // CDM Tails// Amber rear Turn signals // Alpine SWE-1243 w/ Alpine V-Power 500 // Stage 3 Exhaust + Magnaflow mufflers
jkopuffs is offline   Reply With Quote
The Following User Says Thank You to jkopuffs For This Useful Post:
Old 03-01-2014, 7:36 PM   #14
Turbonut
Trader Rating: (1)
Points: 13,334, Level: 75
Points: 13,334, Level: 75 Points: 13,334, Level: 75 Points: 13,334, Level: 75
Activity: 18.8%
Activity: 18.8% Activity: 18.8% Activity: 18.8%
Did you remove the plug and turn the star wheel to loosen the e brake shoes?
Turbonut is offline   Reply With Quote
Old 03-01-2014, 7:42 PM   #15
justnspace
2006 Acura TL
Activity: 100.0%
make sure the E-brake isnt up!!
Old 03-01-2014, 8:08 PM   #16
cruc1a7
2001 Honda S2000
My Garage
Points: 365, Level: 7
Points: 365, Level: 7 Points: 365, Level: 7 Points: 365, Level: 7
Activity: 2.8%
Activity: 2.8% Activity: 2.8% Activity: 2.8%
I am going to do this tomorrow but why the hell they use this design? Would of made sense if they used a rear bbk with this.
2007 KBP TL Type-S
2001 SSM S2000 Ptuning GTX3076R
cruc1a7 is offline   Reply With Quote
Old 03-01-2014, 10:32 PM   #17
AndrewA
2004 Acura TL
AndrewA's Avatar
Trader Rating: (3)
Points: 6,153, Level: 51
Points: 6,153, Level: 51 Points: 6,153, Level: 51 Points: 6,153, Level: 51
Activity: 1.0%
you shouldn't have to loosen the drum pads, but sometimes it's necessary. remove the rubber plug and turn the star wheel and also use the threads where you can screw in bolts to push on the hub to get the rotor off.
2004 6MT NBP
Progress RSB : A-Spec Suspension : Enkei GTC01 18x8 Wheels : ATLP J-Pipe : RV6 3rd Cat Pipe : Comptech Cat Back : Hertz Energy Comps + Coax : JL Audio Amp + Sub
AndrewA is offline   Reply With Quote
Old 03-03-2014, 10:51 AM   #18
07_J35A8_noob
say wattt??
2007 Acura tl-s
thanks for the tips guys.
so i finally got it out on saturday after i got super frustrated and banging it away. turns out, there was a thin lips inside the rotor that was locking on to the shoes.
anyone knows how the lips could have been form?
Old 03-03-2014, 11:49 AM   #19
AndrewA
2004 Acura TL
AndrewA's Avatar
Trader Rating: (3)
Activity: 1.0%
shoes were likely dragging because of improper adjustment
2004 6MT NBP
Old 05-13-2014, 6:27 AM   #20
Jimflys
New Member
Points: 10, Level: 1
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Activity: 0.3%
HELP!!!!!!!
I am having the exact same problem...I even tried to losing the star wheel. It will not move!!!
Any Suggestion before I cause more problems for myself?
Jimflys is offline   Reply With Quote
Old 07-18-2014, 10:23 AM   #21
Amirks
New Member
Points: 11, Level: 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
Activity: 0.5%
I really need help, i have acura TL 2008 when i am making full left turns i am hearing that clicking noise and its only on the left turns, it is really hard to find an honest machanic here, they told me to change the drive shaft right side so i did it but the noise is still there can someone please help me
Amirks is offline   Reply With Quote
Old 07-19-2014, 4:22 PM   #22
YeuEmMaiMai
Robo Warrior
2002 Acura CL
YeuEmMaiMai's Avatar
Points: 17,798, Level: 84
Points: 17,798, Level: 84 Points: 17,798, Level: 84 Points: 17,798, Level: 84
Activity: 73.6%
Activity: 73.6% Activity: 73.6% Activity: 73.6%
^ check your left and right axles for damage
2002 Acura CL Type-S. 138K and still going strong...
2003 Subaru Legacy L 65K and still going strong...
YeuEmMaiMai is offline   Reply With Quote
06, 07, 2006, acura, acurazine, brake, brakes, break, change, pads, rear, replace, rotor, rotors, tl
